The Good the Bad and the Ugly
JamesJ
2 british, one not so much!
James
Platinum
Is there a Lotus twin cam in the Mexico?!? :semi-twins:
J
JamesJ
Good questions.
Ist Mk1 2ltr BDG
They all can be good bad an ugly. Depending on day and mindset
But Ugly.... ST1
Good.... STI
Bad..... STI (it can bite)
Ugly...... MK1 (present State)
Good.......MK1
Bad.... Not Mk1
Ugly........ Not elan for sure
Good.........Elan
Bad......Not Elan
AngliaGT
James,
Just where,in California,are you?
- Doug
Velox The Good, the Bad, and the Ugly Austin Healey 3
Radford MGB MGB Tires The Good, the Bad, and thhe Ugly MG 33
D HS2's on a 1500...good, bad or ugly????? MG 17
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
P TR6 Bad Luck? Triumph 51
jlaird MGB Follow up to my bad post on prewar MGs MG 4
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
T TR2/3/3A bad napa points Triumph 9
S TR2/3/3A Now the bad news. BRAKES Triumph 7
S TR2/3/3A How bad is this? Vertical link Triumph 12
Alfred E. Neuman TR4/4A Bad news on my TR4 Triumph 8
D TR2/3/3A Bad parts. Triumph 16
charleyf TR4/4A Symptoms with bad condenser Triumph 14
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
W TR2/3/3A Overheating Bad Triumph 12
roscoe Good news/bad news Austin Healey 11
Rut Help a bad memory out... Spridgets 6
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
C TR6 Frame Pics, some bad news Triumph 9
M TR6 Fresh rebuild gone bad!!!!!!! Triumph 13
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
TR3TR6 TR2/3/3A Anybody else having a bad day! Triumph 31
S Is it a bad idea to buy a higher pressure radiator cap? Austin Healey 47
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
gbtr6 TR6 Good news, Bad news Triumph 10
JFS TR2/3/3A Bad Water Pump Triumph 11
P TR2/3/3A "MaXpeedingRods" con rods good or bad? Triumph 3
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
D Removing servo . Good or Bad Austin Healey 12
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
Sixpack TR6 Bad Oil Leak Triumph 24
tinman58 TR2/3/3A Bad thinking? Triumph 25
Geo Hahn TR2/3/3A Bad Day in the Garage Triumph 23
tinman58 General Tech Bad spark plugs Triumph 7
DanLewis How bad does your Bugeye need a boot? Spridgets 6
bighealeysource How to color sand really bad orange peel Restoration & Tools 6
D Spitfire '65 Spitfire MKII w/bad vibes Triumph 4
T is my generator bad? Austin Healey 5
T TR2/3/3A Sticker idea; good or bad? Triumph 11
pkmh Distributor rotor gone bad more than once. Austin Healey 5
PAUL161 Moss Motors T Series Parts - Bad Gaskets! MG 5
Boggsy64 MGB Brit are bad engineers MG 17
M My '65 suddenly started running bad today Spridgets 37
HealeyRick Bad Day on the Hill in NZ Austin Healey 7
S TR2/3/3A Bad fuel perhaps water tr3 miss Triumph 0
bertl Bad Surgery Triumph 7
J Bad News 1098 Spridgets 14
John_Mc Probably just a bad ground somewhere... Triumph 1
