MG... Turn Signal Problem
streetking
Hello, New Member Here!
I Own a 78 MG Midget, Bought it last Summer. Wonderful Little Car!
Question? I Don't Have a Owners manual, all the Printing on the Dash Switchs are worn off. My Turn Signals did operate normal, till one day i Pushed a Rocker Switch on the Dash, I Believe its for the 4 way Flashers? ( right side of steering in dash area ) Now the turn signals quit?
I checked the operation of the switch i pushed, and it acts very loose...Like i Broke it...BUMMER!!!
Anyone have a Diagram of a Dash Board? so i can see what all switchs are for?
I'm Seriously thinking that that 4 way switch controls the voltage going to the flasher? I think the Flasher is located on the right side under the Dash somewear neer the Kick area?
Any Feed Back Would be GREAT!!
JPSmit
Hi, welcome! Glad you are here. From your description, you don't have a proper manual, you will need to get one or two. Haynes and Bentley are the best. Each has wiring diagrams. As well, you can buy them off ebay:
https://www.ebay.com/itm/MGB-1977-1...anuals_Literature&hash=item3375384cd3&vxp=mtr
that said, if I recall correctly, the signal lights do in fact go through the flashers. Moss will sell you a replacement switch. Good luck and, you are in the right place!
Flash_Harry
Don't know how closely the Midget and MGB wiring diagrams are, but you could take a look on this site for the relevant year, just in case. If it is close, you can download them and print one out.
https://www.advanceautowire.com/
S
streetking
Thanks for the Feed Back, Correction! I don't have a Manual, Thats why i'm asking questions. I guess i just need to get a simple owners manual? i found them on ebay for around $19.00 bucks. Then i can see just what switch...Does-What?
Thanks!!!
dklawson
Bentley manuals are wonderful if you can find one for a good price. Used ones do show up on eBay from time to time. People complain a lot about Haynes manuals but I believe those complaints often come from people who never tried to use Chiltons or Clymers manuals from the period. Haynes are really not that bad.
The wiring diagrams at the Advance Auto Wire web site linked above are great. Even after you get a manual you will probably find yourself referring to the Advance Auto PDF for its color coding and clarity.
As mentioned above, in Lucas wiring, the hazard and turn signal circuits are tied together with the hazard switch coming "first" in the wiring. If the hazard switch fails you will not have turn signals.
Boggsy64
I found lots of wiring diagrams online. In my opinion the Bentley wiring diagrams are hands down the best! I just googled "bentley MGB wiring diagram", you can probably do the same.
Boggsy64
I often also use the Moss Auto parts diagrams (at least the diagrams Moss uses) to put 2 and 2 together for me. I can match the drawings to switches etc.
bob67bgt
If you find the signal flasher and run a jumper to the solid green wire terminal (unplug the existing wire) you should have working signals and there will be no 4 way flashers working. That should keep your signals working until you get a flasher switch that works. Better to have signals and no flashers than nothing at all. Bob
dklawson
To expand a bit on Bob67bgt's suggestion, look for the green wire going into the turn signal flasher . Run your jumper wire from that terminal on the flasher to the GREEN wire going into the hazard switch. This will bypass the hazard switch and give you working turn signals as he said.
Boggsy64
I have a question not exactly related but close. How do or has anyone found the correct gauge wire with color striping for wiring repairs? Most all of my harness wiring has cracking insulation and many wires are scratched and broken. I don't want to replace the entire harness but would like to get correct wire colors for repairs.
Mickey Richaud
Here ya go - if these guys don't have it, you don't need it:
https://www.britishwiring.com/MG-s/13.htm
dklawson
Nice guys at Britishwiring.com. You will find they have most of what you need for your repairs and customization. Whenever I order I make sure to add some extra bullet connectors and the rubber junction sleeves (whatever they are called) for them. I always seem to find a wire or two where the connectors are failing or have failed.
JPSmit
Not sure about the wireharness colours - but, streetking, I just re-read your posts and realized that you are in the wrong forum. I hadn't computed that you are a Midget owner and not a 'B owner - let's get you over to Spridgets (Sprite + Midget) where you belong! (With me BTW)
Mickey Richaud
Thanks, J-P - will switch over to the Spridget Forum.
bthompson
The switch to the right side of the steering wheel on the dash is the headlight switch. The hazard switch is in the center console on the left hand side.
S
streetking
Hello again!
Thanks for all the wonderful advice & feed back. But, my Question was Never Really Answered. I'm unsure just what switch i broke in the Dash Area?? don't really know if it does Link into the Turn-Signals? all the markings on the switchs are worn off, so...i'm un-sure just what it operate's?
I did put a Bid on a Manual,,,ebay,,,Lets see if it will answer my question? Sorry! to bother all of you with such a Lame Question!! should have just ( SHUT-THE-FRONT-DOOR!! ) and Bought a Manual...Lol :highly_amused:
dklawson
Can you post a picture of your broken switch? If not, try Googling for a picture that's already online which shows the part and post a link to that picture.
bthompson
Here ya go!
All the across the dash, from left to right:
- Rotary knob that opens fresh air flap to heater under the bonnet (mechanical connection.)
- Heater fan switch. On/off, to blower under the bonnet. (Off is in UP position.) Labelled FAN.
- Left turn indicator.
- Tachometer.
- Oil pressure/water temperature dual gauge.
- Brake warning light. (Lit by a pressure differential between front and rear.)
- Fuel level gauge.
- Speedometer. (Reset knob for trip odometer below dash under speedo; rotate to reset.)
- Dimmer for dash lights. (Above speedometer.) And aptly named: the lights are dim or dimmer.
- Right turn indicator.
- Headlamp switch. Three positions: up is off, middle is park lights, down is headlights. Labelled LIGHTS.
- Choke knob, at top right. (You probably have the Stromberg water choke instead of a manual choke.)
- Red light is a charging warning light. (Lit by a voltage differential between battery and alternator.)
- Blue light is the high-beam warning light.
Vespa
Member
The turn signal, um, signal, routes through the hazard flasher switch. The flasher switch almost never gets used, so the copper contacts inside get corroded. When you turn on the hazard switch, the corrosion can get moved into a position where is stops electrical contact inside the switch. So when you try to use the turn signal switch, so no power goes through the hazard switch, and the turn signal lights don't work. Two solutions. First, flick the hazard switch of and on like 25 times in a row. This will scrape off the corrosion on the hazard switch inner contacts. The turn signal switch should work now. If not, you need to remove the hazard switch, take it apart, and clean it out, or get a new one. It's not hard. :smile:
- Paul B.
dklawson
Streetking, if you didn't win the eBay auction, try Amazon. The Haynes manual is a good general manual (in most cases) and it is very affordable.
https://www.amazon.com/Midget-Austi...d=1392773490&sr=8-1&keywords=mg+midget+manual
Bill posted a good picture of a Midget dash above. I couldn't see the hazard switch on it so I went looking for a picture of the switch. The closest I found was the image below. The hazard switch is on the angled console (it looks to be slightly to the left of and above the gearshift knob). Is that the location of the switch that broke on your car?
M Europa turn signal problem Lotus 7
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
M Turn signal problem Austin Healey 3
Brinkerhoff T-Series MG TC turn signal problem MG 1
B TR2/3/3A Another turn signal problem Triumph 5
sim 58 sprite turn signal Problem Spridgets 6
L Turn signal problem solved [sometimes its not your fault] Austin Healey 6
AH67 Turn signal problem Austin Healey 3
Michael Oritt Turn signal problem Austin Healey 19
J TR 2/3 turn signal problem Triumph 17
B Turn signal problem. Austin Healey 4
ekamm turn signal problem Triumph 8
MGB922 Turn Signal Flasher Problem MG 1
S Turn Signal Problem Austin Healey 1
J Turn Signal Switch Problem Spridgets 1
Luke_Healey Right side turn signal problem Spridgets 8
M 87 XJ6 Turn Signal/Hazard Flasher Switch Problem Jaguar 16
F Strange Turn Signal Problem... MG 12
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
R Spitfire Turn signal wiring Spitfire Triumph 5
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
N Turn signal flasher?? Spridgets 8
J BJ8 Turn signal help needed. Austin Healey 6
PAUL161 T-Series Turn Signal Flasher MG 8
glemon General Tech Turn Signal Issue Triumph 12
