Parker
I recently got my car back from a full repaint and body panel restoration. Prior to painting, I'd disconnected and removed all chrome & lights. The repaint included boot and bonnet areas. I've reconnected all of the bullet connectors and have reinstalled the lights, using light emery paper and dielectric greas on all contacts. The following things work just fine: horn, wipers, blower, brake fault light, directionals, brake lights, igntion indicator,and high beam indicator/high beam headlights but ONLY when I activate the "flash" function using the "tree." The following things don't work: headlights, side marker lights, license plate lights.
I get full power coming into and going out of the dashboard's headlight switch. I know the headlights are properly connected because they go on when I use the "flash" function. I've heard that a repaint can cause problems with grounding, so I took extra care to clear the paint away from the license plate light's ground post. I checked the owner's handbook for any information on which of the fuse controls the headlights, but can't find the headlights specifically assigned to a particular fuse on the block nor any inline fuse for the headlights.
It's probably something simple... but after a few hours of methodical messing around, I'm stumped. Does anyone have any thoughts on what I should be doing/checking? Thanks... Parker
