When is the best time to install an antisway bar?
ichthos
I am just now starting to put together the front suspension in my Bugeye. The engine, transmission, and radiator are not back in yet. It never had an antisway bar before, and I have no idea how to install it. I just have few questions for now. When is the best time to install this? I bougth a used stock sway bar on Ebay a while back. Are there specific measurements that the antisway bar plates bolt to the wishpans? I really need to keep moving on putting this thing all back together, and I am hoping it is no big deal to add it later, preferably before I put the engine and transmission in. Any thoughts?
Thanks, Kevin
GeeBee1
Kevin:
You can do it later, actually you are better off with the chassis loaded. I am assuming that it is a stock later bar. I would just make sure your arms have the three wholes in them and one is left and right.
Pat
Dug
Kevin, do your A-arms have the holes in them now?
If not, I have a template I can email to you as a pdf should you wish.
Dug
JPSmit
December
preferably while the car is stopped.
Platinum
:lol: Thank you JP an' Mark! I thought this thread wuz gonna be all too seer-ious an' stuff.
livinginthepast
Install your bar when the wolfsbane blooms and the autumn moon is bright.
Your Welcome!
We are here all week- 4 shows daily.
m
JPSmit
SilentUnicorn said:
Your Welcome!
m
don't forget to tip your waitress
Brian_James
Dug
I would also like that template. I sent you a PM with my email address.
I have a question about mounting the sway-bar at the frame rails. What have people done to mount them on cars that did not originally have one installed?
Brian
GeeBee1 said:
Kevin:
Pat
Well, one of my arms IS a left and one's a right, but NEITHER have 3 (w)holes in them....BUT each has 4 fingers and a thumb and appear to be be OEM...guess I'll just have to live with them..... :laugh:
G
good material I'll have to pass on again due to respect for the board ....
gotta luv the straight man
m
I
ichthos
Brian, I have two Bugeyes that did not appear to have antisway bars originally, but both have four tapped holes for the mounting brackets. Have you looked underneath the rails to see if there are already holes for the mounting brackets?
Kevin
Brian_James
Thanks Kevin. I've looked and there are no holes. Maybe there is enough meat there to drill and tap. I was hoping someone who has done would chime in.
It must be raining in more places than just Houston since this place is looking a little like the Spridget mailing list. :smile:
Brian
I
ichthos
Let me know if you need to know measurements on where the holes are drilled or if you need a picture of this area. Hopefully someone will contribute that has done this before.
Kevin
JPSmit
While I don't know this to be true, others (notably Tony) would have chimed in right now and said you can't drill the A-arms for a sway bar as it would weaken them. According to him (and others) you either bought them with the holes drilled or didn't put on a sway bar but that they were either hardened or reinforced.
Once again I don't know this to be true - just sayin' is all.
Billm
The later pans WERE reinforced for the swaybars. I for one am hesitant to install a sway bar on non-reinforced pans but that is just me.
BillM
I
ichthos
I have seen the wishbone pans that were reinforced. The thickness of the reinforcements looks no thicker than a washer or two if I remember correctly. Why couldn't one just put one of two grade eight washer behind each bolt? I think Apple Hydraulics sells wishbones with the reinforcements. I wish I would have considered this when I had my wishbones rebuilt a few years ago.
Kevin
Platinum
I'm with BillM. The spring pans for the bar do have a re-enforced attachment point for the bar uprights. Tapered. It would be best to get the 'proper' ones if ya decide to do this, Kev. I would think the washers could allow the loads and stresses to cause them to shift and eventually crack the pan itself. Not worth the risk, IMO.
K Tricks or Best Way to Install Front Fenders? Austin Healey 14
T Wedge How best to install these in the TR8/ Triumph 4
Thor how best to install cowl side panel Spridgets 2
mctriumph TR2/3/3A the best kinda folks Triumph 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
tr6nitjulius For Sale "SOLD" Winter projects: Upgrades 4Sale or Reasonable Best Offer Triumph Classifieds 0
AngliaGT MGB-GT The Best Laid Plans....... MG 3
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
J Best Aluminum Fenders? Austin Healey 3
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
G Best fuel option for a 72 Midget Spridgets 5
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
JPSmit some days your best tool is a credit card Spridgets 2
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
D The best place to get shocks rebuilt. Spridgets 8
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
W Best source for Bugeye front shocks Spridgets 3
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
Bob Claffie Best cruise in of the year Spotted 8
longbridgehealey Best way in Austin Healey 2
B TR4/4A What really is the best clutch/bearing combo Triumph 4
I Best glue for rubber door panels? Spridgets 3
N Best cam choice??? Spridgets 5
R TR2/3/3A Best day ever [so far] Triumph 1
C How best to restore red script on valve cover? Austin Healey 7
F Best $25 I've ever spent on my Healey - 2019 Austin Healey Concours Guidelines Austin Healey 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
D Best little tube bender Restoration & Tools 8
N Best lube for a Datsun gearbox?? Spridgets 6
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
I General TR Best car cover Triumph 8
M Best Interiors Austin Healey 20
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
N Best carpet glue???? Spridgets 5
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
B best diff British Motor Corp 5
Boink Pre-War MG-TB wins best in class at Forest Grove Concours MG 7
T TR2/3/3A What is best way to flush engine after antifreeze got in oil?? Triumph 2
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
MisterB Spitfire Best year for a Spitfire? Triumph 12
D TR4/4A Best SU overhaul service to use? Triumph 10
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
Gerald_Gordon TR4/4A Best carpet for TR4 Triumph 2
C Best Replacement BN1 Leaf Springs Austin Healey 5
