Down Draft Vent Tube Plug...
F1LOCO
For those who have removed them, question, my is moving now but it keeps moving back towards the block. Probably about a 1/2". What's behind it? Is there a chance if I remove the pan can I punch it through intact?
Geo Hahn
No. As I recall the area behind it is a blind cavity cast into the block.
If it is moving then you're making progress. If you can get something stuck thru it that enables you to twist it (I used a stubby screwdriver) then you can sort of twist and pull and it should work out.
It is not made of thick metal -- the challenge (as you have probably noticed) is the lack of 'swing room' in that confined area.
F
F1LOCO
Yes, no swing room.
Is there anything behind it that can break? I think it is as far back as it can go at this point. Didn't want to do anymore without some recon.
F
F1LOCO
Wonder if a lapping suction cup can get enough of a bite? Took the liberty of soaking some PB Blaster and a light 2000 finish...
I need a 1/2" super strength suction cup of sorts with a handle on it...
karls59tr
Bronze
I think there was a previous thread on the plug removal. Someone had devised a tool I think. Not sure how to locate past threads on this forum?
sail
Pulling Plug
There is nothing but block behind it but no room to pull it through from what I could tell, even with the pan off. Once I got a large enough hole for my homemade tool it popped right out.
Geo Hahn
If you had a big enough tap to thread in there it would grab hold of the plug pretty tight. I have done this with much smaller bushings but I expect few of us have a 1" (or whatever size) tap in the tool box.
sail
Sorry to say I could not get any pull with the internal wrench or I would send you mine. It did turn it but no pull. It took me forever to enlarge the hole as I was trying different methods. Once the hole was large enough for my tool and pry bar it took only moments to hear "ping."
It will come out.
F
F1LOCO
Unfortunately, no room for a dent puller while in the car.
Working on chiseling through the sides so I can hopefully collapse it and yank it out... stay tuned...only problem is 1/4" chisel is so short, can't get good hard strikes on it so it is tedious..
What a mess...
Geo Hahn
I doubt you'll be able to collapse it to remove. Getting a hole thru it should help. I started with a hole and threaded in a sheet metal screw then used a nail-pulling pry bar -- but that did not work (not sure why). Eventually the hole was large enough to poke a stubby screwdriver through -- once I could both twist and pry the plug cam right out.
B TR2/3/3A Down draft tube blow by Triumph 5
G Down Draft Tube Installation Triumph 3
boxofparts TR6 Tr6 Down Draft Webers - need help Triumph 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Got_All_4 TR6 TR6 Down Pipe How They Last Triumph 6
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
M MGC New book: MGCs Down Under MG 0
shadowfever Shake down run Spridgets 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
Busted knuckles TR2/3/3A Engine tear down, Triumph 13
Rut Cut down windshield Spridgets 22
S TR2/3/3A trim to hold down the furflex Triumph 3
Sopwith_Camel up or down? Jaguar 12
D TR2/3/3A stator tube will not go down Triumph 0
K Austin-Healey Fold-Down Windscreens Austin Healey 27
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
DrEntropy Diesela won't go down... Other Cars 5
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
A Spitfire Spitfire Ride Down The Mountain - Vermont Rt 100 Triumph 12
wangdango BJ8 inner battery hold down? Austin Healey 4
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G Supplier rant from down under Austin Healey 12
RAC68 Cost of Cutting Down an American Rear Austin Healey 12
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
M Hauling a Spridget - Proper tie down technique? Spridgets 15
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
PatGalvin TR2/3/3A Scraping Down Under Triumph 18
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
GTP1960 Drive down memory road. Other Cars 14
AngliaGT MGB When the MGB is Down..... MG 1
KVH General Tech Leak Down Test Triumph 17
aero3113 100 hard top with windshield folded down. Austin Healey 4
N Wire wheel hub removal & suspension tear down Spridgets 3
simon1966 BN1 Strip down well under way Austin Healey 5
mcmillal TR4/4A TR4 suddenly shuts down Triumph 25
SherpaPilot TR6 Engine Will Not Shut-Down Triumph 4
PC the fire down below Spotted 7
S Best Top Down Tune Spridgets 36
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
R Tracking down my dads old Austin Eight Other British Cars 3
healeydan Windshield Seal Won't Lie Down Austin Healey 3
Jeepster BJ8 exhaust down pipe gaskets Austin Healey 6
S rear fold down seat Austin Healey 4
HealeyRick Down East Dickering Midget Spridgets 4
jlaird Miss Agatha jumping up and down Spridgets 0
JPSmit Brisk Top Down Motoring Spotted 1
