timing chain to gear drive?
rikiwho123
does anybody know of a gear drive to replace the timing chain on the spitfire 4 cylinder i have looked every place i could and found nothing ?
Roger
Bronze
If you replace a chain drive with a gear drive your camshaft will go round backwards.
TR3driver
Great Pumpkin - R.I.P
Only if it doesn't include an idler gear.
That said, I've never heard of one made specifically for a Spit.
rikiwho123
rikiwho123
i had one on a 283 chevy motor and it made the timing spot on ;but thats ok i can live without one.
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
K TR2/3/3A Timing chain rattle on start up? Triumph 2
LAW75 Timing Chain Cover Gasket Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
D TR2/3/3A Timing chain tensioner. Triumph 3
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
D BT7 Timing chain install Austin Healey 2
M Timing Chain on 948 Rebuild Spridgets 1
R General Tech Timing chain replacement Triumph 5
RJS TR4/4A Timing Chain Oil Seal Triumph 6
B TR2/3/3A Timing chain cover goop location Triumph 4
B Timing chain tensioner help Austin Healey 15
G Timing Chain - Slackend Austin Healey 5
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A timing chain cover and woodruff key Triumph 4
G TR4/4A timing chain and sprockets Triumph 9
DanLewis Looking for a good timing chain cover Spridgets 1
B Timing Chain Tension Ring for BN2 Austin Healey 5
J TR2/3/3A Timing chain pin Triumph 1
L 100 timing chain worn? Austin Healey 7
mt10flyer TR2/3/3A Timing Chain Tensioner - 1959 TR3 Triumph 32
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
T Timing Chain Wear? Austin Healey 5
J TR2/3/3A TR3A Timing Chain Seal and Gasket Replacement Triumph 7
RJS Timing chain oil seal Triumph 12
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
Geo Hahn Timing Chain Noise Triumph 25
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
TulsaFred Timing chain Spridgets 22
6 timing chain sprocket Triumph 5
Darrell_Walker Timing chain tensioner wear Triumph 8
6 timing chain cover Triumph 4
bugedd Anyone have a timing chain cover? Spridgets 10
eschneider TR2/3/3A TR2/3/4 timing chain tensioner Triumph 4
M TR4/4A tr4A timing chain procedure? Triumph 9
c5racer 1500 Timing Chain Upgrade to TR6 Spridgets 1
W TR6 TR6 Timing chain oil seal question Triumph 3
doughairfield Install oil seal timing chain cover Triumph 9
doughairfield Timing chain sprocket to camshaft Triumph 9
T TR2/3/3A tr3 timing chain question [master link] Triumph 2
