Results 1 to 5 of 5
Thread: no fire coming out of coil
For Sunbeam Tiger, Alpine, etc.
  1. #1
    Join Date
    Jun 2014
    Location
    Meredith NH
    Posts
    4
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Unhappy no fire coming out of coil
    have fire going into coil but not out of coil. Car won't start. When turn the key on it sparks and after turning the engine over and it doesn't start it sparks after trying to start. Some said maybe a short in ignition switch. This is Flame thrower electronic ignition. Husband thinks it is the ignitor in the distributor? Any suggestions.
  2. #2
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Floe Ice, Antarctica
    Posts
    6,064
    Thanks Thanks Given
    14
    Thanked in
    Re: no fire coming out of coil
    Power on and off spark usually means ignition switch okay.
    Probably an igniter. I think there is an on-line troubleshooting process. I'll see if I can find it again.
  3. #3
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Posts
    6,064
    Thanks Thanks Given
    14
    Thanked in
    So...is this a Pertonix with a Flamethrower coil?
    Here's Pertronix check out:
    https://www.mgexp.com/phorum/read.php?1,442367
  4. #4
    Join Date
    Jun 2014
    Location
    Meredith NH
    Posts
    4
    Thanks Thanks Given
    Thanked in
    Hopefully you are right. We ordered one and it is on its way. Had to order from out west so takes a few days. Should be here today or tomorrow. Thank you so far you seem to be on the same wave length as my husband after trying several other things. Thank you for your help.
    Quote Originally Posted by TOC View Post
  5. #5
    Luke Skywalker LarryK's Avatar
    Join Date
    Mar 2007
    Location
    Millstadt, IL
    Posts
    1,771
    Thanks Thanks Given
    12
    Thanked in
    Did the fire come out of new coil?
    Larry K
    58 Jag 3.4 MK 1 auto under restoration, 57 Jag 3.4 MK1 manual ,
    03 Cooper S, 2011 Cooper S Countryman, 2011 Land Rover LR4 HSE LUX, 1964 Valiant V200
    Also had , 68 Cortina 1600E, 64 Spit 4 & 80 1500, 73 GT6 3, 71 XJ6, 79 XJ6, 86 XJS V-12, 53 XK120 OTS.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
