wanted: hardtop for a 1963 bj7
maxwedge5281
looking for the above for 1963 healey that i recently purchased....any leads appreciated. also, if anyone has a pic or two of a bj series with a hardtop in place i would appreciate posting of the picture. thanks, maxwedge
HealeyRick
Works hardtops for the BJ7 fit only the BJ7 and BJ8 and require removal of the convertible top for fitment. In my view, they are quite handsome and add to the appearance of the car. See Steve Thomton's Rallye Replica here: https://stevesaustinhealey.com/inde...ent&view=category&layout=blog&id=10&Itemid=11 However, they are rare and expensive (probably around $2,000 for one needing work) A reproduction is available from Nical Engineering in the UK https://www.nicalengineering.co.uk/austin_parts.html. Price is spendy and you'll have to play around with it a bit to get it to fit correctly. Another alternative (and nowhere near as handsome, IMHO, is the Parrish Plastics/ Smoothline one available here: https://www.smoothline.com/austin_healey.php They show up used pretty regularly for around $300.
maxwedge5281
maxwedge5281
thanks rick. i expected as much. after reviewing the pics where does one find the fender vents and are they effective for removing air from the engine compartment. there was a similar red car with white hardtop at eurofest yesterday at tne bmw plant near greenville sc.
HealeyRick
Here's one source: https://www.britishcarforum.com/bcf/showthread.php?75988-big-healey-fender-vents Randy says the vents work. Geoff Healey said they didn't. :indecisiveness::indecisiveness::indecisiveness: Kind of like the question whether the louvers on the 100M bonnet do anything. They sure look like they should help and I can't imagine they'd hurt. And I think they are must-haves if you have a hardtop.
bob hughes
I had the same discussion with my Healey man last week 'cos I like the look of the fender vents and fancy fitting some down the line, he recons that the fender vents are not as effective as a louvred bonnet. I can see that a louvered bonnet would be very effective - hot air rises and all that.
:cheers:
vette
maxwedge5281
maxwedge5281
i just sent an email and looking for a reply. i will post if i receive an answer.
Tproject
If you want to see a Parrish top for a BJ7 I have one in my garage. We could place it on my healey so you could see the fit. I live in Seneca SC on lake Keowee.
maxwedge5281
maxwedge5281
thank you for the offer. i looked up parrish tops and see that they are a bit different from the factory. much smaller rear window. is your top for sale?
John Turney
:cheers:
BMC tried the louvered hood and it didn't work. That's why they went with, and stayed with, the fender vents. I can tell you that there is a lot of hot air coming out mine when on the road.
Tproject
After a discussion with my wife I would consider selling the top. Do you belong to the Foothills British Car Club ?
Beyond the top since we both have BJ7's we could be of mutual help. I am an original owner.
HealeyPassion
FWIW I agree with John.... the works tried the louvered hoods but they are in a high pressure area and they don't evacuate the heat from the engine compartment.... except when sitting still. I had a louvered hood on a 100/6 when living the Texas, when you stopped at a stoplight the heat billowed out of the louvers. The works changed to the side vents on their rally cars and stayed with them from then on because they do work. Cheers, Steve
Patrick67BJ8
I wonder if anyone with the side vents has ever installed radiator type of fans to remove the heat? It might be very good thing to have at idle.
maxwedge5281
maxwedge5281
i have emailed pete farmer and have not gotten a reply. the parrish tops are kinda awkward looking for the healey lines. i also looked up nicale engineering. their website and attached pricing shows a price of about 1800 pounds... if i understand the currency symbol and the conversion to us dollars adds up to about 3700-3800 dollars for a complete top for the bj7/8. 'course shipping and associated costs would probably add at least another 500 to 1000 dollars. i have asked for more definitive pricing but have not yet received a reply....as someone said early on....pricey?? there is an early factory hardtop shell on ebay now with no hardware, trim etc...but parts do appear to be available at either of the above to complete!
Patrick67BJ8
Hardtops like the Parrish style fit over the rear surround chrome strip and actually sit on the painted surface. The Factory style Tops such as Farmers and Nical sit on the chrome strip but you will have to fit the hardtop to the car. That means trimming the plexiglas rear window and some fiberglass trimming. Steve Thomton installed a Nical top and posted about 160 pictures on this site, https://stevesaustinhealeyalbums.shutterfly.com/ (hope I got that right) about the install. It's not easy but with patience and care you sould be able to do it.
maxwedge5281
maxwedge5281
there is a factory hardtop for sale in chico calif craigslist for bn4 bn6 and bn7 cars as well as a very nice appearing rear shroud. might check it out . it needs a rear glass and paint. has latches. no affiliation...
Jeepster
Once a new hardtop is fitted to your car, how long does it take to take it on and off again?
is it a sensible option to take the top on and off to match the weather?
If so I may consider fitting a hardtop and using a tonneau for nice days. This way I could do without the expense and hassle of the folding top.
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
H Wanted Wanted TR6 Hardtop Triumph Classifieds 3
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
K TR6 TR6 late rims wanted Triumph 0
B Stainless Steel Exhaust System Wanted Austin Healey 5
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
T Wanted Wanted : MGA rear deck cover MG Classifieds 0
T Wanted: Early BN1 Sidescreens Austin Healey 2
M Wanted WANTED...New TR6 piston set. Triumph Classifieds 2
M TR6 WANTED....Nural pistons for TR6 Triumph 1
volunteer Wanted: Brake Master Cyl. Repair Kit for Daimler DS420 Other British Cars 18
M Wanted Wanted: Inoperative J Type OD Solenoid! Triumph Classifieds 2
T TR6 Opinions wanted Triumph 29
S Wanted: AH Concours Registry Guide Austin Healey 2
shadowfever MGB MGB intake wanted MG 2
D Wanted Wanted Triumph Classifieds 0
Joel Lester Wanted Wanted - TR6 steel wheels Triumph Classifieds 6
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
M MGA RHD rack and pinion wanted MG 19
T TR2/3/3A Wanted - Picture of TR3A original firewall layout Triumph 5
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
J Wanted Help Wanted -SE WI Other British Classifieds 1
J Help Wanted - SE WI Racing 2
D Wanted: Austin Healey Classifieds 5
D Wanted: Austin Healey Classifieds 0
35 Siddeley MGB MGB Armstrong shock dimensions wanted MG 0
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
Pythias MKIII Springs WANTED Spridgets 8
J Bugeye seats wanted... Spridgets Classified 0
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
