Top Trunnion Bearing Kit
bob hughes
Have any of you guys put in the bearing kits into you top trunnions to replace the thrust washers?
What is the feed back - they say that it vastly improves the effort required to turn the steering wheel, I can see that it should, is it true.
:cheers:
5
57_BN4
I have them and not convinced there is that much of a difference although I only have driving in a BN2 to compare with. Slightly easier to turn when parking perhaps but nothing to write home about. Might be more noticeable if you have wide tyres.
Biggest change I noticed is when working on a Mk2 steering system with the needle-roller peg as opposed to the staked in one on the earlier cars. That definitely makes a difference in the steering effort. Andy.
steveg
I have the bearing kit with 185/70 tires and agree the difference is not really noticeable.
"Vastly" way overstates the difference. If the thrust washers were dry there would be more friction so that would mean more of a difference.
dougie
They made a difference for me on my vintage racer.
B
bob hughes
Thanks guys
I appreciate your comments, need to adjust the existing system so thought that I would update at the same time. May just leave it for now and add in a shim or two.
:cheers:
I've installed two (2) sets, but have never road tested any; both were supplied with loose stub axles/kingpins
richberman
Randy,
You are welcome to come up to Philadelphia any time you get tired of Florida to road test on of the sets.;):driving:
rich
P.S. I was surprised at how nice the steering was, but then I have nothing else to compare it to not having driven an original.
J Top Trunnion Bushing Fit Austin Healey 9
catfood Top trunnion pin removal. Austin Healey 4
R BJ8 Top Trunnion removal Austin Healey 8
H top trunnion too tight Austin Healey 3
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
S TR6 Soft top material Triumph 10
Sarastro TR4/4A Convertible top installation problem Triumph 12
A TR6 TR 6 Soft Top Triumph 4
D BJ8 Top Installation Detail Austin Healey 3
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
B TR6 TR6 convertible top frame Triumph 0
zoohow BN4 Top Frame Installation Austin Healey 1
L Do you have a picture of these convertible top details? Spridgets 4
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
Frameman 1949 Soft Top Webbing Austin Healey 2
Overdrive45 Convertible Top Cover Fit Austin Healey 6
D Top installer recommendations NYC tri-State area Austin Healey 0
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
S For Sale FREE HARDTOP.. top is in Palm Springs, Cal. Call Bob ,562 400 5983 MG Classifieds 1
E Spitfire '69 Spitfire hard top Triumph 2
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
Popeye TR4/4A Tonneau or top cover? Triumph 12
7 Top, hard Triumph 0
JPSmit Today's top tip - Rain X Restoration & Tools 3
Popeye General TR Old robbins top in box Triumph 7
KVH TR4/4A Closing the Soft Top Triumph 11
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Bayless How does '67 Sprite top attach to body? Spridgets 3
D Top Door rubber and fuzzy seal Spridgets 5
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
Donald1107 TR2/3/3A Soft top Triumph 14
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
luke44 TR2/3/3A Tr3 top - corner fastener Triumph 4
N MGB Convertible Top Frames MG 7
roscoe New / old hard top Austin Healey 16
nevets BN6 Soft Top Webbing Austin Healey 2
R BUGEYE SOFT TOP FIT Spridgets 2
AngliaGT For Sale Two Piece Top Frame - MGB '62 - '70 MG Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
EWD TR6 Top Install Triumph 3
B TR2/3/3A Hard Top Part Triumph 2
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
JamesD BJ8 Top Frame Bumpers Austin Healey 12
