Results 1 to 13 of 13
Thread: Rear brake backing plate differences: Bugeye vs. later model MG Midget
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Jedi Trainee DanLewis's Avatar
    Join Date
    Sep 2011
    Location
    Northern California
    Posts
    233
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    When I converted the front drum brakes to disc brakes, I dutifully changed the master cylinder and rear brakes to the later style from an MG Midget as recommended (see here). After reassembling the rear brakes, I found that the hubs were rubbing on the backing plates. At the time I temporarily solved the problem by adding a washer acting as a spacer between the axle and the hub, thus spacing the hubs outward a fraction of an inch.
    Today I disassembled the rear brakes and took some measurements. It turns out that the original Bugeye backing plates are different from those fitted on later model MG Midgets. First, the outside diameter of the Midget's plates is greater, but that doesn't create any problems. The problem is the thickness of the flange on the backing plate that is used to mount it to the axle housing. I've attached a drawing to illustrate the problem. If anyone has changed their rear brake backing plates to the later model MG Midgets and made it work, please let me know what you did.
    For example, does anyone know if the rear hubs on the later model Midget is different?
    Thanks!
    Dan
    1959 AH "Bugeye" Sprite: 1275 cc, ribcase, 3.9:1 diff, headers, 40DCOE, 9:1 pistons,
    Accuspark electronic ignition, Schneider 256-64F "street" cam
  2. #2
    Yoda Trevor Jessie's Avatar
    Join Date
    Nov 2003
    Location
    Louisville KY
    Posts
    8,086
    Thanks Thanks Given
    2
    Thanked in
    Re: Rear brake backing plate differences: Bugeye vs. later model MG Midget
    My solution was to spend a few minutes with an angle grinder on each brake drum.
    _____________________
    1970/2 MG Midget
    Datsun 5-speed
    Future Fuel Injection Turbo Project
    _________________
    1958/9 Sprite AN5L/1499
    1275 SuperCharged
    Datsun 5-speed
    _________________
  3. #3
    Darth Vader Rut's Avatar
    Join Date
    Jan 2008
    Location
    Tuscaloosa and Orange Beach, AL
    Posts
    2,866
    Thanks Thanks Given
    25
    7
    Thanked in
    Dan,
    Trevor X2. I reversed my drums on the hubs and spun them while using an angle grinder...doesn't take much.
    Rut
    Rut, '60 Bugeye, '70 MGB, '62 TR4, '66 TR4a IRS, '67 TR4a IRS, '68 TR4a IRS, '72 TR6
    When I went to school, they asked me what I wanted to be when I grew up. I wrote down 'happy'. They told me I didn't understand the assignment, and I told them they didn't understand life. John Lennon
  4. #4
    Join Date
    Sep 2011
    Location
    Northern California
    Posts
    233
    Thanks Thanks Given
    Thanked in
    Hi Trevor and Rut,
    'Sorry. I should have been more clear. Clearance between the drum and the backing plate are not the problem I was trying to describe. I too had to have some material removed from the edge of the drums. My drums are no longer rubbing against the backing plates.
    The problem is that the hub (not the drum) rubs against the mounting flange of the backing plate because the flange lip extends further out from the surface of the backing plate.
    Since apparently neither of you experienced this problem, I suspect there may be differences among backing plates from different years of the later model Midgets. I checked the online catalog of Moss Europe, and found the following listings for rear backing plates:
    BTA566 (RH), BTA567 (LH): From chassis No HAN6 20792, GAN1 13555
    BTA566 (RH), BTA567 (LH): G-AN4, G-AN5, H-AN9, H-AN10, A-AN10
    I think the above two (same part number) are for the Bugeye, and the next two are for later model Midgets.
    37H8804 (RH), 37H8805 (LH): G-AN6
    ATA7076 (RH), ATA7077 (LH): GAN1 13554
    Can someone translate this into model years?
    Thanks!
    Dan
  5. #5
    Join Date
    Jan 2008
    Location
    Posts
    2,866
    Thanks Thanks Given
    25
    7
    Thanked in
    Dan,
    Some hubs are machined a little deeper and they make contact with the brake cylinder, but I've not had one contact the backing plate except when the hole in the backing plate was not round. A die grinder or rat tail file should give you the clearance you need.
    Rut
  6. #6
    Join Date
    Sep 2011
    Location
    Northern California
    Posts
    233
    Thanks Thanks Given
    Thanked in
    Thanks, Rut!
  7. #7
    Join Date
    Sep 2011
    Location
    Northern California
    Posts
    233
    Thanks Thanks Given
    Thanked in
    Hi Rut,
    Quote Originally Posted by Rut View Post
    Rut
    I was thinking about your suggestion of grinding the excess material off the hub, but then I remembered that it's in (I think) a difficult place to grind. It's the surface pointed to in the figure below by the yellow arrow that rubs against the flange on the backing plate. How difficult would it be for a machine shop to do that?
    Dan
  8. #8
    Join Date
    Dec 2008
    Location
    South Dakota
    Posts
    3,947
    Thanks Thanks Given
    4
    Thanked in
    I changed to the later brake backing plate as well and don't remember exactly what I did. Do remember having interference at that point and I believe I releaved the backing plate rather than the hub. Also had a bit turned off the brake drum.
    Kurt
    65,66 Midget
    57 Berkeley, MGA
    Working on quality rather than quantity
  9. #9
    Join Date
    Sep 2011
    Location
    Northern California
    Posts
    233
    Thanks Thanks Given
    Thanked in
    Hi Kurt,
    Quote Originally Posted by nomad View Post
    My experience exactly. I ground off some of the material from the mounting flange on the backing plate (as well as the drums), but I finally put a washer between the axle housing and the hub to space the hub a little bit more away from the flange. Not an ideal solution to be sure, and I'd like to go back and do it all over. I didn't like the mess I made of the backing plates and have never been comfortable with how the hub are spaced out by the washers since the axle nut no longer engages as many threads as before. If it's possible to solve all of this by having a machine shop relieve some of the material on the hubs, I'll get some new backing plates and do it right.
    Dan
  10. #10
    Join Date
    Jan 2008
    Location
    Posts
    2,866
    Thanks Thanks Given
    25
    7
    Thanked in
    Dan,
    I ground the inside of the backing plate, not the hub. If you continue to have issues you may have a 'large' hub and a 'small' backing plate hole as far as specs go. Let me know if you need an extra set if hubs, I think I have a few around.
    Rut
  11. #11
    Join Date
    Sep 2011
    Location
    Northern California
    Posts
    233
    Thanks Thanks Given
    Thanked in
    Rut,
    Dan,
    Rut
    Is there an easy way to tell which I have?
    Dan
  12. #12
    Join Date
    Jan 2008
    Location
    Posts
    2,866
    Thanks Thanks Given
    25
    7
    Thanked in
    Dan,
    They are all considered 'normal' size, just match up with a little rub. Clamp the plate in a vise and make sure the hole is round and adjust it to fit the hub. I've used everything from a tack hammer to a file to relieve that area.
    Rut
  13. #13
    Join Date
    Sep 2011
    Location
    Northern California
    Posts
    233
    Thanks Thanks Given
    Thanked in
    Hi Rut,
    'Sorry, 'thought you meant that there were two different size hubs. So, it sounds like what people have done is only to relieve the backing plate, not the hub. That's what I did, but perhaps my mistake was to try to reduce the extent to which it protrudes rather than to make the round opening larger.
    Guess I need to consider what I want to do next before jumping in again.
    Thanks!
    Dan
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
