Odd Bonnet question
radibob
So over the years I have lost count how many times I have removed the "bonnet" on my 66 Sprite for various repairs. Anyways I noticed last week that the bonnet, where it meets the bulkhead, is about a half an inch lower than the bulkhead. Is this something I can fix by placement of the washers under the two hinges where they attach to the bonnet and is there a trick to where you put the washers to raise the back of the bonnet?
smaceng
Sure why not......seems like it would work. "Lucky" you don't have a bugeye.....to adjust one it has about 4 adjustment. Also, the rubber sealing strip located at the back of the hood opening can also provide an additional height. Scott
Jim_Gruber
Cowl Seal, McGregor's in CA. See their ad in the back of Classic Motor Sports. Best to call, they don't respond well to e-mail but their rubber parts fit and are top notch.
G General MG odd but true! MG 8
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
K TR2/3/3A An odd thought.....vinyl wrap a TR3? Triumph 8
K TR2/3/3A An odd brake question? Triumph 2
TRclassic3 TR2/3/3A Odd observation when bleeding Triumph 5
S Engine or Tachometer Odd Problem Austin Healey 7
PAUL161 T-Series Odd spark plug encounter! MG 10
Y MGB More things that seem odd.... MG 2
Y MGB An odd (and probable long-shot) request... MG 5
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
A T-Series Arkansas MG Odd Lifter Wear MG 12
sparkydave Odd discovery, but still ran OK Spridgets 1
Rut TR6 Odd wheel Triumph 4
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
CJD TR2/3/3A Odd Commission number Triumph 16
steveg Odd problem but it got me home! Austin Healey 9
H TR2/3/3A Odd Speedometer Behavior Triumph 3
J TR4/4A Odd Commission Number Triumph 16
D odd photo Jaguar 6
K TR2/3/3A An odd 56TR3 Commision Number? Triumph 8
R Odd Wiring Failures Austin Healey 14
MisterB MGB New Guy- Looking at Early MGB-Odd one MG 5
AN5Sprite Source For Odd BSW Tap Needed Restoration & Tools 9
K TR2/3/3A Odd looking modified TR3 on Craigslist...saint luis obismo Triumph 24
DrEntropy This tops my "odd cars spotted" personal best Spotted 1
K TR2/3/3A Odd Clutch Failure...Clutch crosshaft bushing goes for a walk! Triumph 6
Flash_Harry MGB '71?? MGB on eBay - a bit odd?? MG 10
J TR4/4A Odd TR4 transmission question Triumph 10
J TR2/3/3A Need an odd part for a TR3 Triumph 4
M TR2/3/3A Tring to find odd TR3 parts again Triumph 24
T photo - odd request Triumph 5
frankenstang57 Sorta odd 1500 question... Spridgets 4
TRclassic3 TR2/3/3A Odd TR3A suspension issue Triumph 11
D Odd pair today Spotted 17
A Ignition rotor recommendations - odd failure Austin Healey 11
texas_bugeye Odd rear suspension Spridgets 8
JPSmit Odd week for odd cars Other Cars 34
BoneIdle Odd squealing in 4th gear MG 2
Sherlock A rather odd truck/motorhome Other Cars 0
B Spitfire odd noise from Spitfire rear Triumph 5
mikecyc72usa So far so good, but now an odd question Triumph 2
JPSmit odd screen in Mozilla FORUM Navigation Questions 5
Got_All_4 TR2/3/3A TR3A odd windshield studs needed Triumph 4
jvandyke odd noise from the rear [of the car] Spridgets 8
R Odd problem Spridgets 3
swift6 Odd Triumph Logo... Triumph 14
jhorton3 Odd Piece In Spring Spridgets 8
v8mgbal odd structural question Spridgets 6
