Half way?
TexasKnucklehead
Since I picked up my (58 TR3) flood victim 8-2006, I've spent a lot of time in the garage. Some of it was spent cleaning up parts, painting and reassembling subassemblies, but most of it has been taking the car apart. Today, I consider myself at the half way point, because I no longer have anything to take apart. Now all I have to do, is put it back together. I have parts everywhere, and got them from all over the country thanks to ebay and this forum. I can't turn back now.
M_Pied_Lourd
Tex,
Always nice to get to that point. The only way to go is forward!
Cheers,
M. Pied Lourd
Gliderman8
From this point on the job gets cleaner too :banana:
TR4nut
Geo Hahn said:
I think that's called 'Ratchet Reset Day'.
I like it! Just wish there was 'Close Wallet Day'.
Nice job there Tex - I think you are quite a ways ahead of me but it is very good motivation!
toysrrus
Howdy Tex,
I started my `57TR3 early Jan. this yr. Thanx to a friend of mine who has a "Lift, Ton of Tools, Torches, Saws" etc. We got the "Dismantle" the body parts off quite quickly.
What I did then; Got everything blasted including the chassis. The 1st. "Re-Build" part I did (So it looked liked something was being re-built). Then applied "POR-15" to the Chassis via brush. It came out "Great" and the "Motivation" took a second leap.
By the way; If your reading this "Fred"; Thanx, I could`nt have done it in the time span we did without your Help!!
Keep on Restoring,
Russ
V
vagt6
Tex, I like your attitude.
Keep at it. I promise you, the finished result will be a source of great pride for the rest of your days.
There's no car like a TR-3, it bridges the gap in automotive history from the 1940s to the 1960s. Beautiful car, plenty of power, loads of fun to drive and a guaranteed head-turner everywhere you go.
Keep working at it, and please post photos of your restoration. This kind of documentation on a frame-off resto is very valuable.
Cheers to you, Tex! :yesnod:
tdskip
That is a milestone isn't it. Now it all gets to be cleaned up, refreshed and put back together.
Any surprises so far?
Keep us posted!
T
TexasKnucklehead
Right. I'm going forward, and reset my ratchet -my only competition with TR4nut involves closing the wallet. (Which probably will involve someone living longer!) I'm going to have the frame sand blasted tomorrow, my project is a little unusual and the PO applied POR15 without so much as cleaning off the loose dirt. So my first challenge was to get down to bare rust. A razor blade works great for that.
Surprises? POR15 is hard. If you get some on a rear lug and install the wheel while it's still wet, 2 out of 2 lugs will pull the threads out of the hub, before the lug nut comes off the lug.
After dripping for two years in my garage, the diff still had fluid in it. You can clearly see some oil on top of the water in the picture.
After a car has been under 20' of water for a day, the surprises never stop.
The passenger side leaf had an extra plate on top of it. Is that right?
pjsmetana
TR4nut said:
...wish there was 'Close Wallet Day'.
Don't we all :smile:
Yes sir.
TR4nut
karls59tr said:
Why does the passenger side leaf spring have an extra plate?
I think the story is that the plate lowers the passenger side so that the car is more level when you have a single driver in the car.
Twosheds
That is correct. Married drivers are lighter and the plate is not necessary.
pjsmetana
HAHAHAH!!!! I just shared this one with my wife!
T
TexasKnucklehead
I could not justify the aditional cost of powder coating, but did have the frame sand blasted for $175. Then I put a coat of oil based primer followed by two coats of flat black while I decided what to do about the holes blown through the frame near one of the rebound brackets during sand blasting. I suppose rust can hide from a screwdriver, but not a blaster. Anyway I got some 1/8 inch thick metal and made two pieces with holes drilled to sandwich the area, and had them welded in place today. It's as sold as ever now, and I'm close to starting putting it back together.
Is getting closer to 1/2 way sort of like closing the door 1/2 way each time, and knowing you'll never really get it closed?
T
TexasKnucklehead
Spring is here. I live in Spring Tx, but that's not my update. I'd say spring has sprung, but that might imply a faulty spring compresser. Today I installed the front springs, wheel bearings, hubs and front wheels. I will not say I have a 'rolling chasis' because a set of used bed rollers doesn't really count as a rear axle -but I've made progress and am excited about it.
TR4nut
Looking good again Tex. I've started on the back end, just because there are less parts!
T
TexasKnucklehead
Another update. I'm not sure when a pile of parts becomes a 'rolling chasis', but I rolled my frame out into the driveway today and snapped this picture. I think rebuilding the front end was much easier than the limited work I did on the differential. -But I've got all new seals and axle bearings back there, as well as slaves and brake springs. And the diff is all nice and clean inside (and out), and not leaking any oil (and I filled it with oil).
Now for the engine, brake lines, front calipers...
Got_All_4 TR5/TR250 Only half of the tack is lit Triumph 14
F TR2/3/3A back half to chassis questions Triumph 105
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
B BJ8 Half-Shaft Oil Seal Austin Healey 5
SD Bugeye Half capacity of the fuel tank Spridgets 10
tahoe healey half car cover Austin Healey 3
D Front suspension half moon cotters Austin Healey 6
J Half round tube or D tube source ?? Restoration & Tools 2
A Aligning New half front wing, outer sil and rear wing Austin Healey 5
Jim_Gruber Looking for back half of PS Floorpan for my BE Spridgets 6
S TR2/3/3A Well onto the second half Triumph 2
Boggsy64 MGB Half shaft question MG 2
H brake calliper half seal size Austin Healey 4
Bremer TR2/3/3A TR3 half doors Triumph 11
G Half shaft removal Triumph 3
Jim_Gruber Progress - Suspension half done yeah! Spridgets 2
Brian_James Wire wheel half shafts and bare 1275 block Houston Spridgets 1
PatGalvin TR2/3/3A Rear Half of TR3A Tub for Parts or Scrap??? Triumph 9
hondo402000 new CV half shafts Triumph 49
KVH TR4/4A TR4A Allowable Half Axle Play Triumph 0
ScottTR6 Half shaft replacement Spridgets 7
B TR6 TR-6 U-Joints/Half-shafts Triumph 13
tweety Changing a half axle Spridgets 1
S I hope my car looks HALF as good as this one...... Jaguar 6
jvandyke weird half top, soft targa? Spridgets 10
mrv8q TR6 TR6 half-shaft removal Triumph 15
B 3.9 Diff/half shaft/spline question. MG 2
J Spitfire Spitfire Half shafts Triumph 3
F Removing Axle Half Shaft [Tube Type] MG 4
hondo402000 TR6 TR6 dropped the Diff out and half shaft question Triumph 2
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
G Cut body in half? Triumph 20
JPSmit Help #3 - diff + half shafts now Spridgets 2
G Ninety nine and a half just won't do.... Triumph 15
drooartz Tips for brake drum/diff/half shaft removal Spridgets 14
G Flag at Half Mast for a While at AAW Triumph 6
Z Axle half shafts Austin Healey 0
GB1 Half Shafts - Hardened Spridgets 18
A Introduction [half a day late] Triumph 6
bighly Dream Machines in Half Moon Bay CA Austin Healey 1
martyc Help! Stupid Half-Tonneau Question MG 3
J TR6 TR6 - half top/bikini top? Triumph 1
D Stag Stag half shaft removal Triumph 6
TypeRboy Half way there.. Lotus 1
Basil Half-axel U-joints - HELP! Jaguar 6
