TR2/3/3A Tr3A Oil Priming
aserftr3
Hello all, I have just finished rebuilding my Tr3 engine and am attempting to prime the oil system. I made a spade tip rod and chucked it up into a drill. spinning it counterclockwise ate about 750rpm i get oil to the block galleys and through the pressure tube. but no oil is appearing at the top of the head! none at all through the rocker pedestal hole and none at the back aux oil in hole. the block has been cooked during the rebuild. could i have put the head gasket on upside down? It is the steel shim type. what could be causing the lack of oil? Also is there any way to probe the pedestal hole?
thank You
Geo Hahn
The original style gaskets could be installed either way -- they were drilled for the oil passage in both corners. Don't know about the steel shim version.
But a more likely issue may be the position of the rear cam bearing which, as I recall, has a hole that must line up with the oil passage. Do you recall attending to that during assembly?
CJD
To use you spinner without the distributor mounted, it is likely opening the oil gallery below the distributor, so you will get flow, but never get any pressure or altitude.
TR3driver
Great Pumpkin - R.I.P
The oil flow to the head is "metered" by the camshaft. Most likely it will start flowing once you are spinning the engine.
It is possible that the rear cam bearing is installed wrong; it is the only one of the 3 that has a front and back even though all the inserts are identical. But I don't see any way to check, short of pulling the camshaft out.
You can remove the pedestal from the rocker shaft and look through the passage. But the shaft has to be oriented correctly or the screw wouldn't go in. Be sure to clean thoroughly and use a drop of Loctite on the screw, they have been known to back out.
To check the passage through the head, remove the plug at the LR corner. Put a piece of wire down through the hole under the pedestal, then another through the hole under the plug. If they touch, that part of the passage is open. To check the third leg, you'll have to pull the head and poke a wire from the head gasket side, then look down the hole to see it.
TR4nut
Yes, that's why I'd vote to crank the engine now that the main bearings have been primed up - with the cam moving you should see some oil come up. If not, it would mean some tricky checking to see if that bearing is in properly - especially if the engine is in the car.
TR3driver
Actually, I believe the TR2 workshop manual shows a gasket with only one oil hole, and talks about how it has to be installed the right way. But I agree, I've never seen one that lacks the duplicate hole (so it can be installed either way), including the "shim steel" gaskets I got from BFE.
A
aserftr3
ok so very very valuable input! Thank you all! My first step was to determine if the head passage was open, it is. next i was forced to pull the head and wired check the hole down the block and into the cam bearing, that was also clear. while turning the oil pump and removing the rear most galley oil plug I saw that there was in fact oil to the back of the galley. now i had to pull the cam out. so its out and i do believe that my cam bearings is either installed wrong by my machinist, or possibly manf. wrong. in the rear most bearing there is a hole to the head, a hole for the set screw, a hole to the main bearings, but there is NO hole from the oil galley to the cam bearing!! is it possible to instal the bearings out of sequence? I saw that Randall noted the rear bearing is the only dirrectional one of the 3 inserts.
A
aserftr3
ok just to clarify. can someone tell me route the oil takes through the engine. Does oil travel from the pump into the galley, then into the center cam bearing. then down to the crank. it then travels up to the other cam bearings from the mains. then to the head via the rear most bearing and finally back down to the pan by gravity? If that is the proper sequence then i have had that backwards in my head! :rolleye:
TR3driver
I believe there is a direct passage from the gallery to the main bearing, plus another passage from the gallery to the camshaft. Don't recall the exact configuration offhand, whether the two passages tee together or each connects to the gallery directly; but the oil to the main does not go through the cam bearing at all.
Otherwise, your description is correct. The oil to the rocker shaft flows "through" the rear cam bearing, carried from the inlet hole to the outlet hole by the action of the cam turning and the grooves in the cam journal. Thus the flow to the head is very limited and has almost no pressure at all. I believe this was a deliberate design feature, to limit the amount of oil on top of the head.
Some folks like to install a bypass line that supplies full gallery pressure to the head, but IMO it results in way too much oil up there. I make it a habit to start the engine with the cover off after adjusting the valves, to double-check that the rockers are getting oiled. When I tried that with the bypass line installed, it literally painted the hood with oil! (I only tried the bypass line on that engine because someone apparently installed the rear bearing wrong and there was no oil flow to the head. The cure proved to be worse than the disease :smile: )
A
aserftr3
Thank You! I believe that I now understand It. So the oil to the front two and the rear cam bearings is supplied from the mains not the gallery! Now i have to try to prime it with the cam out whilst turning the crank. seeing if oil surfaces at the front 2 and rear bearings!
A
aserftr3
Tried priming and oil is now to all of the bearings! I suppose the lesson learned is to rotate the engine whilst priming. Also to prime, if at all possible, before installation of the cam!
A TR2/3/3A A rigged TR3a oil filter housing Triumph 8
C TR2/3/3A Oil Catch Can TR3a Triumph 8
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
D TR2/3/3A '59 TR3A oil pan leak Triumph 12
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
Tinkerman TR2/3/3A Major oil leak from original oil filter system 1960 TR3A post 600000 series Triumph 3
B TR2/3/3A TR3a oil line at block question Triumph 5
mgbmedic TR2/3/3A oil pressure line routing TR3A Triumph 4
S TR2/3/3A TR3A Oil Pressure Gauge Leather Gasket ?? Triumph 11
V TR2/3/3A TR3A Front Oil Seal Triumph 3
H TR2/3/3A Oil Sump Thread size TR3A Triumph 4
H TR2/3/3A TR3A Oil Leak Triumph 4
M_Pied_Lourd TR2/3/3A TR3A Oil Cooler Opinions Triumph 5
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
ekamm TR2/3/3A tr3a transmission oil preferences? Triumph 4
rlandrum TR2/3/3A TR3A Low Oil Pressure Solved Triumph 19
T TR2/3/3A 1960 TR3A oil leak issue [imagine that!] Triumph 5
H TR2/3/3A TR3A Oil sump drain plug [Thread zize] Triumph 2
rlandrum TR2/3/3A TR3A Timing Chain Oil Slinger Triumph 3
B TR2/3/3A TR3A Oil Gallery plug Triumph 6
NutmegCT TR2/3/3A oil pressure TR3A Triumph 5
NutmegCT TR2/3/3A original oil filter, TR3A Triumph 6
jdubois TR2/3/3A Should be oil in a TR3A steering rack, right? Triumph 16
TRclassic3 TR2/3/3A TR3A steering box oil Triumph 10
NutmegCT TR2/3/3A TR3A oil gauge stuck Triumph 11
J TR2/3/3A Oil change on TR3A Triumph 5
S TR2/3/3A TR3A oil by-pass to cylinder head Triumph 11
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
