Too Good to be True!!!
LarryK
My "Hemmings" catalog came at 3:00PM today, looked in Jaguars. 57 XK140 Roadster, mint condition 21,000 miles, $18,000. Dropped everything. Too good to be true????? Backed up to trailer and called. Yep! Already sold for $150K two weeks earlier by on-line catalog, misprinted in printed catalog. OOHHH! WEELLLLL! 4-letter word.
LarryK
LarryK
He said he had 14 calls in a two hr. time frame. But, you have to call, what if?
PC Dang, that was too good to be true... Restoration & Tools 3
John_Mc Two/too good to be true? Triumph 5
W TR2/3/3A Too good to be true? Ebay tr3 Triumph 14
77MidgetMkIV I knew it was too good to be true: carb woes now Spridgets 3
Dave_H TR2/3/3A 1961 TR3 4 Sale - Too good to be true? Triumph 4
J TR4/4A Exhaust a tad too loud... Triumph 2
jfarris Message too long error FORUM Navigation Questions 8
mctriumph TR2/3/3A The concept of too many Triumph 8
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
R For Sale Conundrum - Too Many Bugeyes Spridgets Classified 1
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
M TR6 76 TR6 Brakes too tight Triumph 10
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
M 1275 too high? Spridgets 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
JPSmit Pre-War Is it too early to write Santa? 1933 MG J1 MG 13
CJD General TR Too Rude Triumph 13
AUSMHLY 64 front end too high Austin Healey 14
S TR2/3/3A OMG problem—the doors are too tight Triumph 12
T TR2/3/3A Turn Signals Blinking too fast Triumph 2
M Fat Feet hitting too many pedals Austin Healey 23
DrEntropy MGB Differential with too much lash MG 5
Got_All_4 TR6 TR6 engine rebuild. Too tight? Triumph 23
S TR2/3/3A New shocks too short? Triumph 7
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
HalLucy Post-War Other Renown - Idle too fast Triumph 5
TRMark TR4/4A Seal too large for Surrey backlight Triumph 8
J TR4/4A Too hot to drive a convertible Triumph 14
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
TomMull TR2/3/3A New Top Too Tight Triumph 14
K Too lean? Austin Healey 2
Jim_Gruber What Now, new gas tank filler neck is about 1/2-3/4" too short Spridgets 19
warwick-steve How low is too low? [spring question] Austin Healey 19
Marla TR4/4A Carbs too lean? Triumph 11
D TR4/4A flywheel bolts maybe too long Triumph 15
kennypinkerton MGB Are my wheels too far gone? MG 8
wkilleffer MGB Fitting a new top to a 74 MGB- how tight is too tight? MG 23
3798j Boomers Too Old for Sports Cars Other Cars 8
tr3guy TR2/3/3A New Wheel Cylinder too large Triumph 7
A rear brake drum too tight after rebuild Austin Healey 3
Jim_Gruber Bullet Connectors are too large to fit Tail Lamps on BE Spridgets 8
Got_All_4 TR2/3/3A Tr6 a type overdruve in my tr3 too long Triumph 10
TomMull Air Compressors, how much is too much? Restoration & Tools 7
Trevor Jessie Waaaay too much body roll Spridgets 14
Rut MGB Too many cars MG 31
KVH General Tech Transmission Drain Plug Too Tight? Triumph 5
T TR2/3/3A Is 5.5 lbs too much fuel pressure? Triumph 9
