TR4/4A Triumph TR4 A clutch assembly and gearbox
Valenciablue
Hi,
The clutch of my 1966 Triumph TR4A is worn out... so I will need a replacement.
Can anyone tell me if it is possible to replace the clutch from underneath the car? (wihout having to dismantle gearbox tunnel, lower dash, carpets, etc... on the inside)
Or is this only possible from the inside of the car?
(my car doesn't have overdrive, so maybe the gearbox is small enough to be taken out from underneath?)
Thanks a lot for your help
Best regards to all !
trrdster2000
I hate to break it to you, the only way out is the passenger side unless you take out the steering wheel. No as painful as you think just a lot of unscrewing, Set the rear of the engine blocks up high after taking the drive shaft loose, it helps with pulling it out and putting it back in. Buy the plastic clutch plate alignment tool, until you try it without, you will never understand.
Wayne
TR3driver
Great Pumpkin - R.I.P
As a side comment, on a Stag it has to come out the bottom. Trust me, it's easier removing the interior!
KVH
I've removed and replaced two from '66 TR4As. Very satisfying, and easy. Just follow the manual to the letter. A good shop manual; the big blue one as I recall. You'll have to remove the seats, carpets and center console. Amazing how quickly that all happens. The sump must be supported with a jack and block of wood. I also put a transmission jack under the transmission "just in case" it might have fallen from my grasp, which it didn't. Once you've disconnected the diff, drive shaft and and transmission support bracket, and you've pulled the transmission back and turned it to a 45 degree angle it will come out of either side of the car. Use a helper at that point so you don't drop or scratch anything.
TR4A_IRS
You could also pull the entire engine and transmission assembly... Don't have to remove the interior for that!
trrdster2000
Ian, it's possible to all come out but by the time it takes for that you can have the tranny on the floor.
I should mention that a 24 inch extension and deep well socket allows you to take a handful of nuts off at one time, air makes it even quicker and you hardly have even moved.
Wayne
Geo Hahn
I too found this 'no big deal'. On a 4A going out thru the passenger side makes sense as the handbrake is centrally located. On my LHD TR4 I found it worthwhile to remove the steering wheel (2 bolts) and go out through the driver's side to avoid the handbrake.
...my car doesn't have overdrive...
The job is the same - but much easier as you're wrestling with a lot less weight.
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
S For Sale Triumph TR4 Factory Parts and Service Manuals on CD/ROM - 1961 - 1965 Triumph Classifieds 0
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
N For Sale 1964 Triumph TR4 street racer Triumph Classifieds 0
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
G For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420 Triumph Classifieds 1
B Triumph TR4 replacement fuel tanks Restoration & Tools 3
T TR4/4A 1963 Triumph TR4 Triumph 11
Rut TR4/4A WTB Original Triumph TR4, 5, 6 and Bentley workshop manual for 1967 TR4a Triumph 10
Stinger TR4/4A 1967 Triumph TR4-A FOR SALE Triumph 9
Triumph_TR4_Girl TR4/4A Second Hand Copy of Original Triumph TR4 Triumph 1
arizonamike TR4/4A Collector's Originality Guide Triumph TR2 TR3 TR4 Triumph 1
CZ_Dave Triumph TR4 Spotted 0
J TR4/4A Triumph TR4 Body Restorer Chicago Area Triumph 3
Atomic8 TR4/4A 1965 Triumph TR4 For Sale - $17,875 Triumph 4
M TR4/4A SVRA NJMP Triumph TR4 in-car Triumph 3
Tabcon TR4/4A Triumph TR4 T3T4 Turbo Charger Kit Triumph 3
C Triumph TR4 racecar build [w/ detailed photos!] Racing 2
3798j TR4/4A A Golden Triumph TR4 Triumph 10
Cabrioman TR4/4A History of the Triumph TR4 and the Surrey Top Triumph 10
glemon TR4/4A Complete Original Triumph TR4-6 Triumph 10
SCguy TR4/4A Triumph TR4 Oil Pressure Triumph 26
SCguy TR4/4A TRIUMPH TR2 TR4 DOOR RESTRAINT ASSEMBLY Triumph 1
KVH TR4/4A Triumph TR4/4A--The Horn Triumph 2
Tim Tucker TR4/4A Book Review Request: "HOW TO RESTORE TRIUMPH TR4" Triumph 5
J TR4/4A Vintage Triumph Register Build Codes Triumph 4
J For Sale Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
tr6nitjulius General TR 1/1/2024 in TRIUMPH Triumph 0
pbraun For Sale Triumph TR 250 Project Triumph Classifieds 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
tr6nitjulius General Tech TRfest 9/7-10th 2023 (150+ TRIUMPH Only) Triumph 6
R TR6 Triumph vin tag information Triumph 7
L For Sale British car collection for sale Morris Minors, Triumph Other British Classifieds 0
L For Sale 1961 Triumph Herald Saloon Triumph Classifieds 0
L My 1951 Triumph long ago British Motorbikes 0
tr6nitjulius TR6 TRIUMPH invades Redmond, Or for ATDI 2023 Triumph 4
Hamish Racing General TR At last a New Triumph Triumph 2
