Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: TR 250 "While I am there"
Discussions of Triumph motor cars
  1. #1
    Jedi Knight tinman58's Avatar
    Join Date
    Sep 2008
    Location
    Star Idaho
    Posts
    1,293
    Thanks Thanks Given
    Thanks Thanks Received
    1
    Thanked in
    1 Post
    The 250 was going to be a "change the oil, change the old rubber bits, new tires and a spit shine and were off for a summer of driving the 250. After sitting in a garage since 1987 things are not what they seem. So..... You can't put new shocks on the funky looking suspension, you can't just put a new pretty power booster in a old grungy engine bay...... More updates to come.
    Dan
    TS37148L Restored and running! Again!
    TS23575L gone, but found in a wharehouse
    TS23351L Donor parts for TS37148L
    TR 250 CD835LO
  2. #2
    Jedi Warrior luke44's Avatar
    Join Date
    Dec 2009
    Location
    Sewell NJ
    Posts
    650
    Thanks Thanks Given
    1
    1
    Thanked in
    1 Post
    Re: TR 250 "While I am there"
    Quote Originally Posted by tinman58
    The 250 was going to be a "change the oil, change the old rubber bits, new tires and a spit shine and were off for a summer of driving the 250...
    And so it starts...down the long slippery slope. No turning back now!
  3. #3
    Yoda Geo Hahn's Avatar
    Join Date
    Sep 2001
    Location
    Mt Lemmon, Arizona
    Posts
    9,370
    Thanks Thanks Given
    14
    Thanked in
    Is that what they mean when they say the engine is 'missing'?
  4. #4
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Floe Ice, Antarctica
    Posts
    6,338
    Thanks Thanks Given
    24
    Thanked in
    I like those new, improved, blue head gaskets. Fixes the problem, does it?
  5. #5
    Obi Wan HerronScott's Avatar
    Join Date
    Apr 2009
    Location
    Staunton, VA
    Posts
    2,039
    Thanks Thanks Given
    Thanked in
    Dan,
    Wasn't that a running moving car when you got it?
    What's the current plan? Definitely keep us updated on the progress!
    Scott
    1966 TR4A IRS CTC69123L (first car and first love!)
    1966 TR4A IRS CTC72159LO
    1959 TR3A TS51339L
  6. #6
    Join Date
    Dec 2008
    Location
    AZ
    Posts
    1,670
    Thanks Thanks Given
    Thanked in
    Your in trouble now $$$$$$
    Keith D
    1974 TR6 been the owner of this car for 37 years.
    1956 TR3 car is being restored.
  7. #7
    Join Date
    Sep 2008
    Location
    Star Idaho
    Posts
    1,293
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    The car had not moved from the garage since 1987. Was "running when parked" It looked liked you could throw a new battery in, prime the carbs and off you go. But on closer exam...... The plan was to clean it up fix the minor things and make it safe to drive. Well as you can see by the photos that We have done a little more than that. Plans change. I think for the good. This 250 is for my Wife and it needs to be safe, reliable and has to look good. We are going to leave the paint alone just a good buffing and polish. I like the patina. The interior is going to be all redone to proper TR 250 specs. But with guidence from my Wife (color, leather etc. Under the hood we are going to respray to the signal red after welding in a new battery section. Maybe out of S.S.. The engine will be left stock (The TR3 is fast enough). Glen stopped by today with more advice, I.E. how to spend more money. I am sure that the Moss catalog is going to get well used.
    P.S. I need a windshield wiper motor If any body has a extra?
    It does have overdrive
    Dan
    TR 250 CD835LO
  8. #8
    Join Date
    Oct 2007
    Location
    CA, USA
    Posts
    15
    Thanks Thanks Given
    Thanked in
    Dan,you act so supprised. I'm from the goverment and I'm here to help.
  9. #9
    Jedi Trainee TonyPanchot's Avatar
    Join Date
    Dec 2008
    Location
    Where the man sends me ( MO ) currently
    Posts
    318
    Thanks Thanks Given
    Thanked in
    I would hope that you are to change to oil filter DE-rangement, I retained my Original Equipment thru one oil change and that was it, I am sure it would work on a RH, Oh do the oil cooler as well, while your there
    1968 TR 250
    1972 MkIV 1500
    1973 MKIV 1500
    2002 BMW Z-3 M
    2004 Lotus Esprit
    2007 SL 550
    2009 LR3
  10. #10
    Join Date
    Sep 2008
    Location
    Star Idaho
    Posts
    1,293
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    O.K.Spent most of the day removing more and more parts..... Now I am thinking frame off. The only problem is not enough room. I need a bigger garage. and a little more brains....
    Dan
    TR 250 CD835LO
  11. #11
    Obi Wan TR6oldtimer's Avatar
    Join Date
    Mar 2006
    Location
    Santa Cruz,CA
    Posts
    2,163
    Thanks Thanks Given
    Thanked in
    Your floor boards look great. If there is not rust to deal with, then I would not do a frame off restoration, especially if the car is to be a driver, occasional or not.
    With the engine removed, the car, especially the engine compartment,can be easily painted.
    At most, I would remove the fenders to inspect for rust. But frame off, not. Even the frame can be painted with the body on, except of course the top.
    It is a whole lot of work just to have shiny floor boards under the car.
    But if you must, then there are creative solutions to lifting in place inplace and supporting the body in toto above the frame, which can be wheeled in and out as work progresses.
    Ray
    A man is not old until regrets take the place of dreams.
    1973 TR6 sort of Mallard Blue in restoration
  12. #12
    Join Date
    Sep 2008
    Location
    Star Idaho
    Posts
    1,293
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Well we are going to pull the body off the frame.The "while I'm there" syndrome is to over powering. As is the conversion with my beautiful Wife. She want' it to look like the TR3..... so here we go!
    I don't think that it will be that much more work than I already have into it. The time frame is not critical. It will be done for the spring driving fun. Gonna order a bunch of stuff tonight so the economy of the USA will hit a spike tomorrow. "IT'S ONLY MONEY".
    Dan
    TR 250 CD835LO
  13. #13
    Join Date
    Oct 2011
    Location
    Meridian, MS
    Posts
    5
    Thanks Thanks Given
    Thanked in
    Some more guiding lines:
    - "You can't take it with you"
    - "You're spending your childrens' inheritance" (tell my son that often - I intend to time my death to be on day Zero $)
    To expedite that, build that bigger garage you need. I did 1200 square feet, attached to the house, really helped me along that path... Did I mention the 600 sq ft tornado shelter underneath the garage? (that also holds a future project car)?
    Now I just need my TR-6 drive-train back from Wishbone Classics/Kai Radicke
    Better to die than to look bad!
  14. #14
    Join Date
    Sep 2008
    Location
    Star Idaho
    Posts
    1,293
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    I WILL NOT WATCH "OVERHAULING", I WILL NOT WATCH "OVERHAULING" Repeat over and over.
    Dan
    TR 250 CD835LO
  15. #15
    Join Date
    Oct 2008
    Location
    South Charleston, WV USA
    Posts
    470
    Thanks Thanks Given
    Thanked in
    While you have the body off the frame, you might as well reinforce the diff mounts even if they look okay, just to avoid issues later, since you are there.....also maybe a coil over conversion for rear shocks...
    Dan B
  16. #16
    Join Date
    Sep 2008
    Location
    Star Idaho
    Posts
    1,293
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Thanks for the advice. The body is ready to be removed. There is a lot more to a 250 than a TR3. The coil over is a must and the stiffening is to. There is a big order ready to go to TRF. "IT'S ONLY MONEY"
    Dan
    TR 250 CD835LO
  17. #17
    Obi Wan hondo402000's Avatar
    Join Date
    Mar 2006
    Location
    Charlotte, NC
    Posts
    2,117
    Thanks Thanks Given
    3
    Thanked in
    why not just stick with the original armstrong shocks, you can have them rebuilt a little stiffer. those after market kits although look really cool just transfer loads to different parts of the body that were not designed for
    the coil overs just put more pressure on the upper spring mount and the kits that bolt to the original mounts but use a regular shock just make a big lever and eventually rip the original mounts apart.
    just my observation on here over time and the things I have seen
    Hondo
    It Is What It Is
  18. #18
    Join Date
    Sep 2008
    Location
    Star Idaho
    Posts
    1,293
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Oh the things to ponder!
    Dan
    TR 250 CD835LO
  19. #19
    Join Date
    Oct 2007
    Location
    CA, USA
    Posts
    15
    Thanks Thanks Given
    Thanked in
    Dan, you need to do the tube shock kit, you need the headers, you need it all. Don't stop half way, I'll point it out to everyone that you went cheap.
    IOM, IOM, IOM, then whip out the card and make the call and sleep better tonight
    Glen
  20. #20
    Join Date
    Sep 2008
    Location
    Star Idaho
    Posts
    1,293
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Thanks Glen, I really need your support! I need to keep the garage door closed. The worst part is that you will point it out to Terry! Then I am in trouble.. On TRF's web site now.
    Dan
    TR 250 CD835LO
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
