Front hub & rotor removal
Pablo
Hi all,
Just found this site - what an excellent resource? Anyhow, I have a question to ask: How does one remove the front hub and rotor from the hub assembly (in order to get at the wheel bearings)? It looks like I need to get the bolts off from the rear (inside??) but can't figure how...
Thanks in advance and looking forward to posting more questions!
~Pablo
Ed Kaler
w. scott brunkhurst
I am assuming that you have already removed the brake caliper. To remove the hub and rotor you must remove the grease cap from the hub. If this is a wire wheel hub you may need to make a puller for the threaded stud on the grease cap. Under the cap you will find a large hex nut held with a cotter pin. Re-bend the pin so that it is straight. You must now find the hole in the side of the hub so that the pin can be pushed through. This is on the wire wheel hub. There is no hole on a disc wheel hub. Remove the pin. Now you have to find a hex socket big enough to fit the nut and I can’t remember what size that is. Remove the nut and the thrust washer. Be careful of the shims behind the thrust washer. They may be stuck to the thrust washer or to the face of the outer bearing. They are delicate. Remove the hub with a suitable hub puller. The hub may come off by pulling on the rotor by hand. If you are doing both sides of the car don’t mix up the bearing rollers. If they are in working order they must go back in their respective races. Reinstalling the hub is another fun game. If anyone sees something missing in this, please correct me. Remember, cleanliness is next to Godliness.
SB
w. scott brunkhurst
SB
ThomP
Here is some good wheel bearing info. This is posted on Jim Werners web site: https://members.aol.com/bgahc/02_jwha_wheelbearing.html
If you want to work on your car yourself and don't own a Healey maintainence manual and Norm Nocks Tech notes , I recommend you invest in both of these items they are worth the money.
Good luck
[ 11-09-2002: Message edited by: Basil ]</p>
droy
Hey Thom,
How and where can i get a copy of Norm's Tech notes. Sounds like a good book to have a round.
Thanks
Don
droy
Hey Thom,
Thanks
Don
droy
Hey Thom,
Thanks
Don
Dave Russell
Yoda - R.I.P
Don,
I sometimes get multiple posts also.
You can remove your unwanted posts by clicking on the pencil & pad icon at the beginning of the posts. This will take you to a screen with "delete post?" check the box & proceed. Extra post gone.
ThomP
Don
Intelligent, beautiful women usually make me stutter like that!
Carlbanan56 MGB Front hub MG 4
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
A BN7 Front Hub Stud Nuts Austin Healey 5
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K TR2/3/3A Front Hub and Felt Seal Triumph 1
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
MikeAH100M 100 Front Hub Spacer/Distance Piece Austin Healey 2
warwick-steve Missing grease cap in front hub Austin Healey 8
warwick-steve Front hub bearing grease repacking Austin Healey 28
K TR2/3/3A Front hub oil seal Felt? Triumph 1
K TR2/3/3A Front wheel hub "felt" again? Triumph 2
K TR2/3/3A Front hub wheel bearing nut? Triumph 1
aero3113 Front Hub Inner Bearing Seal Austin Healey 7
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
Jeepster Front hub replacement. Austin Healey 34
R TR2/3/3A front hub seal options Triumph 9
Bob_Spidell Securing Front Hub Bolts Austin Healey 8
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
C Front Hub Castle Nut Austin Healey 8
B TR2/3/3A TR3 Front Hub Felt Seal questions Triumph 2
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
R BJ7 front hub shim question Austin Healey 18
catfood Removing front hub Austin Healey 6
RAC68 Calculating Front Hub End-Play Austin Healey 32
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
bertl Front Hub Spacer Kit Triumph 1
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
BillD Front hub puller Spridgets 21
H front hub removal Austin Healey 37
6 front hub options... Triumph 4
S Spitfire Question on front Hub for a triumph Spitfire. Triumph 4
pkmh Dismantling BJ8 Front Hub From Caliper Disc Austin Healey 20
Willie_P TR 3/4 Front Hub Install - question Triumph 15
J Front hub mystery Austin Healey 0
britndablood To install or not to install Front hub spacer Austin Healey 8
Lon_S What hub puller tool works well for the front hub? Spridgets 2
TR4nut Front Hub Felt Seal - Old vs New Triumph 15
D Need a front hub Austin Healey 1
S Front Hub Replacement Austin Healey 7
G Front hub Spridgets 2
TonyPanchot tork settings for 1997 front hub Jaguar 1
TR3driver Front hub balance problem Triumph 17
M Front hub worn out Spridgets 6
Monark192 MGB-GT 67 GT front hub removal MG 10
drooartz Front hub/brake question Spridgets 12
Jim_Gruber Castle Nut on Front Wheel Hub Spridgets 6
B TR2/3/3A TR3 front bearing/hub advice needed Triumph 6
19_again front hub removal MG 3
