TR2/3/3A TR3 seat patterns
jwolff
Hi,
I saw a recent post where someone mentioned having a seat pattern for a TR3a... does anyone have a seat pattern for a small mouth TR3 or know where I might find one? Thanks in advance!
J
jwolff
by the way, my seats had been recovered with non original all pleated white vinyl, so unfortunately I can't use the originals to make a pattern. thanks
TomMull
jwolff said:
Thanks for the link.
Excellent link I agree but note that the patterns are for post 60000 TR3s. Do you still need patterns for the earlier seats? Tom
J
jwolff
Hi Tom,
Yes I am still looking for the correct patterns for the early style seats. This link does give me a good idea of the process and what I will be getting into though.
thanks!
apbos
BCF
Here is a little more info on sewing your seats. I can may be get some pictures for you at the local show this weekend, that might help making patterns. sewing them is not that difficult, it does require a good machine. They are available for very little on Craigslist. Look for pre 1980's solid steel machines and reviews of those machines online.
Paul
J
jwolff
Thanks, looks like great information! A co-worker has a couple of high end sewing machines and has offered to give me a hand if I can come up with a pattern. I might need to see if there are any local small mouth 3 owners in my area that would let me take some measurements.
TomMull
jwolff said:
Hi Tom,
thanks!
You have a PM. Tom
jcarr123
Reviving an old thread here but it's the only reference to early TR3 seat patterns (vertical pleats) I could find.
So I'm sewing my own upholstery and need some basic dimensions for the bottom and back pleat layout.
-How wide are the pleats, are they the same for the bottom cushion and back?
-How wide is the seat bottom at it's widest dimension?
-How wide is the "horseshoe" shaped piece of material that surrounds the pleats on the seat bottom and back? It looks like it varies some, maybe just a measurement in a few spots.
I couldn't do this work without this Forum! Thanks
Jeff
TS20857LO
J TR2/3/3A TR3 Rear seat Triumph 11
B Wanted TR3 seat frames repairable Triumph Classifieds 1
T Wanted TR3 Seat Frames and Seat Rails Triumph Classifieds 3
tr3guy TR2/3/3A New TR3 Seat Rail Glides Triumph 3
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
A TR2/3/3A Tr3 Seat Belts Triumph 3
T TR2/3/3A TR3 Seat Questions Triumph 10
M TR2/3/3A 1956 TR3 ocasional seat Triumph 10
Tinkerman TR2/3/3A 1960 tr3 a seat tack strips Triumph 19
luke44 TR2/3/3A TR3 Which Seat flips? Triumph 11
B 60 TR3 Seat Belts Restoration & Tools 0
B TR3 seat frame issue Restoration & Tools 2
M TR2/3/3A TR3 seat rebuild Foam VS Springs Triumph 7
mountainman TR2/3/3A TR3 Rear Seat Triumph 3
mountainman TR2/3/3A TR3 Back Seat Support Brackets Triumph 3
E TR2/3/3A TR3 seat track width Triumph 10
M TR2/3/3A TR3 Seat Rails Triumph 10
MGTF1250Dave TR2/3/3A TR3 Optional Rear Seat Triumph 22
R TR2/3/3A TR3 seat belts Triumph 7
CCURTISS Removing Seat Track Screws TR3 Restoration & Tools 3
PeterK TR2/3/3A TR3 seat rebuilding with foam. Triumph 4
fad64b TR2/3/3A TR3 seat back padding? Triumph 1
AngliaGT TR2/3/3A 3 Seat TR3? Triumph 25
fad64b TR2/3/3A TR3 seat redo Triumph 17
martx-5 TR2/3/3A Seat Belts in TR3 Triumph 41
TRclassic3 TR2/3/3A TR3 seat comfort Triumph 3
D TR2/3/3A TR3 seat rebuild Triumph 11
bluemiata90 TR2/3/3A tr3 seat slide rail locations Triumph 3
martx-5 TR2/3/3A Problem with TR3 Seat Triumph 9
