TR2/3/3A ground strap on a tr3
sp53
Could some please post a picture of the location for the ground strap on a tr3? I used to have it on my old server. Thanks
Geo Hahn
Here's how I did mine:
O'Reilly's (and no doubt others) sell a braided ground strap. If the firewall is thoroughly painted you will want to scrape the area around the bolt hole clean of paint, a star washer will also improve contact.
The other ground strap is the one from the body to the engine block -- generally from the left hand engine mount to a bolt on the timing chain cover.
TR3driver
Great Pumpkin - R.I.P
Here's a nice photo of the upper end from Don Elliott:
And a not-so-nice photo where you can almost make out the lower end
Kleykamp
This brings up something I've been pondering for a while. My car came with a "modern" sheathed cable attached to the positive ground side of battery and running to the engine block, mounted at the coil bracket bolt. I knew this was not original, but it works. I know the concern with the ground cable was to provide a substantial ground for the starter, which this configuration accomplishes. I haven't changed it over, because it worked and there were more pressing issues up to this point. Is there anything I am losing by just leaving it this way....other than originality points. All electicals work fine.
S
sp53
I would look at it this way. The engine and transmission sit on rubber mounts, so what is needed is a ground wirer/strap to go from the engine to the frame or the trans to frame so that the running gear is not isolated from the ground of the battery which usually grounds so the body tub. Perhaps with your configuration the lights, gas gauge, and wiper would ground through the choke cable which connects the engine to the body. I think you need a better ground.
Geo Hahn
...Is there anything I am losing by just leaving it this way...
I suppose that depends on whether you still have the above-mentioned ground cable from the timing cover to the left motor mount.
If that is in place then I see no serious problem with your set-up other than it looks wrong - but if something looked wrong on my engine and was so easy to set right I would not leave it that way.
6TTR3A
Efficient grounds have been the bane of all LBCs. For sidescreen TRs, the fuel gauge wins. As Geo Hahn says, get it done but don't make it obvious. Moss has the strap you're looking for (736-040) Even though it isn't exactly right for a sidescreen TR, it fits and can't be seen by a judge. It is what I installed & it fit fine, engine side left motor mount to frame side left motor mount.
Frank
TexasKnucklehead
I too have a black ground cable that comes from the battery down to the engine/trans. I put it there on purpose. I don't find it looks bad at all. I do have the ground strap near the mounts, but I think my bolt/nut with star washer lug provides a more secure grounding point. I know it's not 'correct', but it's my car, it works fine and few notice it's 'wrong'. I think the important thing is that the battery is 'earthed' as well as the generator/engine/accessories.
CJD
It’s not easy to get a picture. The two above are about as good as it gets. Geo is the only one I know who may have a better one. Geo...you out there?
Madflyer
LBC's and grounding should be as big or larger than supply cable. and tided to motor and frame and body. Body to frame may have poor contact to common ground. Some electoral ground to body ( lights ) others to frame ( horn ) The TR 6 ground has a braided cable with two mountings to motor and body very clean at firewall. NOT OEM on TR 3 but clean. Madflyer
I was at an aircraft sale and there was a British cargo plane with Lucas elect. I think grounding was the best place for it. sorry UK
Jim_Stevens
Madflyer: will the TR6 ground strap work on a TR3? I’ve been asking around, but no answer
DavidApp
The strap from the frame to the motor?
If it is long enough and the bolt holes are the correct size I would think any braided strap should work.
David
Madflyer
Mine uses one bolt trans to motor and one bolt at firewall and battery cut off. Grounding is first thing then clean look any braided strap. ROCKAUTO web has braided cables for a start. Madflyer
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
O TR2/3/3A TR3 Ground Strap Triumph 6
martx-5 TR2/3/3A TR3 Engine Ground Strap Triumph 12
K TR2/3/3A The engine ground strap? Triumph 6
B TR4/4A Engine ground strap Triumph 5
R TR2/3/3A Pic of installation of ground strap-TR-2 Triumph 2
S TR4/4A Horn ground strap Triumph 6
D TR4/4A Ground strap, ammeter Triumph 3
MGTF1250Dave T-Series TD/TF Engine Ground Strap MG 4
B BJ8 Ground strap Austin Healey 3
bugedd Ground Strap Spridgets 2
P Engine ground strap Austin Healey 2
RJS Steering Column Ground Strap Triumph 3
tmc Engine ground strap Triumph 6
H TR2/3/3A TR3A Ground strap Triumph 2
T TR6 Does a TR6 need an engine to chassis ground strap? Triumph 16
MGTF1250Dave TR2/3/3A TR3A Engine Ground Strap Triumph 12
A 1275 Spridget Ground Strap Spridgets 10
J TR2/3/3A Ground Strap on TR3A Triumph 1
M MGB Ground polarity '67 MGB MG 2
B Positive-Ground LED Light Strip Austin Healey 8
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A Muffler/Ground Clearance Austin Healey 13
jfarris TR2/3/3A Ground location for center panel lights 56 TR3 Triumph 5
R Ground wires under dash Spridgets 5
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
T Location of ground wire for BJ8 Austin Healey 6
K Is my BJ8 horn switch connected to ground positively or negatively? Austin Healey 3
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
S TR2/3/3A TR3 with Ground Conversion Triumph 18
apbos Positive Ground Alternator wiring. Spridgets 9
6 Relay wiring positive ground Spridgets 4
M BJ8 Positive-Negative Ground Conversion Austin Healey 7
M 66 ‘ BJ 8 Positive ground identification Austin Healey 4
doc50 Nash Metro Positive to Negative Ground Other British Cars 2
R TR2/3/3A Positive-ground LED lights Triumph 13
D TR2/3/3A Main ground connection Triumph 2
G TR4/4A Negative Ground Conversion Question Triumph 11
S TR4/4A Where do the ground straps connect Triumph 5
Joe Schlosser BN1 Ground cable Austin Healey 3
S TR2/3/3A Positive Ground Question Triumph 2
Marla TR4/4A Positive ground inverter Triumph 9
M TR2/3/3A Positive or negative ground? Triumph 6
P Bugeye Negative Ground Spridgets 15
S MGA 1956 MGA negative ground, True Spark Ignition distributor MG 3
P Jump starting a positive ground BJ8 Austin Healey 4
Jim_Gruber Am I set up as Positive or Negative Ground? Spridgets 12
