TR2/3/3A Pedal box Tr3
Tr3aguy
OK so somehow the bolts that hold the pedal box together are missing.....anybody know the size and thread of these? I am speaking about the one that hold the pedals to the assembly.....just to be clear.
MGTF1250Dave
Aloha,
the bolt is 3/8" UNF x 5/8" long. The Standard Triumph part # is HU0905 and is listed as a set screw. The bolts should be fitted with a lock washer.
CJD
From what I remember, they were a bit "odd". I think the heads were abnormally large for the size of the threads, to give a larger bearing surface.
John
TR3driver
Great Pumpkin - R.I.P
Nope. Only thing odd about these is the length. Generally the hardware store only carries increments of 1/4", but you can cut down a 3/4" to fit.
Note that there is a "magic decoder ring" for all the part numbers that begin with two letters, available for download at:
https://docs.google.com/open?id=0B2H2NJt34OffMjJhY2YwZmQtYzgxNC00ZTk0LTk1YTUtZTIyZmU3ZTc1Y2M4
K For Sale TR3 Pedal Box Triumph Classifieds 0
K For Sale TR3 pedal box Triumph Classifieds 0
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
Jim_Gruber Pedal Box - Reassembly - Any issue with adding a spacer in the middle of the pedals Spridgets 5
simon1966 Pedal box blanking plate for a RHD Frog Eye Austin Healey 5
Rut Pedal box blanking plate Spridgets 10
AngliaGT Early '74 Midget - MC/Pedal Box Replacing Spridgets 3
M Screws vs bolts for pedal box attachment to body Spridgets 6
Jim_Gruber Adjusting Pushrods in Pedal Box Spridgets 5
Jim_Gruber Need BE Pedal Box Cover Spridgets 15
Branson later spridget pedal box install in early spridget Spridgets 21
Rut Bugeye pedal box Spridgets 2
T Pedal box seal question Spridgets 3
J TR6 TR6 Pedal Box Triumph 9
Branson Question re: master cylinder and pedal box Spridgets 11
Thor Brake light, do you have to remove pedal box? Spridgets 2
G Pedal box assemby Spridgets 7
Alan_Myers TR6 with TR6 pedal box and MC in TR4? Triumph 6
Thor Does the coil mount on top of pedal box on 1500? Spridgets 2
fmichaels pedal box bolt Spridgets 10
77_MG_Midget Pedal Box Bolts for '77 1500 Midget Spridgets 6
P Pedal Box Cover Screws MG 6
philman Wedge tr7 pedal box Triumph 3
F Excessive Brake Pedal Travel Austin Healey 3
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Sopwith_Camel MGB pulsing brake pedal MG 10
CARSINC MKIII Accelerator Pedal Spridgets 0
Gatheringtree TR2/3/3A Billet Pedal Cover Set w/ Triumph logo Triumph 0
P Pedal Position Adjustment Austin Healey 2
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
T Clutch Pedal Engagement Point Austin Healey 1
K TR2/3/3A The Dead Pedal Triumph 3
petnatcar Dead Pedal Austin Healey 12
R TR2/3/3A Gas pedal pad for TR-2 Triumph 3
bighealeysource Soft Brake Pedal Austin Healey 7
BierRunner TR6 TR6 Gas Pedal Triumph 4
DrEntropy MGB Pedal extension MG 6
Jeepster Clutch Pedal Position Austin Healey 4
DrEntropy General Tech Pedal freeplay MG 6
S Receding Brake Pedal Austin Healey 32
C BN1 Clutch Pedal Rattle Austin Healey 2
J For Sale Triumph Tr 2/3 Gas Pedal Triumph Classifieds 1
G TR6 Binding Clutch Pedal Triumph 5
K Midget Brake Pedal Question Spridgets 2
D TR2/3/3A clutch/brake pedal question Triumph 4
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
D Gas Pedal Pad Jaguar 7
P TR6 Clutch pedal click noise Triumph 2
