Not sure how exhaust should fit?
Jimflorida
I am fitting the stainless exhaust from Moss on my Bugeye. I have the front-most hanger on and the midpoint hanger. At the very rear, I can either let the exhaust come fairly straight back, and in this case, the rear exhaust pipe is about an inch or two inside of the left bumperette or whatever its called, but this puts the silencer about 1 1/2 inches from the fuel tank, which is a bit of a worry. Or, I can push the rear of the exhaust more to the left, and the rear pipe comes out an inch or two to the left of the left rear bumperette. Looking at some Bugeye pictures, It is not easy to tell where it is supposed to come out as original. Anyone know?
Gerard
Jim,
There is a stud (or should be) near the end of the floor pan, between the hole for the bumper brackets and the fender. The muffler should be right below that stud. You can see the exact location in this photo.
J
Jimflorida
Thanks, Gerard. That picture helps a lot. I do have a hole where that stud must have been.
Jim
roscoe Not sure what I think of this Austin Healey 7
S Not sure on the ignition Spridgets 12
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
JPSmit Spotted - well I'm really not sure what? Other Cars 8
Jim_Gruber Generator and Polarity - Making sure Generator is Polarized Correctly Spridgets 13
KVH TR4/4A I Sure Like Driving My Triumph Triumph 8
L I'm sure this is how Donald would have developed the Bugeye... Spridgets 16
D Cheap sure-shot alternative Spridgets 0
bigbadbluetr6 Not sure what this is. Do you? Other British Cars 7
7 Post-War Other All apart, really frustrated and not sure what to do. Triumph 15
DNK Not to sure about this!! Triumph 9
NutmegCT Buying this will sure make someone *very* happy. Other Cars 14
SilentUnicorn I am not sure what happened... British Motorbikes 5
DNK Pretty Sure... Triumph 9
Stewart I sure hope its just a head gasket MG 8
Randy Forbes It might be a slug, but it sure is pretty... Austin Healey 28
S Not sure what a switch is for on my car Triumph 8
judow Not sure if MG 1
JPSmit Wasn't quite sure where to put this -youtube video Spotted 6
Moseso TR250 [This time, I am sure what it was] Spotted 0
regularman Pretty sure my overheating problems are gone. Spridgets 9
C Driving lots; be sure to... Triumph 15
T I'm sure this is simple but... MG 7
T Check this out! Make sure to look at all the pics Triumph 19
Bruce_B Just want to make sure before starting engine.... Spridgets 2
JPSmit Not sure it's worth it Spridgets 6
S HELP NOT SURE WHAT i HAVE Other British Cars 12
PATR8 Pretty sure this is a Healy Austin Healey 6
JPSmit I'm pretty sure but just in case Other Cars 5
Nunyas I'm not sure what to think.... MG 5
T Roll over video - not sure if it is an LBC Triumph 3
Mickey Richaud Well, It Sure Is RED! Triumph 6
AUSMHLY I'm thankful, I'm sure I'm not alone Austin Healey 2
jlaird Not sure Spridgets 12
JPSmit I'm sure we've discussed this before but... rims Spridgets 6
jlaird Would you beleive, sure you would. Spridgets 11
Bruce Bowker Not real sure about this paint. Lotus 4
B Unleaded but not sure Spridgets 4
B Overheating??? Not sure please help. Triumph 7
KLUTZ Not sure, but isn't this a ?? Triumph 4
Hegg No spark -- not sure why Triumph 14
J Smoking is that Bad? Yeh Sure, Help.. Other British Cars 12
W Pretty sure their blown Triumph 8
B Silly engine questions that i'm sure could be found in a FAQ somewhere.... MG 15
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
