Spitfire Pacesetter/Monza Exhaust on 69 Spit
Jorgen
Does anyone have any underbody pictures of this exhaust on a spit. Mainly the rear mounting areas. I bouught an exhaust that was installed on a "project" that had gotten a new owner who was almost done putting a hemi into the car. He obviously coulnd't use this exhaust on the car with taht motor and sold it off to me <span style="font-style: italic">cheap</span>. Now I am trying to work on installing and was looking for info on how others mounted this this, there doesn't see to be much worthwhile near the mounts on the system to conned to.
Thanks to anyone who can help.
Scot
GregL
Hi Jorgen, I have the Monza exhaust on my TR6. It is a newer style and has resonators forward of the mufflers. It's louder than stock, but not as loud as what some people have said of the past systems. The alignment of the hangers is pretty poor, and requires some creativity on your part or your muffler shop. So far I am happy with the system, not the installers in my area, but that is another story.
71MKIV
The monza requires hangers through the boot floor as mentioned. Lots of cut and fabricate.
Go find the quietest glass pack you can find and put it in the middle of the long pipe under the car.
Mine I bought cheap, found out it was cheap because it was missing the muffler for the center of the car. It was truly awful, going down the road it sounded like it had a severe gastroinstestinal problem.
S
suggs
"Monza" must be the worst, noisiest exhaust silencers in the world.
Don't even think about it, your ears will be ringing for weeks and they give zilch extra power.
J
Jorgen
That is about what I expected. I just wanted to check if there were better lest floor destroying options that I whould consider. As for the sound level, I think I'll like it. Something I will likely drive only a little bit a year and will likely sell within a year or two I will be able to handle it. The stock exhaust was trash so it had to be replaced adn well $50 for this ust couldn't be passed up.
Don_R
I think my 73 has muffler hangers at the rear that the monza will mount to with a little mod....I'm running the stock exhaust till it rots off then I'll make the switch.
J
Jorgen
I got it mounted up yesterday. When I did a trial fit the exhaust stuck out about 8 inches past the rear of the car. I cut it and put it back together so it is lined up perfectly in the rear. I am very happy with the fit and look so far. Need to bleed the brakes and I can pull he off jack stands and see how it sounds.
J
Jorgen
Eh can't be any louder than what a was "running" before the few time I have driven the car (around the block). The broken off (previous owner didn't do a few things right) about 5 feet from the exhaust manifold and blowing straight out at that point. If it ends up tool loud I will just toss a tube muffler or glass pack in there.
71MKIV
I do like the look of the monza tips sticking out the back. Just need to shut them up.
Trevor Triumph
I have the Monza system on both Spitfires. I don't mind the sound, even on long trips- notice I did not call it "noise." My concern has been the film of exhaust on the back of the car. I added the bracket in the boot floor- no problem. On one our club member let the pipes extend farther and has the bracket bolted on the rear valance.
T.T.
GregL
I did 150 plus miles in Ginger this morning. Went to visit poolboy. It wasn't that loud, my ears aren't ringing, but she does get looks from people on the side of the road. Remember though, my Monza system came with glass packs/resonators, forward of the mufflers. Poolboy likes the sound too.
W Good price on Pacesetter Monza Muffler Spridgets 0
J has anyone used pacesetter headers and monza exhau Triumph 2
johnrip Wedge TR7 pacesetter header connection to stock exhaust Triumph 2
A Dual SU carbs pacesetter exhaust MG 0
S Pacesetter Header Spridgets 11
eejay56 Pacesetter header plug Triumph 6
Mark Jones Pacesetter header - any good? Triumph 9
J pacesetter header? Triumph 11
Brosky Pacesetter Headers Yes or No? Triumph 13
Morris Pacesetter Headers again Spridgets 1
Morris Pacesetter Header Spridgets 4
maxwedge5281 monza fuel filler door??? Austin Healey 6
C TR6 Monza Exhaust Triumph 10
jfarris TR2/3/3A Wanted - TR3 Monza Muffler - Rear Section Only Triumph 1
I TR6 Opinions on Monza exhaust needed Triumph 21
steveg [OFF] Great Leno Garage vid driving Alfa 8C 2300 Monza Replica Austin Healey 1
TRclassic3 TR2/3/3A TR3 Monza Exhaust installation Triumph 2
apbos Monza fuel cap - How do I remove it? Spridgets 16
Patrick67BJ8 Monza & Falcon Exhaust Selection Austin Healey 19
aeronca65t Monza-1960 Racing 2
R Monza Exhaust System Austin Healey 0
rjc157 monza exhaust Austin Healey 1
S Monza Muffler Spridgets 14
T TR6 TR6 Monza exhaust - all that and a bag of chips? Triumph 41
M Monza Exhaust for a 1500. Good Idea? Spridgets 7
W Monza Performance Muffler Spridgets 65
B I stink!! aka Monza exhaust Triumph 19
healeyboz Monza Exhaust Spridgets 30
zimmy monza muffler Spridgets 6
A TR6 Monza mufflers??, Borla?? [tr6] Triumph 11
hondo402000 TR6 Monza exhaust modified for TR6 Triumph 0
Ed Kaler Monza Exhaust Sys. Triumph 5
1 Q about Monza mufflers and install MG 22
johnrip Wedge tr7 monza exhaust question Triumph 3
G For those with a 6 and a Monza exhaust Triumph 10
jmayled Monza Exhaust Performance with Stock Headers? Triumph 12
K Monza Muffler Spridgets 3
G video ferrari enzo in monza circuit Other Cars 0
J TR4/4A Exhaust a tad too loud... Triumph 4
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
