Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment
timtucker
Howdy, just joined so this would be my first post. I have a 1979 Triumph Spitfire 1500 with 42000 miles on it. I noticed the rear wheels are angling in at the top at a good 20 to 30 degrees and that there is wear on the inside tread. When I put it up on the lift the wheels (rear only) angle outwards at the top. One person suggested it just needs new shocks, but I'm not sure that is the answer. Anyone have an answer for me on this? Thank you
Trevor Triumph
Could be shocks, but consider the spring. The usual suspects have replacements. There are shops that can re-arch the spring, too. Another thought is that if the car was raced/ autocrossed the owner may have adjusted the spring to provide that kind of camber. Most times, however, the camber is a matter of a few degrees, not twenty. Some drivers have used air shocks to eliminate the camber, but air shocks tend to cause stress fractures in the body and hence stress cracks in the gas tank.
Welcome to the site. There are a lot of people that know a lot about a lot! In others words, not just British cars.
T.T.
T
timtucker
thank you for the input...i will try to find a local shop that can check the spring arch......i did notice shimms placed on the spring arch (at least I think thats what they are) I may replace the shocks first just in case they look original
luke44
Shocks are not the problem, save your money.
I raced a Spit (ultimately being very successful at it) for several years, and can speak fairly knowledgeably about what you are seeing. The Spit rear end is a simple swing axle design, which has a lot of inherent design flaws. (early Corvair anyone?). The simple and best fix is to increase the static rear negative camber (exactly what you have).
The early standard race setup was to increase the negative rear camber (so the wheels would angle inward and are closer together at the top than the bottom) to prevent rollover and rear wheel lift under hard cornering. (the wheel would literally tuck in under itself going over to major positive camber - the same thing you see when the car is on a lift). To prevent this going too far in under load, a camber compensator - a flat bar, was also then attached below the diff to the 2 uprights, limiting the amount of tuck under. All in all, a bad design and a compromise fix.
Later designs (like your 1500) used a significantly modified spring which achieved the same result, but was much more reliable (and cheaper for Triumph).
The static sitting position of this is exactly what you are seeing.
Under load, this negative camber does flatten out, and in cornering it all works to the put maximum flat tire contact patch on the road. My guess, like TT noted, is the arc of the spring was adjusted a bit more - perhaps for auto crossing or just spirited driving.
While tire wear on the inside may increase, it may be nothing more than normal wear, and trying to fix this will likely decrease the handling - so it's a big trade-off - the remedy may be worse than the disease. if it were mine, I'd live with it and thank the previous owner for fixing this design flaw. Buy some new tires, don't worry about the wear, and enjoy your sporty setup.
Here's a shot of my early car in a hard right turn - what it can look like if not dealt with properly...
Here's a small picture of what can happen if you don't live with the negative camber you have now and go too far the other way...
The only other adjustment to check is rear toe - this is adjusted with shims where the upright "radius" rod mounts to the body. But this rarely needs adjustment unless the car gets hit.
You may want to check out these links as well. A picture of a Herald (same car underneath as a Spit) also really showing the point I'm making.
https://herald-tips-tricks.wikidot.com/rear-suspension:jacking-and-tuck-under
https://www.fairpoint.net/~herald948/database/cc/
Good luck with it, and welcome aboard. The Spit is a great little car.
T
timtucker
WOW!~ thats a relief! it handles great! and I was just worried when someone brought it to my attention. Love the little red devil and it all documented etc....42K miles is minimal and I even have the hard top for it. Thanks for your input and I feel much better now! The interior tire wear is minimal and I just didnt want to make a matter worse by driving it if it was in trouble. Will be posting other issues I have found very soon......Like the durn seatbelt buzzer that wont shut off???
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
N For Sale 1979 Triumph Spitfire Triumph Classifieds 2
T Spitfire 1979 Triumph Spitfire 1500 Triumph 3
B Spitfire Sellng my 1979 Triumph Spitfire 1500 Triumph 1
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
C Triumph colors from PPG book 1979 Triumph 2
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
Morris For Sale Fuel Injected 1979 MG Midget Spridgets Classified 0
wingsandwheels For Sale 1979 MGB for sale MG Classifieds 0
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
wingsandwheels MGB 1979 MGB coil w/ altered wiring MG 6
B Spitfire 1979 Spitfire Emissions Triumph 4
D 1979 Spitfire Spotted 0
R Spitfire Lbs of compression Spec for 1979 Spitfire. Triumph 3
N MGB 1979 MGB exhaust replacement. MG 1
Andrew Mace Wedge 1979 [Fed.] TR7 fuel tank questions Triumph 6
A MGB 1979 MGB Flasher Big Headache MG 3
AngliaGT 1979 B Owner's Manual MG 6
T MGB 1979 MGB with Weber carb MG 7
R MGB Testing temp sending unit 1979 MGB MG 6
startech47 1979 Midget rear hub bearing nut torque spec. Spridgets 3
M zenith float adjustment 1979 MG 1
ronzet Needed EGR valve for a 1979 MG Midget Spridgets 20
H Valve cover paint 1979 Midget Spridgets 8
startech47 1979 Midget Wheel Bearing Numbers Spridgets 0
P 2 midget problems 1979 help! Spridgets 2
C MGB 1979 MGB Zenith Stromberg Carburetor MG 3
B Have Available for Midget [Its from a 1979]... Spridgets 0
B 1979 Midget Wiring Diagram, Harness, etc. Spridgets 6
PATR8 1979 MG for sale MG 1
B 1979 MG Midget Headrest available..just pay shipp. Spridgets 2
1979Roadster 1979 OVERDRIVE TRANNIE MG 3
B Help with 1979 Radiator Spridgets 19
1979Roadster MGB 1979 MGB SITTING FOR 17 YEARS MG 12
B 1979 MG Midget Headrest Available! Spridgets 3
C MGB 1979 MGB steering wheel socket? MG 1
C MGB 1979 MGB door mirrors MG 4
B My 1979 Midget...before and on its way to rebirth! MG 10
kyreb1862 Wedge 1979 TR7 Roadster Automatic Triumph 0
startech47 Static timing a 1979 Midget Spridgets 4
X 1979 LE console removal MG 9
S 1979 rear shock conversion kit worth it? Spridgets 10
S White disk in drivers seat 1979 Midget? Spridgets 3
M Spitfire Removing the emergency brake grip;1979 Spitfire Triumph 0
I 1979 wont go into reverse MG 10
H Geoff Healey @ Encounter 1979 - 8trac tape Austin Healey 9
