Brake booster
TRclassic3
Need some insight in this. My brake master started leaking on the 77 M. I decided that seeing that the booster is an unknown to me I would replace it as well with a rebuilt. All my research indicated that it is a stock TR6. I received one today from a trusted vendor and find that it is smaller in diameter by about an inch. Some other minor differences as well. but it does look like the rebuilt would work. So, looking for some info on whether TVR used something other than a TR6 booster, or if maybe the one on it is not original, or.....?
Thanks
tr8todd
I wouldn't be surprised if they switched over to using the TR7 booster once production of the TR6 ended. The later 280i stole more than just its shape from the TR7. There were a lot of the parts on my 280i that were the same as my TR7s and 8s.
TRclassic3
TRclassic3
Interesting and very plausible explanation as this car was at the very end of the 2500M run. Thanks for the response.
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
G Adding a Brake Booster / Brake Calipers Austin Healey 3
G Brake Booster Failure Symptoms Austin Healey 3
drooartz MGB Swapping to dual SU on later MGB with brake booster MG 7
glemon General Tech Brake Booster Happy Camper Triumph 0
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
glemon TR5/TR250 Brake Booster Triumph 2
Marvin Gruber BJ8 brake booster Austin Healey 6
Marvin Gruber Big Healey brake booster rebuild Austin Healey 4
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
Marvin Gruber BJ8 brake booster picture Austin Healey 4
G Brake Booster Replacement Air Filter Austin Healey 4
BOBBYR BJ8 Brake Booster Austin Healey 13
sundown TR6 1973 TR6 brake booster hose Triumph 7
RAC68 Alternative Remote Brake Booster Austin Healey 3
T Brake booster rebuild Austin Healey 4
P BJ8 Brake Booster mount Austin Healey 9
C Vacuum line routing for brake booster Austin Healey 5
Gliderman8 Brake booster rebuilder Triumph 5
Got_All_4 Wedge TR7 brake booster Triumph 18
tinman58 TR5/TR250 TR250 brake booster Triumph 2
W Brake fluid in Servo/booster Triumph 5
PAUL161 Chevy P 30 chassis brake hydro booster? Other Cars 0
66healey Aftermarket brake booster pictures Austin Healey 7
J TR6 70 TR6 Brake Booster Triumph 4
B Brake Booster Austin Healey 2
E installing AP brake booster Austin Healey 3
Patrick67BJ8 Brake Booster Repair Vendor Austin Healey 21
rjc157 Powertune Brake Booster Austin Healey 0
Basil COrrect plating for Brake Booster? Jaguar 9
nissanite TR6 TR-6 brake pedals in a TR4A including booster &... Triumph 30
B rebuild of brake booster Austin Healey 6
D Wedge Power Brake Booster/Master Cylinder for TR7 Triumph 4
J Rebuild brake booster? Austin Healey 0
A brake servo booster help Triumph 3
R Painting the Power Brake Booster Triumph 11
BOBBYR Girling brake booster Austin Healey 5
N Brake booster rebuild Triumph 3
kyreb1862 Brake Booster Install MG 0
I TR6 69 TR6 brake booster Triumph 2
VelodromeRacer Brake booster hissing... Austin Healey 9
N Vacuum leak at Brake Booster? Triumph 15
B TR6 TR6 Brake Booster/MC Rebuild Triumph 5
WALTER BJ8 w/o brake booster? Austin Healey 4
S HELP! with vacuum brake booster Austin Healey 4
S Brake booster vacuum cylinder cover color... Austin Healey 2
Brosky Brake Booster Rebuilding Triumph 9
2 Brake Booster Triumph 3
kyreb1862 MGB 77 MGB Brake Booster Color MG 5
kyreb1862 MGB MGB Brake Booster Diagnosis MG 1
