V12 bellhousing Dimensions?
erikred
Anyone know where I can get the dimensions for the engine to bellhousing bolt pattern for a Jag V12? I would like to make an adapter plate to use a GM transmission.
Thanks,
Erik
Administrator
Boss
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by BCanon:
I believe John's cars has a kit to do that, but I can't find the link right now.<hr></blockquote>
Would you believe
www.johnscars.com
Administrator
Boss
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by erikred:
Thanks,
Erik
<hr></blockquote>
Contact Dan Mooney at Classic Jags. If he can't help nobody can! (Let us know what he tells you i.e, is it even possible?)
basil
Hal Kritzman
John's Cars is a specialist in making complete kits to lump an American V8 and transmission into Jaguar S2 and S3 (S4?) sedans and with some additional mechanical work even into E-types. I don't believe he has any need to produced an adapter plate to mate a Jaguar engine to a GM transmission since its the Jaguar engine he advocates replacing in the first place. Am I wrong?
Administrator
Boss
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Hal Kritzman:
<hr></blockquote>
Dunno, but it would be easy enough to ask him.
E
erikred
Well, https://www.vintagejag.com sells the adapter I am looking for, but it cost $297. The above mentioned business also sells 6 cylinder and standard trans. adapters but they are all close to $300. I would rather have one made for me at a machine shop for <$100, all I need are the dimensions for the Jag side.
Thanks for the replies,
Erik-
AngliaGT Interesting Article on the V12 Jaguar 0
P For Sale v12 carbs Jaguar Classifieds 0
T 1993 xj v12 red hot catalytic converter Jaguar 6
Paulus Thermovacuum switch for a 1973 V12 XKE Jaguar 4
drambuie Check out this Healey 100 with a Jag V12 convertion [click on the british v8 link] Austin Healey 5
CJD Valve shims on V12 Jaguar 19
P E Type V12 PCV & Smog systems Jaguar 8
V IRS selling a '73 XKE V12 Roadster Jaguar 0
B Looking for a Jaguar E-Type S3 V12 - LHD A/C unit Jaguar 0
1965_MGB XJS V12 Junkyard Sighting - West Palm Beach, Fl Jaguar 1
nissanite E-Type V12 very low oil pressure - new rebuild Jaguar 11
E 1990 XJ-S V12 Front Brake Locking Jaguar 5
Tullamore V12 E-Type Valve Covers Jaguar 10
equiprx 94, xjs 6.0, v12, coupe FF44 code Jaguar 2
Tullamore Custom V12 E-Type Project Jaguar 1
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
Tullamore Zapped V12 E-type Jaguar 9
W new shocks for jag xjs v12 ? Jaguar 3
Rick60 E-Type Series 3 V12 distributor Jaguar 5
Wray XJS Coupe V12 Jaguar 11
PAUL161 So You Want A V8? How About A V12 MG 5
J V12 Marelli Ignition Jaguar 12
D v12 top hoses??? Jaguar 4
D xjs v12 tire wear Jaguar 1
A Stretching the V12 Jaguar 5
D 1991 xjs v12 irs oil leak& hot diff Jaguar 8
A V12 block cast date * 1st post * Jaguar 6
Sherlock Jaguar V12/1932 Ford Hotrod... Other British Cars 5
D 1991 xjs v12 strange pipe Jaguar 1
D grinding noise on 91 xjs v12 Jaguar 5
D 1991 xjs v12 high idle speed. Jaguar 8
D 1991 xjs v12 ,smell of fuel. Jaguar 4
G Looking at a 1988 XJ-S V12... CARFAX anyone? Jaguar 1
T Erratic idling v12 xjs Jaguar 2
Sergio MGA MGA 60 ROADSTER WITH BIG HEART JAG XJS V12 MG 6
Sergio MGA 1960 WITH A BIG HEART XJS V12 Jaguar 10
D Modifying the Jag V12 engine. Jaguar 3
J 86 XJS v12 fuel pump problem -Help! Jaguar 9
B Fuel leakage at carby on V12 Jaguar 4
K V12 Engine Fires Jaguar 8
J Spotted a V12 yellow XKE coupe yesterday at gas station in NJ. and thought maybe??? Jaguar 2
Rick O. V12 E-Type; Should I? Jaguar 6
L Upgrades for a V12 Jaguar 1
J V12 Door on 68 E-Type OTS Jaguar 7
M XJS V12 Cruise Control Jaguar 3
M V12 Jaguar 3
M How Do I Set Timing On 1990 Marelli Ignition V12 after reinstalling distributor ? Jaguar 0
R XJS V12 Problem Jaguar 5
T extra cooling for e-type v12 carbs ... Jaguar 1
E Any V12 Mods? Jaguar 2
