Results 1 to 7 of 7
Thread: Spitfire rack n pinion lub
Hybrid View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Join Date
    Nov 2011
    Location
    Pensacola, Fl.
    Posts
    7
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    i'm rebuilding my Spitfire R&P and need to know what to lub it with. there are no zerk fittings on it. i looks like it has a moly type grease in it now.
    thanks,
    Fred V
  2. #2
    Jedi Warrior sd80mac7204's Avatar
    Join Date
    Feb 2012
    Location
    Home, Pa
    Posts
    667
    Thanks Thanks Given
    Thanked in
    Re: Spitfire rack n pinion lub
    I use 80-w90 gear lube. There is a small plug where the steering shaft goes into the rack. Remove said plug and thread in a zerk. Once adding oil is done you can replace the plug.
    Dan
    1978 Spitfire 1500 "Little Girl"
    2002 Impala LS "Beast"
    2001 Impala LS "Harlot"
    1974 Spitfire 1500 "Scrappy"
  3. #3
    Join Date
    Nov 2011
    Location
    Pensacola, Fl.
    Posts
    7
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by sd80mac7204
    there is no such plug in mine. my guess is that it doesn't need grease once packed initially. it would be easy to drill and install a zerk since it is all apart now.
    Fred V
  4. #4
    Moderator Andrew Mace's Avatar
    Join Date
    Sep 2002
    Location
    East Nassau, NY (nr. Albany)
    Posts
    6,196
    Thanks Thanks Given
    101
    6
    Thanked in
    I suppose geal oil is ok; ISTR older racks called for that. But Triumph typically called for the same grease as you would use in the rear hubs or water pump (if it's the older, greaseable type).
    -- Andrew (Andy) Mace, VTR's Triumph 10/Herald/Sports 6 vehicle consultant and keeper of the North American Triumph Sports 6 and Herald Database
  5. #5
    Luke Skywalker 3798j's Avatar
    Join Date
    Apr 2005
    Location
    Susquehanna Valley
    Posts
    1,803
    Thanks Thanks Given
    10
    5
    Thanked in
    Try Mobil 1 Synthetic Grease. I really liked the results - very smooth.
    '66 TR4A '68 GT6
  6. #6
    Join Date
    Sep 2002
    Location
    Posts
    6,196
    Thanks Thanks Given
    101
    6
    Thanked in
    Take a look at #35 (large screw-in cap) and #36 (grease plug) in this diagram of a Spitfire Mk3 rack from Canley Classics. I chose this one as it's more obvious than the later Spitfire diagram in showing you where the grease plug (or Zerk) is or would be. Some later racks might not have had it, and most new ones don't as I recall.
  7. #7
    Join Date
    Nov 2011
    Location
    Pensacola, Fl.
    Posts
    7
    Thanks Thanks Given
    Thanked in
    thanks Andrew. i do have that plug. i didn't remove it yet so didn't realize a zerk could be put in there.
    another question. does anyone in the states sell a u-joint to replace the rag joint. i found one from a UK supplier.
    Fred V
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
