Which Tool for the Oil Drain Bolt?
kindofblue
I need to relieve the engine of the oil before turning it over. I can't get the bolt off after being siezed in there for fourteen years, and I don't want to round it off. I would like to replace the square head with a more conventional hex head at some point.
G
I'm not quite sure whose idea it was to put a square headed bolt on oil pan and transmission drains. I changed all mine to hex head bolts. You can find these at any industrial-grade shop. Just clamp a really big pair of vice grips on the little puppy and start tapping in a counter clockwise motion. Bring the bolt to said shop to match the threads. Do the same for your tranny. I can top off my tranny from the bottom easily now by accessing the side bolt with a shallow socket. p.s., never use teflon tape to secure a seal.
Bill
martx-5
I know the drain plugs on the TRactor (4 Cyl) engines are actually tapered pipe plugs which usually come with a square head. If it's square on the six cylinder engine, it's probably a pipe thread also, which is readily available just about anywhere. I've used a pipe wrench on those suckers when they are really tight which only seems natural since it's a pipe plug. The cast iron plugs generally have the square head. Steel and brass can be gotten in hex heads. Steel hex would be the best choice, but since generic pipe plugs are so cheap, putting a new square head guy on every oil change if neccessary, wouldn't be a big deal. /ubbthreads/images/graemlins/cheers.gif
trrdster2000
Most of the big BL companies carry the right wrench for the job, I was lucky to pick up a bunch of square head sockets at a yard sell years ago. I would guess they are still avaible at your local plumber. TR6Bill is right about the vise grips on one that has been stuck for a while. Wayne
trboost
When you do get the old plug out replace it with a magnetic drain plug. All of the houses sell them. It's a good way of keeping unwanted bits from circulating.
As recomended a large vise grip (10cr) will grip well but leverage will not be great. You can also use a pipe wrench.
How come the stuff that's supposed to come loose doesn't & the stuff that's not, does ?
Geo Hahn
[ QUOTE ]
...never use teflon tape to secure a seal.
[/ QUOTE ]
Why is that? I don't do this on the TR because I see no need but routinely do it on an engine with an aluminum casing and steel plug. Get that one too tight and it's all she wrote.
Is it because a bit of the tape might get in the oil? I sure I have nastier stuff in the crankcase from time to time.
kindofblue
kindofblue
Aha,
Its a plumbing remnant. I will look around at the local stores to see if I can come up with something. I have a really old style hardware store not far away that may just be the one to have such a tool. With the way the car is sitting on the jackstands, it is kind of hard to get at the bolt under there. Especially since the floor is freezing cold, and there is water trickling in from the cement because all the rain we got in the fall is thawing.
Don't ask, we must really love this to be laying on freezing floor in the ice cold weather trying to get some strange bolt loose....
BTW, I did see the magnetic diff bolt with a hex head in the TRF catalogue. I presume the the thread pitch is the same. I will order one with my next TRF order.
I really like this forum. Everyone responded so well to what seemed like an inane question about an oil drain bolt. I have changed the oil on 100s of cars at work (with normal bolts). I found myself getting annoyed this afternoon, and that is when I put my tool down and went inside. Its supposed to be fun above all else.
Alan_Myers
Hi all,
Most any good hardware store will have the bolt you are looking for. It can be bought in square head, although 1/2" square is most common now while the TR original is 7/16" square, or in hex head, possbly even an Allen or socket head.
Just go to the plumbing department and look in the pipe fittings. You need a 3/8" NPT fitting (I know, seems much larger than that... plumbing pipe thread fitting sizes are referenced to the inside diameter of a pipe using this thread, not the diameter of the thread). I use brass, since it's less likely to damage aluminum parts and seals well. My local store also offers them in galvanized steel and plain steel.
I've been looking for a set of square wrenches too, if anyone knows a source.
Cheers!
Alan
G
You're right, guess I was thinking of Teflon and gas lines. Refer to "dumb thing" post to check out my infallability issue. I've got so many leaks of oil under my car that I really don't know where they all come from. At least the front 2/3 of my car never rusts. The whole overdrive unit is new and it leaks. Between the oil and Waxoyl, BL knew what they were doing. Who needs galvinized panels? BTW, have any of ya'll discovered Pro Honda Spray Cleaner and Polish. Great little detailing item for cleaning up everything before a show, paint and all. (what's this got to do with Teflon, you ask?)
Bill
kindofblue
kindofblue
I sprayed with Mopar rust penetrant yesterday. I got it off with an adjustable pliers and an 11mm open end wrench.
I drained some oil out, turned the engine over and ran compression.
W General MG 2001 MGF 1.8 Steptronic Flywheel locking tool MG 0
K TR2/3/3A SU balance tool Triumph 13
Editor_Reid MGA Seeking Items for MGA 1600 Mark II Tool Kit MG 0
D New Tool. Restoration & Tools 3
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
charlie74 TR6 handbrake adjustment tool Restoration & Tools 0
Basil Hagerty Car Valuation Tool Other British Cars 1
JPSmit some days your best tool is a credit card Spridgets 2
D My new restoration tool Restoration & Tools 13
Basil Drill Bits (and other tool reviews) Restoration & Tools 9
TomMull Wanted Churchill Tool 20sm69 Triumph Classifieds 36
steveg At last - inexpensive double crimp tool Restoration & Tools 4
Basil Multi-Tool Scraper/ Utility knife Restoration & Tools 0
Basil Now THIS is a tool box Restoration & Tools 6
drooartz The latest tool addition to the shop Restoration & Tools 25
JPSmit Tool identification quiz Restoration & Tools 16
H Wanted BJ8 Jack and complete Tool Kit Austin Healey Classifieds 0
JPSmit what's this tool? Restoration & Tools 12
M TR2/3/3A Transmission Removal Tool Thread Triumph 2
H name and address of Jag tool seller located in Chambersburg pa Jaguar 3
I TR6 Chrome bezel removal tool? Knob removal? Triumph 6
N Tool Rolls and Pouches Austin Healey 14
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
Got_All_4 General TR Is there a special tool needed for rear brake cylinders Triumph 14
TomMull Knock Off Tool Restoration & Tools 6
K BMC Supplemental Tool Kit Bags Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
1 MGB MGB tool kit MG 18
D Modified carb sync tool. Austin Healey 11
D Eastwood Surface conditioning tool Restoration & Tools 18
D tool roll Austin Healey 2
M Tool Advice Sought Austin Healey 3
steveg Carb float setting tool Austin Healey 11
H useless carb balance tool Austin Healey 25
steveg Wanted - easy install tool or technique for directional/stop light lenses Austin Healey 9
TomMull bubble flare tool Restoration & Tools 4
TomMull Another tool score? Restoration & Tools 6
PC latest tool score Restoration & Tools 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
Michael Oritt SU reaming tool needed Austin Healey 7
M SU Jet Centering Tool - A Worthwhile Investment? Spridgets 2
Rut Diff plug tool Spridgets 7
Nelson My new toy/tool Spridgets 3
S TR2/3/3A the 9/16 & ½ tube socket for the tool kit Triumph 13
drooartz Brake flaring tool Restoration & Tools 8
Brinkerhoff TR4/4A TR4A tool kit Triumph 0
2billydavies TR2/3/3A Question about size of Clutch Alignment Tool Triumph 9
Editor_Reid Tool Kit ID Jaguar 7
trotti Simple tool for steering box adjustment Austin Healey 5
