Clutch Travel
Cujo
Member
Any suggestions on raising the point at which the clutch engages - have rebuilt both the slave and master cylinders and clutch still only engages right at the bottom of the pedal travel.
Deleted member 8987
This is a 70...right?
Didn't they got to "self adjusting" by then? As in, no adjustment on the rod from the slave?
If so, you didn't perchance stick a return spring on the arm, like on earlier units, did you?
Sarastro
Make sure you're getting a full stroke at the master cylinder. I don't know what car you have, but on the bugeye it should be at least about a half inch. You can adjust this with the pedal-stop adjustment, then make sure that the pushrod has only about 1/16" slack when the pedal is in its rest position.
bthompson
I had something similar happen: make sure there's no slop in the pedal linkage. If the clevis pin is even a <span style="font-style: italic">little </span>loose, the geometry of the lever will put the pedal almost on the floor before the master cylinder rod even moves.
Take off the top of the pedal box and look at the levers move -- if the clevis' holes have elongated over time, your problem may be more mechanical than hydraulic!
Solutions are many: re-drill the holes for a larger clevis, or weld the hole smaller and drill it out so the clevis is tight again. I cut a small strip out of a tin soda can and made a lil' bushing in the clevis hole, which has worked great for me. Went from pedal on the floor to engaging within the first inch of travel. :thumbsup:
C
Cujo
Member
Will check that as I definitely have travel in the rod before it engages the master. And sorry - it is a 70 and no spring.
Thanks
Sarastro
One more thing--make sure the clutch is well bled. You may be aware that these are notoriously difficult to bleed completely.
It's important to remember that, as long as the clutch is well bled and of course not leaking, the hydraulics aren't the issue any more. A certain amount of movement at the MC will give a certain amount at the slave. End of story. The rest of the mechanics are the issue. Anything that limits movement, like looseness, can be the problem.
I had this problem for years, and finally solved it after thinking it all out correctly. My clutch (err... my CAR's clutch) now engages very nicely in the middle of its travel. The key was to get the pedal stop in the right place--the shop manual provides very little guidance on this.
Deleted member 8987
Reason I asked on the spring...seen it done.
With no adjustment rod, the piston is supposed to "float" with the TO bearing just off the plate fingers. Put a spring on, sucks the piston to the bottom of the bore, and you've got no clutch pedal.
Lukens TR2/3/3A How much travel at the clutch slave? Triumph 12
Scotsman Adjusting clutch pedal travel Triumph 2
D Clutch slave travel Triumph 12
T TR6 tr6 clutch travel saga Triumph 1
1 T-Series Clutch pedal travel and point of engagement MG 5
bighealeysource Clutch pedal travel in BJ8 Austin Healey 7
O Clutch Slave Cylinder Travel Triumph 5
G 67 Midget Clutch travel.. one more time... Spridgets 3
G How much clutch travel? Spridgets 5
AUSMHLY clutch pedal travel Austin Healey 3
B clutch travel Triumph 5
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Clutch Master Cylinders? Triumph 1
