TR6 TR6 trailer hitch
tomshobby
I have been working on a way to mount a trailer hitch on our TR6 for a few years and this is what I came up with. I still need to drill the fastener holes and have it powder-coated. I did get a new chrome ball for it. I also need to cut off the tops of the rubber bumper brackets.
I wanted something that was quick and easy to install and remove. With this it is only 4 bolts to install and remove the hitch.
Brosky
So Tom, were you able to use those old brackets that I set you?
Brosky
Yes we did Tom, but you know my memory needed a "prime" to recall that conversation.
John_Mc
Time to paint the trailer BRG!
tomshobby
tomshobby
Well, the hitch is mounted and the trailer has been on the car. Very happy with the result so far. I have re-packed the wheel bearings on the trailer and had new wheels and tires installed. I also tested some Fusion paint and found it a reasonable match to the car so we are removing the old paint.
Will need a new Packer sticker for the trailer too!
David Sanborn
For those of us without the rubber bumper overriders, we're out of luck. So far my searches have not turned up any kits or CAD plans for making a trailer hitch for the earlier TR6 with the purely aesthetic but structurally worthless bumpers. Anyone out there know anything on this topic, don't hesitate to drop me a line at danborn at google's own gmail service. Much thanks in advance.
trrdster2000
Tom, Looks professional and I like the TRIUMPH on the lower section of the middle bumper. Nice effect.
Wayne
Got_All_4
I have a rear competition ADDCO anti sway bar installed and along with the trailer hitch it stiffens the rear end too much where it is too dangerous to drive without the hitch in use. I removed and plan to only install when on a trip.
sqbsprite
Looks great. I'm not being critical, but I probably would have made the plate that the ball mounts to extend the full length of the braces. That way you could have ran a weld along the entire lower edge and it would just look more solid. Might not be any stronger, just would look smoother.
tomshobby
tomshobby
I used an extruded piece for the main beam and it is very strong. It is a boxed part with a heavy braced side in the back. The parts that are used for the ball mount are also pretty heavy. It is all aluminum and the welds were made by an expert welder. The bumper brackets have since had the top part for the rubber bumpers have been cut off and all the parts are now out for powder coating. Even though the towing capacity for the car is 2,000 lbs I doubt it will ever be used for the trailer capacity of 900 lbs or even half that.
tomshobby TR6 progress on my tr6 trailer hitch Triumph 8
I TR6 TR6 trailer hitch? Triumph 9
tomshobby TR6 TR6 trailer hitch? Triumph 12
tomshobby TR6 Trailer for our TR6 Triumph 24
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
charlie74 ‘74 1/2+ TR6 Spotted 0
