TR2/3/3A TR3 clutch slave cylinder
TFB
I didnt get a slave cyinder with my car,and have seen 7/8" new repalce ments and 1" bore "original type".
Was the bore originally 1",and are the 7/8" a suitable relacement?
Thanks
Tom
TR3driver
Great Pumpkin - R.I.P
The 7/8" will give you a softer clutch pedal, and more travel (possibly even so much travel that the clutch does not release fully). Unless that sounds attractive to you, I'd stick with the original size. The 7/8" cylinders are from later TR6, and they have all sorts of clutch problems.
Moseso
It's so rare for Randall to miss on one, that I just have to comment...
Smaller bore slave cylinder = harder pedal, longer excursion at the slave piston, more CLUTCH movement.
Larger bore slave cylinder = easier pedal, shorter excursion at the slave piston, less CLUTCH movement.
Worth mentioning, also, are the three holes where the slave rod clevis can attach to the clutch throwout lever. I found they're not all really usable, due to the angle that this can create where the rod enters the slave cylinder, but:
Lowest hole = easiest pedal, least clutch movement.
Highest hole = hardest pedal, most clutch movement.
Mine is in the lowest hole and there is PLENTY enough movement to release the clutch.
TR3driver
Moseso is, of course, entirely correct! I must've been tireder than I thought ... was thinking of what happens with a smaller bore <span style="font-weight: bold">master</span> cylinder rather than slave.
But I still feel this is a bad place to be making "improvements", since the stock setup works quite well.
Also, my opinion is that the hole in the lever should be chosen strictly to get the best alignment between pushrod and slave cylinder bore. Misalignment here will cause side force on the slave cylinder and lead to more rapid wear; plus the extra friction will tend to negate any advantage from the slight change in ratio.
luke44
Hi guys, see my other thread I have going on this topic. https://www.britishcarforum.com/bcf...tion-Adjustment-of-TR3A-Clutch-Slave-Cylinder
I just crawled back up from the car, I didn’t shorten the rod. My problem is I need to have the throw out bearing preloaded quite a bit before the clutch action disengages and allows easy shifting. Regardless of rod length the throw - ie amount of movement- has to be controlled by the fluid being displaced. It appears to be a 1” dia cylinder. Wouldn’t a smaller bore result in more movement?
ive been working the pedal with the boot off. The piston travel (system is well bled, good pedal feel) is about 5/8”. This just isn't enough to release the clutch unless I have the preload.
So so the idea of somehow getting more movement seems to be exactly what I need. Step one is to move to the center hole from the bottom one. That still isn’t enough.
And maybe step 2 is the longer throw slave cylinders? I honestly don’t know wht else to do. Could this be related to the faulty clutch master cylinders of a few years ago?
CJD
So, the next question is, what year/style master are you running?
Randall would know the actual diameters, but, from my limited experience...
My TR3A had a smaller MC diameter which went to the longer (and smaller diameter) slave cylinder.
My TR2 uses a larger MC bore and a fat, short slave.
Either of the above arrangements gives about the same throw, but if you mix a later MC with an earlier slave, you cut the throw.
luke44
I was also wondering if that’s where I should look, and not the slave.
In that regard, if I lengthen the master cylinder rod length will that cause more travel to take place in the slave when the pedal is depressed? It looks like I have a 1/4” of longer throw I can adjust in.
STeve 1958
My clutch engages at about half way. If you're at full pedal and not disengaged, there is something wrong. That 1/4" at the master cylinder will give you a couple inches at the end of the pedal, so I'd try that first. Just make sure you still get fully disengaged when your foot is off the pedal.
TR4nut
Jerry (texasknucklehead) may chime in on this - but beware using a longer throw slave. On a car he recently worked on clutch disengagement was a real mystery. Until he studied it and found the slave was actually moving too far and doing that the pressure plate was actually recatching the clutch disk. A real headscratcher until he sorted it out.
I believe the 3A master cylinder is 3/4", the slave is 1". Steve's thoughts sound good to me, especially if you've adjust to the specified free play at the slave.
luke44
Just to bring this thread full circle for those who may search later, I finally got everything working, with my original parts.
I moved the slave back onto the engine side of the mounting plate - the trans side mounting I'm pretty sure is for the TR2 Lockheed setup. Then after a full bleed, I selected the center hole for mounting the clevis instead of the bottom hole. That combination seemed to do the trick, albeit just barely, there is still a slight bit of fight mainly going into non syncro first.
I did speak to BPNW who make the extended throw slave. It's all about fluid displacement, so cutting rods etc really doesn't help you. They achieve the longer throw by going to a 7/8" dia bore, which moves the rod 30% further. So why would you ever need this I asked? He asked if I had a new pressure plate and clutch - yes. So the needed distance to disengage is at its greatest after all new parts. Then he asked if I'm using silicone fluid - yes. They believe silicone is more compressible than Dot 3-4, and hence needs a bit of a further throw. Add in the tolerance of all the repro parts today and there are enough variables that it may be right on the edge. All in all, it made sense to me. I'm going to order the longer throw slave - it's very quick to install so I'll know pretty quickly it's effect. As the car gets broken in, it should all come together. Thanks as always for the great feedback.
CJD
Thx for the update! My TR2 disengages in the last inch of travel. My Vette in the first inch. It drives me nuts switching between the 2.
Snowkilts
Hey, did you try the 7/8 bore slave? I just got my clutch back together with all new parts and I'm having a similar issue of the clutch failing to disengage.
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
K TR2/3/3A TR6 gearbox on TR3: re clutch slave adjustment. Triumph 13
K TR2/3/3A TR3 Clutch master and slave bleed issues? Triumph 5
T TR2/3/3A TR3 clutch slave and clevis Triumph 4
RedTR3 TR2/3/3A TR3 Clutch Slave Cyl Return Spring Size? Triumph 7
RedTR3 TR2/3/3A TR3 Clutch Slave Cylinder Adjustment Triumph 3
RedTR3 TR2/3/3A TR3 Clutch slave bleed screw size Triumph 4
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
S TR2/3/3A TR3 clutch release bearing... from Home Depot? Triumph 12
A TR2/3/3A TR3 Brake / Clutch Resevior & Lines needed Triumph 2
Lukens TR2/3/3A TR3 clutch issues Triumph 14
K TR2/3/3A Torque value for TR3 clutch cover to flywheel bolts....... Triumph 2
AHS TR2/3/3A TR3 transmission clutch fork & shifter removal? Triumph 5
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
K TR4/4A TR4/TR3 clutch operating shaft availability? Triumph 2
M TR2/3/3A TR3 clutch hydraulic line routing Triumph 2
mgedit TR2/3/3A Routing of Clutch and Brake Pipes from MC 56 TR3 Triumph 7
Moseso TR2/3/3A Clutch Swallows Air -- TR3 Triumph 32
K TR4/4A Can I fit a TR3 clutch plate&disc in a 4A? Triumph 4
TRclassic3 TR2/3/3A TR3 new clutch? Triumph 6
Kleykamp TR2/3/3A sticking clutch ??? TR3 Triumph 5
T TR2/3/3A tr3 brake/clutch reservior question Triumph 1
C TR2/3/3A New member and newbie question on TR3 clutch Triumph 26
K TR6 TR6 Trans in a TR3...What about clutch? Triumph 1
mgedit TR2/3/3A 56 TR3 Clutch/Brake Pedals Triumph 4
S TR2/3/3A TR3 clutch pressure problem - not a broken spring! Triumph 3
J TR2/3/3A TR3 Lockheed brake/clutch MC bracket... Triumph 11
bigjones TR2/3/3A TR3/4 clutch adjustment and shifting into 2nd Triumph 5
Moseso TR2/3/3A TR3 Clutch Slip Triumph 6
mrv8q TR2/3/3A TR3 Clutch Master Cylinder Triumph 20
H TR2/3/3A TR3 Clutch Advice Triumph 11
mountainman TR2/3/3A TR3 Clutch Release bearing Triumph 2
R TR2/3/3A TR3 clutch Triumph 2
M TR2/3/3A TR3 Clutch / Pressure Plate Triumph 2
Moseso TR2/3/3A TR3 Clutch/Brake Reservoir Triumph 4
martx-5 TR2/3/3A TR3 Clutch Pipe Triumph 9
CCURTISS TR4/4A TR3/TR4 Clutch Fork Install Question Triumph 8
Aldwyn TR2/3/3A TR3... Double Clutch or Syncromesh? Triumph 5
M TR2/3/3A TR3 clutch release bearing Triumph 3
S TR2/3/3A part numbers for tr3 clutch Triumph 8
S TR2/3/3A clutch set up for a tr3 Triumph 3
S TR2/3/3A tr3 freeway clutch Triumph 8
MGTF1250Dave TR2/3/3A TR3 CLUTCH FRICTION DISC REPLACEMENT Triumph 9
T TR2/3/3A TR3 Clutch Problem HELP Triumph 7
