TR4/4A Refreshing solid axle TR4a rear bushings
tdskip
I've done the TR6 and the IRS TR4a, need to do the solid axle TR4a and wondering how much of a fight I'm in for.
Is the front eye spring (#51 below) usually a fight to get out?
The shackle pins shouldn't put up too much of a fight should they?
richie
Mine came off very easily! Was quite straightforward, although my springs had been changed about 15 years ago which could account for its ease :smile:
MichaelG
Mine were original, rusted in, and needed some work to get out. I don't have a press so tried penetrating oil, heat, BFH, etc....didn't budge. Someone on the list offered a tip to drill out the rubber in the bush..so the inner metal tube falls out leaving just the outer metal tube. This worked and then it was short work with a BFH and chisel....
TR3driver
Great Pumpkin - R.I.P
Another alternative is to heat the rubber until it melts (and burns), then poke it out while it's hot. Then you can cut into the outer sleeve with a hacksaw blade. When you are most of the way through, beat on the sleeve with a BFH & drift to drive it out.
I've used this approach on other similar components, but the original rear spring bushings on my TR3 came right out in the press. Of course, we don't get nearly as much rust around here, so YMMV.
aeronca65t Refreshing engine Racing 8
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General Tech Rear Brakes and Solid Axle Triumph 2
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
C AUF214 solid state conversion question British Motor Corp 0
R Solid state SU Fuel Pump Austin Healey 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
T TR4/4A Differential clatter-solid axle Triumph 4
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
N Spitfire Question on solid steering rack mounts! Triumph 3
BobbyD New OD Controller & Solid State Rheostat Triumph 0
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
T Tvr 2500m For Sale, Nice Original Solid Example. TVR 1
Stinger TR4/4A TR4A Wood Dash Plywood or Solid Wood Triumph 13
coj Solid state turn and brake box Austin Healey 7
V Solid state fuel pump question Spridgets 2
T TR4/4A Which TR4a is better - IRS or solid axle? Triumph 30
hymodyne rubber, poly vs solid steering rack bushings Triumph 12
PAUL161 Solid Throttle Disk for HIFs MG 7
Banjo TR4/4A TR4A solid rear axle, axle. free Triumph 8
M Solid state conversion of Lucas regulator Triumph 9
bighealeysource Noisy solid state fuel pump Austin Healey 15
T GT6 GT6+ - could be a solid car Triumph 22
J TR4/4A TR4A Solid Axle Rear Brake Backing Plates Triumph 17
MGTF1250Dave Solid State Voltage Regulator Up-date Triumph 7
MGTF1250Dave Solid State Voltage Regulator Conversion Triumph 9
BugEyeBear Nice Solid BugEye on eBay [not mine...] Spridgets 8
Morris Solid core wire Spridgets 6
vping Installing a Solid State Fuel Pump MG 7
J TR4/4A TR4A solid axle assembly Triumph 15
B solid looking project for someone Spridgets 7
B MOSS solid state fuel pump Spridgets 3
ronzet Flame Thrower solid state distributor for my A MG 12
B solid bronze TW Spridgets 1
vping Anyone use a solid state fuel pump? MG 35
6 Solid State SU Fuel Pump Ticking: Constant? Austin Healey 4
T TR4/4A 4A IRS tub on 4A solid axle frame? Triumph 2
Westfield_XI Solid mounted Spridget transmission Spridgets 0
T TR4/4A TR4a [solid axle] rear twitch-iness question Triumph 15
D E-type solid rack mounts? Jaguar 6
Banjo TR4/4A TR4A solid axle rear end for sale Triumph 0
racing girl How Many Of You Use A Solid Neck/Shoulder Brace? Racing 3
M Solid color or 2 tone paint Austin Healey 8
Banjo TR4/4A Soon to be parting a TR4A solid axle Triumph 1
beaulieu solid wheel knock-offs , do they exhist ? Restoration & Tools 11
AUSMHLY Su Solid state fuel pump Austin Healey 26
T Solid Sway Bar bushing mounts Spridgets 2
3 Solid vs. poly vs. stock rack mounts. Triumph 10
R rusty but solid seat bottom Spridgets 4
