General TR TR3B Cylinder Head
cjimj
I'm in the process of restoring my TR4A, which has an untouched TR3B cylinder head (except for a valve grind in 1977). I was getting ready to haul it off to the machine shop to have the combustion chamber modified and ports all matched when it occurred to me that I have something no one can readily buy anymore and that perhaps someone doing a full, 100% accurate restoration might have more of a need for it than I.
While I'm not particularly looking to make any money off it, I'd need enough to buy a reproduction head.
So then my question is, how likely is it that there's a purist out there who's ready and willing to shell out at least $2,600 for a used, but otherwise original, TR3B head?
Just thought I ought to check BEFORE casually wasting all that untouched originality.
Jim
CJD
I picked up 3 for $150...plus three tranny's. Be willing to sell them for $1300 each.
martx-5
What's the difference between a 3B head and a 3A head???
TR4nut
Evidently about $2400! Seriously I'm not sure there was anything unique about the 3B head. TSF cars probably were the same as late 3As, and TCF cars would be the same as early 4s - and I'm not sure if there was a difference between the two.
luke44
So then my question is, how likely is it that there's a purist out there who's ready and willing to shell out at least $2,600 for a used, but otherwise original, TR3B head? Jim
Hi Jim and welcome aboard - I think the above posts have already given a good sense there is not much market for the heavy iron parts - heads, blocks, trans, diffs etc. From my perspective I would say it is generally agreed in the TR2/3/3A/3B world there are early (low port) and late (high port) heads. Being as all but the earliest cars had the late port, there is more than enough supply in the used parts market.
The TRA does note a "Late High Port Head" on the 3B, essentially a TR4 head, which looks functionally interchangeable with the other high port heads. According to TRA, it is distinguished by "a flat crown on the front most hump on the head, and the flat area may have a serial number".
Your market for such a head therefore would be limited to a) those who have a car that came so equipped and b) does not already have this head and c) wants to spend the kind of money you want out of it (my sense is this would be a very small group). So, my advice is to haul it off to the machine shop and do your thing. Oh, pictures always welcomed! Again, welcome aboard and tell us about your project.
martx-5
You know, I forgot that Teri Ann's site has all the info on the TRactor engine cylinder heads. However, after reading it, it seems that the late 3A, 3B, and early 4 heads is still a gray area, although they are definitely different from the earlier high port heads.
https://www.tr3a.info/FAQ_heads.htm
C
cjimj
Thanks for the response, I'm not looking to get anything for the head, it works just fine for me. In fact, it'd be an inconvenience to me to bother with going through the gyrations to trade out the head so someone else could benefit from its condition. But in case it had some value to someone else that I wasn't aware of, I figured I should at least ask before hacking away on an otherwise untouched head. Thanks again.
T TR2/3/3A TR3b Master cylinder push rod clevis Triumph 2
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
AngliaGT TR2/3/3A Value of a One Owner,Excellent Condition TR3B ? Triumph 12
glemon TR2/3/3A TR3B Triumph 10
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
P TR2/3/3A TR3B SU carbs Triumph 10
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
P TR3B Coil Issue? Triumph 7
P TR2/3/3A TR3B Panel Light Switch Triumph 20
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
af3683 TR2/3/3A TR3B Oil Drain Plug Triumph 10
J TR2/3/3A TR3b Tyres Triumph 6
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
W TR2/3/3A TR3B ‘TCF’ on BAT Triumph 10
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
tr3guy TR2/3/3A Late TR3A, TR3B windshield assemply Triumph 5
K TR2/3/3A Windshield stanchions on a TR3b - guide plates?? Triumph 13
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
M TR2/3/3A After Market Oil Filter - TR3B Triumph 8
M TR2/3/3A Technical Assistance Needed - TR3B Carb Adjustment Triumph 5
D TR2/3/3A Best TR3B seats - repair or replacement? Triumph 11
K TR2/3/3A Broken exhaust manifold TR3b Triumph 13
D TR2/3/3A TR3B Tire sizes? Triumph 10
S TR2/3/3A 155/15 Vredestein Sprint Classic on a 4.5" Wire Wheel as TR3B Spare? Triumph 6
J Restoring a '62 TR3B Restoration & Tools 2
M TR2/3/3A TR3B Door Cables Triumph 5
M Door Cables - 62 TR3B Spridgets 1
B TR2/3/3A Are these seat slides for a TR3B? how do you paint them? Triumph 8
B TR2/3/3A carpet snap questions tr3B Triumph 1
B TR2/3/3A TR3b lower door seal question Triumph 3
B TR2/3/3A tr3b center exhaust hanger Triumph 3
B TR2/3/3A steering box seal replacement TR3B Triumph 4
af3683 TR2/3/3A TR3B Exhaust Manifold Gaskets Triumph 15
af3683 TR2/3/3A TR3B Signal Flasher Problem? Triumph 2
B TR2/3/3A where to buy oversize thrust washers for TR3B? Triumph 16
B TR2/3/3A Identify the Mystery Bolts from TR3B front and interior Triumph 2
T TR2/3/3A TR3B fuel gauge Triumph 3
T TR2/3/3A TR3B stanchion to frame scew size Triumph 8
T TR2/3/3A TR3B alternator leak Triumph 4
T TR2/3/3A TR3B steering wheel cover Triumph 25
T TR2/3/3A TR3B VB windshield Triumph 11
M TR2/3/3A TR3B Front suspension Triumph 5
T TR2/3/3A TR3B gas cap Triumph 0
T TR2/3/3A TR3B steering column felt bushing Triumph 2
V TR2/3/3A TR3B Engine Oil Triumph 8
af3683 TR2/3/3A TR3B Rear Handbrake Cables Triumph 8
