Results 1 to 11 of 11
Thread: Protecting bonnet from rocks
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Member dcoplan's Avatar
    Join Date
    Aug 2012
    Location
    Los Angeles, CA
    Posts
    38
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Wondering if any of you do anything to prevent rocks from chipping the front of the bonnet. A bumper is an option but I really like the look of the car without one. Is there some sort of protective transparent film that can be put over it that won't harm the paint if/when pulled or a driving bra?
    Dan
    1960 Bugeye Sprite AN5L 38667
  2. #2
    Yoda Trevor Jessie's Avatar
    Join Date
    Nov 2003
    Location
    Louisville KY
    Posts
    8,086
    Thanks Thanks Given
    2
    Thanked in
    Re: Protecting bonnet from rocks
    There is a clear vinyl sold just for this purpose. However, I prefer to ignore the chips and drive on. My life is too short to worry about rock chips ... I'm here to have fun.
    _____________________
    1970/2 MG Midget
    Datsun 5-speed
    Future Fuel Injection Turbo Project
    _________________
    1958/9 Sprite AN5L/1499
    1275 SuperCharged
    Datsun 5-speed
    _________________
  3. #3
    Jedi Knight JodyFKerr's Avatar
    Join Date
    Feb 2008
    Location
    Sultan, WA
    Posts
    1,176
    Thanks Thanks Given
    Thanked in
    I agree with Trevor. Additionally, the stuff starts to look funky after a couple years. That being said:
    https://solutions.3m.com/wps/portal/...VentureShield/
    Website: http://www.theymightberacing.com/
    1953 Studebaker Champion, 1960 Austin Healey BT7, 1969 Austin Healey Sprite MK IV, 1970 MG MGB, 1974 Jensen Healey MKII (2), 1978 Triumph Spitfire (2), 1980 Triumph TR7 Spider, 1981 Triumph TR-8 (driver-ish)
    Farm: http://www.ScottishThistleFarm.com/
  4. #4
    Jedi Knight AN5Sprite's Avatar
    Join Date
    Sep 2011
    Location
    The Pine Tree State
    Posts
    1,076
    Thanks Thanks Given
    Thanked in
    I wouldn't risk tempting fate. Put the vinyl on to protect against pebbles - get backed into by a Suburban.
    Steve C & the Tunebug
  5. #5
    Yoda RickB's Avatar
    Join Date
    Mar 2007
    Location
    Snoqualmie, WA USA
    Posts
    5,180
    Thanks Thanks Given
    Thanked in
    My rattle can paint, although it was advertised on the cans as being "automotive paint" has chipped very badly.
    On the one hand it was cheap.
    On the other hand my bonnet is flecked with a lot of little spots from rocks.
    When I paint it again I'll use my compressor and HVLP gun.
    Does a place like Eastwood have a paint I can shoot that will be a little tougher (or a lot tougher would be nice)?
    '80 MGB roadster - pageant blue with Overdrive
    '73 RWA car + rust free tub and parts - going to build an Arkley SS!
    '78 Midget - Datsun A15 with HIF4's Dogleg 5 Speed Bugeye Bonnet with Heated Miata Seats
    '80 Datsun 210 w/60 series 5 speed
  6. #6
    Join Date
    Nov 2003
    Location
    Louisville KY
    Posts
    8,086
    Thanks Thanks Given
    2
    Thanked in
    Summit racing has good prices on decent paint if you want a "stock" color. Otherwise, try some autobody supply shop that has mixing systems from something other than the "big names". here is an example of such a manufacturer: https://www.matrixsystem.com/
    1970/2 MG Midget
    Datsun 5-speed
    _________________
    1275 SuperCharged
    Datsun 5-speed
    _________________
  7. #7
    Join Date
    Apr 2010
    Location
    Lynnwood WA
    Posts
    642
    Blog Entries
    2
    Thanks Thanks Given
    Thanked in
    when your car is lower than a 18 wheelers tire..**** happens... drive it as it was meant to be... pos... when desired undo eight bolts and pull bonnet and a quick sand and paint job...
  8. #8
    Jedi Warrior Nelson's Avatar
    Join Date
    Apr 2005
    Location
    Medina, Ohio
    Posts
    529
    Thanks Thanks Given
    Thanked in
    I have heard that, for short time useage, the plastic film that realtors use to cover carpets for open houses can be used.
    Nelson
    Original owner '62 Mk 2 Sprite aka Little Mo
  9. #9
    Yoda Jim_Gruber's Avatar
    Join Date
    Dec 2006
    Location
    Apollo Beach, FL
    Posts
    5,494
    Blog Entries
    2
    Thanks Thanks Given
    5
    Thanked in
    Another reason for DIY Methodology rather than a $2,500 paint job. Rolled on Rustoleum works well, easy to fix. Someone here did Interlux Bright Sides Boat paint. Designed to be rolled or sprayed. Flattens well, provides good gloss and recommendation is not to sand or buff. I did paint a sailboat I raced using what was described as Corvette Paint, Deltron or something starting with a D. really, really hard paint. Could run into other boats and not leave a scratch. Drawback temperature sensitive when applying in Spring. I needed to paint outside, used cold temp additives in paint but one side of boat was in sun when painted but before it cured, that side moved into shade and temps dropped. Came back next day to discover major sags and runs on the bow area above the water line. Paint was almost impossible to sand down once cured. Not sure if still made as paint was known carcinogen I found out later but it was tough paint.
    Jim Gruber - Apollo Beach, FL
    Bugsy I - '68 Sprite w BE Bonnet - Gone but not forgotten
    Bugsy IV - '60 Bugeye - 1,275+.040 and a 5-Speed - CA Car - 2nd Owner from new - 10/12 Painting done, reassembly, cutting, and buffing in progress.
  10. #10
    Join Date
    Dec 2008
    Location
    South Dakota
    Posts
    3,930
    Thanks Thanks Given
    4
    Thanked in
    There's always bra's! Remember them?! I've seen a bugeye with one. I suppose they had a proper name but we always called them "bra's". If the front is covered with naugahyde and padding you won't get chip's. Paint chaffing under the covering but no chip's!
    Kurt.
    65,66 Midget
    57 Berkeley, MGA
    Working on quality rather than quantity
  11. #11
    Great Pumpkin JPSmit's Avatar
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    18,825
    Thanks Thanks Given
    64
    Thanked in
    Quote Originally Posted by nomad View Post
    Kurt.
    Proper name is Car Bra - Had a car once with one - the slight wind buffeting was not kind to the paint underneath.
    John-Peter Smit
    1976 MG Midget
    1969 Vauxhall Viva GT
    1958 Fiat Multipla (Barn art)
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
