2500M Carb Conversion
ralph_s
Need some add'l opinions on this. I've got the opportunity to switch out my 175CD ZS carbs on my stock 2500M w/ a set of HS6 SU's. My ZS carbs are fine, but I'm a fan of SU carbs and understand them. Is there any performance gain to be had w/ the switch to SU's or am I wasting my time & money?
I do have other places to waste my T&M if this doesn't work out....lol
Nigel_TVR
I don't believe there is any performance gain with switching to the HS6 carbs. I'm a fan of the 175s and the Stroms have proven trouble-free. Any clearance issues with switching to the SUs?
R
ralph_s
Good question on clearance. I think I'm OK, but need to verify, thanks. I'm more partial to SU's but haven't had issues w/ the ZS carbs.
May just leave well enough alone and not fix it if it ain't broken. But as I need to pull off the carbs to get the exhaust manifold jet hot coated was just thinkin'........
Bob60
Member
Speaking of carbs, I have thought about switching to SU's to try and cure a starting problem I have.
When I start my 2500M from cold, it starts right up. When it's up to temperature and I shut it off and wait about 5 minutes or so it is very hard to start and requires a lot of cranking to get it going. If it sits long enough (30-40 minutes) it starts right up. Once started, runs strong and smooth.
Determined that fuel seems to dribble out of the main jets after switching off and puddles by the butterfly, thus, I believe causing a slightly flooded situation when warm. I've tried:
- Carefully adjusting the float levels
- Carefully adjusting the temperature compensator valves
- Pinched off fuel line after shutting down to make sure it's not residual fuel pressure
- Installed aftermarket heat shield with additional heat shield material added
- Completely replaced carbs with a set of non-emission 175CD's that I bought at a flea market and throughly rebuilt (carefully adjusting float level) - absolutely no difference.
- Replaced coil (just to make sure it's not the coil getting too hot)
- Replaced plugs, wires, cap, cond. etc.
- Obviously, adjusted valves, timing, the usual stuff.
Has anyone else ever experienced this?
Incidentally, I understand the float bowls on SU's sit at a slightly incorrect angle when used on the TR-6 engine to permit smooth functioning of the float and must be modified slightly or a set of SU's from a certain Triumph sedan used. Anyone have experience with this?
'73 2500M
gtemkin
My '74 2500M has HS6 installed by a former owner. I did rebuild them over the winter and I'm running BAE needles now.
Your symptoms do sound like vapor lock induced flooding but you sure have gone through almost all the right diagnostics I can think of. Is there any possibility that the venting of the float chambers is plugged. I'm guessing that those would normally be routed to the charcoal canister. Might pay to leave those lines open for a test.
If you go with HS6's, check out a post I made a while ago that you'll want to be aware of. You really must use the SU Insulator Block or risk a vacuum leak. Go here to see what i'm talking about.
https://www.britishcarforum.com/bcforum/u...trom#Post771993
I fixed the float chamber leveling problem by installing SU part numbers AUD1071 and AUD1070 float adadpters. I forget which one was on the front carb and which one was on the back carb but they're both level now.
By the way, ordering from SU in England was a breeze and the parts came within a couple of weeks.
Oh, and one more thing. I was able to install a standard TR6 air cleaner assembly to the HS6 setup. I had to make some small adapter plates which are almost invisible. Makes the installation look very factory. If you're interested, I can post some photo's.
Gregg
'74 2500M 3111TM
R
ralph_s
Thanks all for the info. I think I'll keep the ZS carbs on the car as there is nothing to gain by a swap. I'll save the $$'s for the jet hot coating on the manifold.
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
C My 2500M progress/questions thread TVR 5
bravenrace WTB - TVR 2500M TVR 0
bravenrace For Sale 1974 TRV 2500M FOR SALE Other British Classifieds 2
A 1974 2500M Spring Rates TVR 6
J Looking for a 2500M TVR 0
S 2500M or Vixen wanted TVR 0
B 77 2500M Shocks TVR 0
O TVR 2500m weatherstrip source needed TVR 2
J 1973 2500M ignition issue TVR 8
Z Just Restored 1973 TVR 2500M, Barn Find TVR 25
T Tvr 2500m For Sale, Nice Original Solid Example. TVR 1
M TVR 2500M Triple Weber 40 DCOEs TVR 130
Jastx TVR 2500M tires - what are you running TVR 7
TRclassic3 2500M Heater cable TVR 1
TRclassic3 Flasher units 2500M TVR 3
Kirk_Fisher 74 2500M prices TVR 9
TRclassic3 2500M rear suspension TVR 5
TRclassic3 2500M sun visors TVR 11
R 2500M Overdrive options TVR 13
Kirk_Fisher 2500M V8 on Ebay TVR 2
R 2500M Vents TVR 3
TRclassic3 2500M carpet kit TVR 1
R Windshield for a 2500M TVR 3
TRclassic3 Tranny removal 2500M TVR 10
R A fan of 2500M's!!! TVR 3
B 2500M chassis tube question TVR 2
R 2500M Cooling TVR 1
B 2500M search TVR 5
R 2500M Battery TVR 0
M TVR 2500M Model TVR 4
R Ignition Circuit - 2500M TVR 0
G Parting out a 2500M - Should I do it? TVR 18
Mickey Richaud 2500M on Ebay TVR 4
J TVR 2500M Shop Manual TVR 9
G 2500M hood TVR 3
G Gas tank for a 2500M TVR 5
H How to Remove Sunroof on 2500M? TVR 0
H How to Remove Sunroof on 2500M? Restoration & Tools 5
H Door Panel Removal on 2500M? TVR 4
H Photos of My 2500M's Engine and Radiator TVR 9
H Steering Column Binding in 2500M TVR 5
H 2500M Features and Stuff to Fix TVR 2
H Owners Manual for 2500M? TVR 3
H 2500M Came Originally With Electric Cooling Fans? TVR 19
H Bad Tach in 2500M TVR 0
AngliaGT 2500M on craigslist TVR 4
bravenrace Ebay 2500M race car and TR-6 Engine TVR 9
bravenrace 2500M Header Info Needed TVR 1
bravenrace 2500M on Ebay TVR 5
