Turn signal problem
AH67
Hi all,
The left turn signal is erratic on my 62 BT7. Trafficactor is working fine. The right turn signal blinks fast and the left has blinks slow and sometime not at all.
Is this a flasher or relay problem? Any advice would be greatly appciated.
GregW
Platinum
I would lean towards the relay. Though a poor ground could be the culprit too.
rjc157
start with the connections see what happens ,then i would go with the flasher its the cheapest way to go
healeyblue
Fast or slow is usually a resistance difference. You need to verify if all the bulbs are actually lighting and are they all the same wattage. If some lights don't light or sometimes not at all, then I would point to the signal relay on the fender well.
JIM
M Europa turn signal problem Lotus 7
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
M Turn signal problem Austin Healey 3
Brinkerhoff T-Series MG TC turn signal problem MG 1
B TR2/3/3A Another turn signal problem Triumph 5
sim 58 sprite turn signal Problem Spridgets 6
L Turn signal problem solved [sometimes its not your fault] Austin Healey 6
S MG... Turn Signal Problem Spridgets 19
Michael Oritt Turn signal problem Austin Healey 19
J TR 2/3 turn signal problem Triumph 17
B Turn signal problem. Austin Healey 4
ekamm turn signal problem Triumph 8
MGB922 Turn Signal Flasher Problem MG 1
S Turn Signal Problem Austin Healey 1
J Turn Signal Switch Problem Spridgets 1
Luke_Healey Right side turn signal problem Spridgets 8
M 87 XJ6 Turn Signal/Hazard Flasher Switch Problem Jaguar 16
F Strange Turn Signal Problem... MG 12
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
R Spitfire Turn signal wiring Spitfire Triumph 5
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
N Turn signal flasher?? Spridgets 8
J BJ8 Turn signal help needed. Austin Healey 6
PAUL161 T-Series Turn Signal Flasher MG 8
glemon General Tech Turn Signal Issue Triumph 12
