1500 Fuel Pump
N233TX
The engine-driven fuel pump on my '75 Midget seems anemic. Engine runs OK but stumbles when you jab the throttle at lower RPMs. The amount of fuel entering the clear plastic filter upstream of the carb is just a dribble, even at higher RPMs. Shouldn't the pump fill it up at least halfway? Couldn't find a test for the pump in the manual and there is no obvious leakage under it. Looks like it is replace with stock or ???
I have a nice Facet 4.5 PSI pump which I replaced on my plane. Would this be a good in-line, full-time boost? Carb is a Weber with bowl and floats. TIA
Jim
South Texas
dklawson
The only way I know to determine pump output is to bring the engine to temperature and make sure the float bowl is full. Stop the engine, disconnect the fuel line at the carb and point it into an empty container. Start the engine and collect the fuel for a measured length of time. Measure the fuel pumped and divide by time to see what your pump is delivering.
With the clear filters it is sometimes hard to see how much is really moving through so I wouldn't get too bothered until you measure the flow.
Facet pumps are certainly OK. I don't know what pressure a Weber likes. The SUs and Strombergs prefer a bit lower (2-3 PSI) and would benefit from a pressure regulator with your Facet. If you decide to install it, remove the mechanical pump and fit a cover plate to the block. Find a way to mount the electric pump low and at the rear. More info on this will be available if you use the search feature for old fuel pump threads by "Big Jones". He did this conversion recently.
bigjones
Bronze
Jim,
As Doug mentioned, here is the thread .
I would suggest finding out the pressure required by your Weber and finding a suitable pump. In other words, not installing a regulator - just something else to install/leak/fail.
The only slight problem is you'll have to cut the fuel line as it comes out the tank (to install the pump). I received lots of good advice in the thread and the car is running fine.
Cheers!
aeronca65t
I have a similar low-pressure facet in my MGB with a Weber DGV (you haven't said if you have a sidedraft or the downdraft DGV). It works fine without a regulator, but the pump is noisy. I'd agree that deleting the mech pump and blanking off is the way to go.
I'm not a fan of the DGV and intend to swap it for proper SU carbs when I get a chance. At which point I'll run a pressure regulator set around 2 to 3 psi.
I'm also running a Facet in my race car (SU carbs) also with a pressure regulator set for 3 psi. If you decide on a regualtor, buy the better Holly unit (they're available at Summit Racing).
By the way, Welcome to British Car Forum!
N
N233TX
Yessir, it is a downdraft. I plan to fabricate a cover plate for the stock pump and mount the boost pump FWF in an insulated box to hopefully hush it up some. I have a regulator if needed. The fuel flow test seemed inadequate but lacking a benchmark, I'm goin' with the electric pump. Car is light years away from stock.
F Spitfire Spitfire 1500 Mechanical Fuel Pump & Spacer Triumph 6
regularman What was wrong with the 1500 mechanical fuel pump? Spridgets 20
bigjones The 1500 mechanical fuel pump Spridgets 21
RobSelina Fuel Pump Upgrade on 1500 Spridgets 19
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
J 1500 mg midget fuel issue Spridgets 2
Morris 1500 fuel tank Spridgets 4
Morris Midget MK1 fuel tank in a 1500? Spridgets 24
P Fuel for 1500 Spridgets 20
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
P Pristine MG TF 1500 Spotted 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
