Getting ready for Spring
Voda
Have the 100M up on jack stands. Changing the oil, etc. getting ready for Spring driving. Planning on using Valvoline VR1 this time. Any thoughts? What Weight?
pkmh
Engine oil, I have been using and most will say 20W50, if Valvoline is mentioned. For transmission, again Valvoline is one, but there are other solutions and I am sure others will chime in (aside older posts that may still exist on this subject). The advice I hear over and over is to be sure the tranny oil used is a non detergent motor oil for contaminants remain suspended due to no filtering system to catch, other than the existing screen at the bottom which works on gravity (I believe).
Keoke
They just do not make any better IMOP.:encouragement:
GOT Zinc too
I run 60 weight but you can use the same single weight you have been running I would think
I have this Arizona and California heat to live with so I have settled on the 60W.
When you change oil in Phoenix in 115 Degree ambient 60W run just like water.:smile-new:
AH100M
60W in the transmission in Burlington WA?! Burlington's not Phoenix; it's not even Los Angeles. I think 30W is fine. That's what I run here.
dougie
I switched to Joe Gibbs 15w-50 Hot Rod oil 5-years ago when my race engine builder suggested it was the best oil to protect internal engine components in periods of extended storage. I put about 500-1000 miles on my BJ8 a year, it's the non-use that I worry about.
https://www.drivenracingoil.com/dro/hr1-conventional-15w-50html/
Keith_M
Like Dougie, I use Joe Gibbs 15w-50 Hot Rod after it was recommended to me by my machine shop. It has the zinc necessary for flat tappet engines. Not cheap, but how often do you change your oil, and how much does an engine rebuild cost?
30W nondetergent for the tranny.
jcsb
I'm listening since a couple of years ago we bought a house in Santa Fe, NM. Plan to store the car there and use it 6 months of the year. This will be the first time I will actually store a car due to weather. In Houston it just doesn't get cold enough.
John
Rob Glasgow Getting Ready for Winter Austin Healey 24
X getting ready for bodywork and paint Spridgets 11
cbrvfr Getting ready for a 1200 mile trip in the BN4 Austin Healey 26
G Wash...Wax and getting ready ! ! Triumph 2
T Still getting ready for Triumphest... Triumph 5
tahoe healey getting ready for post paint restoration Austin Healey 5
Brosky Getting head ready to install Triumph 19
JPSmit Getting ready for the Ozarks trip? Spridgets 10
Stinky Getting ready for Good weather Triumph 5
Patton Paint and Body -Getting it ready to send it off Austin Healey 10
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Celtic 77 MGB Getting closer! MG 5
J Finally getting (re) started on the Bugeye Spridgets 27
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
D TR2/3/3A Getting difficult to start. Triumph 6
S TR2/3/3A problems getting the engine to run correct Triumph 21
J MGB 73 getting loud squeal with acceleration MG 11
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
M Getting behind the dash on BJ8 Austin Healey 4
John Turney Getting Speedometer out of the Case Austin Healey 6
tr6nitjulius General TR Part 4 What We Missin' we getting closer Triumph 0
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
J TR2/3/3A Finally getting started Triumph 20
glemon GT6 GT6 Getting Some Recognition Triumph 8
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
D Getting closer... Spridgets 2
RAC68 3D Printing Getting Closer Austin Healey 16
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
steveg Really Getting Into one's Healey Austin Healey 17
M TR5/TR250 problem getting engine running Triumph 15
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
Jim_Gruber Brake Light - Getting them working Spridgets 8
Darrell_Walker General TR TR3A on Comedians in Cars Getting Coffee Triumph 7
S TR2/3/3A getting a new multi meter Triumph 9
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
RickB MGB Rain water getting inside behind dash MG 17
drambuie Getting more horse power from a Healey 100 Austin Healey 63
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
Jim_Gruber 1/4 Elliptics- Getting the Bast__rd Apart Spridgets 22
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
steveg Unable to edit posts, getting a wierd message FORUM Navigation Questions 2
RickPA Getting back in the game Austin Healey 5
D Getting hot in the car [AH3000mk3] Austin Healey 6
Got_All_4 General Tech Getting the nut off for J Type drive shaft flange Triumph 3
T Spitfire Randall - anyone you would recommend for getting a driveshaft shorted in SoCal Triumph 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
B TR2/3/3A Is a 63 TCF probably needing total restoration worth getting into? Triumph 16
