TR6 Spring Compressor [Atlanta area??]
kbatl
Hate that this is my first post and I'm asking to borrow a tool... anyone in the Atlanta area have a spring compressor I could borrow? I'm installing new bushings and springs in my '72 TR6.
TIA,
Kevin
'72 TR6
KVH
I'm curious, do the simple Moss Motors "huge long screw and plate" design spring compressors last forever, or do the threads start to wear and allow the nut to slip? I've used mine a few times and I seem to notice some thin shearing of the steel around the threads. Anyone notice the same?
charleyf
I made my own using a 5/8" bolt from the hardware shop. I have now used it on about 10 springs and it is not showing any wear. I tried a half inch bolt before that and it did not hold up. I posted some pictures of it on a thread just a few weeks ago.
Charley
K
kbatl
Charley
Thanks Charley,
I've been searching for at least a drawing with dimensions of the bottom bracket I've seem some make with the holes that go over the studs and a hole in the middle for the bolt. I have a buddy that can plasma cut and I'd rather give it to him once to cut than have to go back and forth cutting. I've seen some that don't have the holes and simply rest on the bottom. Overkill, but I'll probably go with 3/4" rod and just make my own. I've got a feeling that I'll be adding spacers to the new springs so having my own will probably be better.
Kevin
bobh
I made my own. I think it is 1/2" threaded stock. The threads were well worn after changing my bushings. As mentioned above 5/8 may be a better choice. Better yet a would be rod with Acme threads. If you are not familiar with Acme threads take a look at a bench vise. The screw uses acme. I have not tried to find acme threaded stock so I can't offer a source.
For the ends of mine I cut pieces of 1/8 flat stock and drilled holes for the threaded stock to pass through. I also uses a bronze bushing to allow the nut to turn. It's beed 4 or 5 years so I don't remember the exact details.
mrv8q
I thought that car on the Scribd site looked familiar!
Hope Dale is doing OK.
Tr6easyrider
Kevin
You can find Dale Todd over on The Triumph Experience web site. He goes by 'Sabalo' and resides in Florida.
Looks like he's doing Ok. Long live Amos!
charleyf
Thanks Charley,
Kevin
If by the term lower bracket you mean the square washer that I used for that purpose. I used a square washer that is commonly used for holding the sill plate on the foundatin of a new house. It is about 3/16 to 1/4" thick and is about 2 & 1/4 " square. It fits fine between the four studs that hold the shock absorber in. Nothing fancy there.
Charley
2 For Sale Dr. Doolin Spring Compressor for TR3 Triumph Classifieds 0
M For Sale Churchill 18G106 Valve Spring Compressor for Austin Healey 3000 Austin Healey Classifieds 0
A TR6 Spring compressor Triumph 16
F Who needs a Spring Compressor... Spridgets 12
ekamm TR2/3/3A Tr3 coil spring compressor Triumph 20
DNK Spring Compressor Triumph 9
H Coil Spring Compressor Triumph 10
Mickey Richaud Strut/Spring Compressor Restoration & Tools 10
eejay56 Spitfire Spitfire spring compressor Triumph 11
I TR6 How do I use this? TR6 spring compressor help Triumph 15
Foghat73 MGB Spring compressor for MGB front suspension MG 45
K TR2/3/3A Need Pic & Dimensions of TR3 Spring Compressor Triumph 2
CraigLandrum TR2/3/3A TR3 spring compressor Triumph 7
T Recommendation on coil spring compressor Triumph 6
S building front spring compressor Triumph 24
M VALVE SPRING COMPRESSOR ? Restoration & Tools 5
Simon TR4a Valve spring compressor Restoration & Tools 2
77MidgetMkIV spring compressor bolts Restoration & Tools 3
Cain How to Use Spring Compressor Triumph 10
martx-5 Spring Compressor Triumph 3
Jarhead Coil Spring Compressor Restoration & Tools 5
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 0
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
SpeedyG TR4/4A Door window regulator spring Triumph 5
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
P MGB 1974 MGB front spring length. MG 0
F 59 bugeye spring bushing bolt Spridgets 8
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Clutch slave "return spring"? Triumph 3
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A First drive of spring - I hate electricity!!! Triumph 7
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
B Poor quality BE replacement spring boxes Spridgets 0
B Any issue with cutting this weld on the spring base plates? Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
jfarris TR2/3/3A Relacing rear spring busings Triumph 3
J TR4/4A Seat install, Spring clip Triumph 0
F TR2/3/3A Leaf spring advice Triumph 16
K Missing spring clutch release lever Other British Classifieds 1
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
T Heater Door Spring Austin Healey 1
R General TR Spring collar flange thickness options Triumph 2
Editor_Reid Unusual Leaf Spring Austin Healey 4
J Tips for quarter elliiptic spring install Spridgets 3
L Welding Bugeye Spring Base Plate?? Spridgets 1
