BJ8 O/D Question
Have a friends BJ8 at my house and the OD seems to operate strangely, but maybe it is OK and I just don't understand. When driving the OD kicks in just fine with the flip of the toggle, but I also understand that the throttle switch should disconnect the OD when 1/3 depressed. I have adjusted everything and double checked the connections but the OD will not kick out when the toggle switch is on. If I am driving I OD and flip the toggle off, the OD stays engaged until I depress the accelerator 1/3 or more to disengage. Is this the normal procedure? Doesn't seem so to me. Any help or suggestions would be appreciated. Many thanks.
Keoke
Flip the toggle switch OFF then depress the accelerator pedal.
Keith_M
Totally normal and correct behavior. The overdrive should only kick off when you flip the switch AND depress the accelerator. This is done to prevent damage to the overdrive that could occur if it kicks out when engine braking.
D BJ8 brake master cylinder question Austin Healey 6
CLEAH Another BJ8 Misfire Question Austin Healey 11
B BJ8 Camshaft Question Austin Healey 3
D Another question 1967 BJ8 top installation,metal retaining strip Austin Healey 1
60TR3A BJ7/BJ8 Boot Cover Question Austin Healey 15
C question on the front brake lines for BJ8 Austin Healey 2
ttrotter 67 BJ8 Blow by question Austin Healey 12
bighealeysource BJ8 wiring harness question Austin Healey 8
C BJ8 Door latch question Austin Healey 9
D bj8 shock conversion and suspension question Austin Healey 15
J Late BJ8 front suspension question Austin Healey 18
MadRiver BJ8 Center Console 3000 Badge Question Austin Healey 13
bighealeysource BJ8 exhaust question Austin Healey 6
D new moss carpet question, BJ8 Austin Healey 1
David_K BJ8 camshaft Duration and Lift question Austin Healey 3
David_K BJ8 cam question -- Regrind and Where? Austin Healey 7
C AH3000 BJ8 Brake Caliper question Austin Healey 7
David_K BJ8 hardtop question....Almost an AH BJ8 owner!! Austin Healey 3
Velox BJ8 Antenna Question Austin Healey 3
mikejones BJ8 wiring question Austin Healey 2
M BJ8 interior question Austin Healey 7
S BJ8 Distributor Question Austin Healey 16
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
