Spitfire Front wheel bearing seal???
nomad
Don't have a manual for a spitfire but am wondering if the early felt front wheel bearing seals are supposed to be treated with anything before they are installed. Oil?? Grease??
Kurt.
TR3driver
Great Pumpkin - R.I.P
Some of the books say to oil them and squeeze out the excess oil. But I put them in dry on my TR3, seems to work fine. The main thing IMO is to keep grease or oil from getting on the brakes, and adding oil to the seal seems counterproductive.
N
nomad
Thanks, think I'll soak them in 90wt before a good squeeze out. Considering the condition of the disc's a little oil can't hurt!
Kurt.
TR3driver
Rusty brakes will still stop the car. Oily ones won't ...
dklawson
I typically oil them and then squeeze/blot the excess out as Randall mentioned in his first post.
N
nomad
Disc Rotors have no wear on them but plenty of rust and rust pit's. I'm sure i won't leave enough oil in them to cause any harm. I've had 90wt running out of rear drums before I even really noticed a braking problem.
Kurt.
TR3driver
I agree. It's actually pretty common for folks to not notice rear brakes that don't work; but front brakes are a lot more important.
Try stopping the car with the handbrake some time, you'll see what Andy and I mean.
And the least little bit of oil on the rotors will decrease friction and contaminate the pads; requiring the rotor to be thoroughly degreased and the pads replaced.
70herald
When you put the new seals in, note that the felt on most of the seals are way oversized. you can either trim them or verify that they are fully compressed. probably easier to trim them first.
TR3driver
Another option is to check the bearing clearance first, before installing the new seal. Then mark the nut and install the seal, putting the nut back where you marked it. The felt will compress to fit and there is no chance of thick felt upsetting the bearing adjustment.
This process is in at least one of the workshop manuals, TR4 I think.
dklawson
That sounds like a very good practice to compress the felt. On the last installation I did I trimmed them as 70Herald suggested.
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
A Front wheel bearing issues Austin Healey 11
TRclassic3 TR2/3/3A Front wheel bearing adjustment Triumph 5
J TR2/3/3A Outer Front Wheel Bearing Triumph 22
R Front wheel bearing - end float Austin Healey 40
K TR2/3/3A Front hub wheel bearing nut? Triumph 1
KVH General TR Front Wheel Bearing Felt Seal Direction Triumph 9
G TR4/4A Front Wheel Bearing Seal Triumph 19
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
S Problem removing front wheel bearing retaining nut Austin Healey 9
K TR2/3/3A Front wheel bearing grease seal with felt packing? Triumph 4
7 General TR Chirping front wheel bearing Triumph 6
Morris Front wheel bearing installation Spridgets 4
TulsaFred Front wheel bearing grease packing Spridgets 26
mountainman TR2/3/3A TR3 Front Wheel Bearing Triumph 1
D MK2 front wheel bearing adjustment Jaguar 8
T TR6 TR6 front wheel bearing ? Triumph 5
tomshobby specific front wheel bearing questions Spridgets 8
tomshobby front wheel bearing question. Spridgets 9
T Bad front wheel bearing. Triumph 81
H Healey 100 Front Wheel Bearing replacement Austin Healey 4
B TR2/3/3A TR3A front wheel bearing question Triumph 5
T TR4/4A TR4 Front Wheel Bearing Triumph 8
10musketeer Front Wheel Bearing Shims Spridgets 10
D Front wheel bearing adjustment BJ8 Austin Healey 4
7 Putting the front wheel bearing back together. Triumph 0
T Front wheel bearing grease cup removal Austin Healey 1
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
P 100/6 Front Wheel Alignment Austin Healey 10
Z 3000 Front Wheel Bearings Austin Healey 3
K TR2/3/3A Greasing the Front Wheel Hubs? Triumph 9
B Front Wheel Camber Setting Austin Healey 8
Rob Glasgow Front Wheel Bearingsknow Austin Healey 4
K TR2/3/3A Front wheel hub "felt" again? Triumph 2
KVH TR4/4A Front Wire Wheel Hubs Differ from Disc Hubs?? Triumph 5
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
N Front wheel bearings?? Spridgets 8
4tecdog BJ8 front wheel alignment Austin Healey 11
Jeepster Front wheel tracking-toe in Austin Healey 21
pan Front wheel bearings [BN1] Austin Healey 6
BN6_2197 Front Wheel Clearing of BN7 Austin Healey 35
M BN1 front wheel bearings Austin Healey 5
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
C TR2/3/3A Front wheel bearings Triumph 8
T TR2/3/3A Front wheel bearings direction and torque Triumph 1
