TR2/3/3A TR2/3/3A Steering Box Mod
Geo Hahn
I've just installed a modified steering box cover to the TR3A and what a difference it makes. Mine had just enough wear on the steering gear that I could not get rid of the excess play w/o causing some binding.
The modified part uses a spring-loaded pin in place of the solid adjustment screw so pressure is maintained on the rocker shaft assembly yet there is enough give to eliminate binding. Now I have almost no play in the wheel yet a normal 'rebound' when coming out of a turn.
The part is available from Herman van den Akker handhvan@msn.com for $65 + shipping. Herman will need your old top plate for a core... the replacement is a modified original steering box cover. Looks almost identical to original, the only difference is a 9/16" adjustment screw instead of the original 7/16" as it has to be machined out to accept a spring & plunger.
No financial interest -- just a satisfied customer.
bluemiata90
I'm glad to hear someone has installed and enjoys this steering box improvement. I'm in the process of restoring my TR3 and read about this spring loaded steering box cover in the TR3 performance book. I purchased one from RevingtonTR, but as of yet have not installed it. I'm very happy to hear it's an improvement. For those who don't want to send your cover away, Revington sends complete units without exchange. Also, depending on currency exchange rates, I bought mine last spring for 53.00 including shipping. I don't know what the price would be at this time.
I'm looking forward to seeing the difference in steering.
trrdster2000
Geo, glad it worked out and as they were just around the block from you made it a lot easier. When I take down the steering in the Roadster this winter I will send mine off. Thanks Wayne
Russ Austin
About 4years ago I tried Revington's spring loaded top plate, I believe I had to much wear in the box to do any good. I had about 2" of travel left to right. So I went ahead an added R&P and could'nt be happier.
Geo Hahn
Geo Hahn
Seems to be $88+ w/o VAT or shipping from Revington. Given the current exchange rate, now is not a good time for US owners to be obtaining parts from the UK.
trrdster2000
Geo, it's not so much the price, but the postage for a larger item. Today I got the postage for my complete grill for the Roadster, 92 pounds (about $170), 12kg, somewhere between 26 and 30 pounds of weight. It was a used grill, but happy to find one since the chromer put mine on a 10 horsepower buffer and rapped it around the wheel, all it had was a few scratches around the radiator cap, what were they thinking??? Wayne
eschneider TR2/3/3A source for TR2-3 steering bearings? Triumph 7
Mark_Gibson TR2/3/3A Tips on Removing TR2 Steering Wheel/Head Unit Triumph 14
Nanhook TR2/3/3A TR2 shoes Triumph 2
CJD TR2/3/3A TR2 Annual Triumph 6
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
S Wanted tr2 original grill Triumph Classifieds 10
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
S TR2/3/3A tr2 muffler clamp Triumph 10
Southwarks TR2/3/3A TR2 door help! Triumph 2
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
A Wanted Girling Axle for TR2 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
S TR2/3/3A tr2 Triumph 18
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
P New member TR2 carpets Triumph 7
S TR2/3/3A Tr2 hood Triumph 8
W TR2/3/3A TR2 wiper motor mount Triumph 1
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
P TR2/3/3A TR2 color questions Triumph 23
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
CJD TR2/3/3A TR2/3 Guru Final Exam Triumph 59
R TR2/3/3A TR2 Scam Triumph 13
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
JFS TR2/3/3A TR2 Rear Plate Lite on TR3A Triumph 10
