sundown
Thanks guys for the fuel filter issue. I check the fuel pump seems to be working fine. I can't seem to get that sluggish movement figured out it almost feels like the car is doing the cha cha.I double checked the ignition timing the dizzy gap is good I did start fussing with the carb mixtures on the 175cd zs It seems even when i completely rich them out when i lift the piston it almost stalls as if they are too lean ? Thanks
