My TR6 engine has about 103K and as far as I know, the head & oil pan have never been off. I have 65 lbs oil pressure and good compression but bad valve guides so this winter, I'll take the head off & do the usual.But - I think my thrust washers must be original. I never checked them because nobody told me I should have.Assuming they have to be replaced, my question is this - should I replace the connecting rod bearings while the pan is off or am I looking for trouble? And - should I replace the main bearing cap bolts?
PD
PD
