TR2/3/3A TR3 winnshield glass
TFB
I need new glass windshield.Moss is $299 for triplex brand,BPNW is $129 and I could not find any windshield glass on TRF site.
Anybody used the BPNW glass?My main concern is quality, fit and price not brand.
Thanks
Tom
PKPoole
Jedi,
I've used Victoria British several times (TR3 and MGA)for windshields and think they are the best for the least price ($100 on sale). The shipping is also very reasonable and well packaged. My only advice is to order the rubber seal (glazing) for the MGA from Moss. It is thinner and easier to install than the ones you get for the TR3. I found this out the hard way by breaking the first TR3 glass I got. Good luck. Pat
JFS
Bronze
You might try a local glass company. Tri City Glass, a local company, procured a Triplex windshield and necessary gasket and installed it in my TR3 windshield frame for what I remember to be a reasonable price.
T
TFB
Thanks for the info.Maybe I will run it by a local glass shop after I get the frame prepped.
Thanks again
Tom
TR3TR6
Tom:
When I purchased my windshield glass ( I think I got it from Victoria British), its been some years ago; the first thing I noticed was the glass was thinner then on my original. A friend also purchased one just before I got mine and ended up breaking it when he tried to install it. I was very careful and got mine in okay. The glazing for the glass that I purchased was too thick, so I used black cloth tape which worked real well. After I had the glass installed, I just used an box cutter to trim off the excess. Good luck.
mallard
The glass I got from VB was at least 1/4" shorter than the original, and it did not fill the corners. I would not get one from them again. It was cheap though $89.00 on sale.I'm sure TRF has the glass you just need to find the factory part number. I've always had good luck with BPNW parts. The Triplex glass is a bit expensive but it may also be the best.
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
R TR2/3/3A TR3 Wiper motor Triumph 10
H For Sale TR3 RHD tonneau cover nee Triumph Classifieds 0
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
5 TR2/3/3A TR3 fender patch panel question Triumph 10
2 For Sale Dr. Doolin Spring Compressor for TR3 Triumph Classifieds 0
