Results 1 to 9 of 9
Thread: Recommendations for radiator hoses - 1500
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Jedi Warrior bigjones's Avatar
    Join Date
    Apr 2008
    Location
    Raleigh, NC
    Posts
    743
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Hi folks,
    The lower hose is started to show cracks.
    Might as well replace all hoses while I'm at it so has anyone got recommendations for good qualty radiator hoses for a 1975 (1500 - rubber bumper) Midget.
    Also, is there any other preventive maintenance that should be done "while I'm at it"?
    The car is running famously (not overheating or anything - I just want to keep it that way!)
    Cheers
  2. #2
    Join Date
    Apr 2008
    Location
    Raleigh, NC
    Posts
    743
    Thanks Thanks Given
    Thanked in
    Re: Recommendations for radiator hoses - 1500
    Also,
    there doesn't seem to be a nice way of draining the radiator.
    Do folks just undo the lower hose and hope to catch all the antifreeze in a tray? Or is there a better way?
  3. #3
    Jedi Warrior bthompson's Avatar
    Join Date
    Jun 2008
    Location
    Belmont, NC
    Posts
    592
    Thanks Thanks Given
    Thanked in
    There's no nice way...and don't even bother trying to catch the antifreeze. Ain't gonna happen. At least, it never does for me. Just pull 'er over the grass and let it gush...and hope the EPA black vans aren't patrolling.
  4. #4
    Jedi Hopeful losmorob's Avatar
    Join Date
    Nov 2007
    Location
    Los Molinos, CA
    Posts
    129
    Thanks Thanks Given
    Thanked in
    And NO PETS!!! They love the sweet taste and it kills them.
    I use a cardboard box knocked down flat with a large oil drain pan. Most of it hits in the pan while any spillage is soaked up by the cardboard.
  5. #5
    Great Pumpkin jlaird's Avatar
    Join Date
    Nov 2005
    Location
    Loganville GA winter & Highlands NC summers
    Posts
    19,583
    Thanks Thanks Given
    Thanked in
    Understand that the newer anti freeze is no longer loved by pets. Thank goodness.
    Jack Laird
    Retired USAF
    Miss Agatha. On the road again and smiling at her new Calif. home.
    Fourteen shows, Eleven firsts and counting we hope.
  6. #6
    Yoda Morris's Avatar
    Join Date
    Aug 2005
    Location
    Austin, TX
    Posts
    3,067
    Thanks Thanks Given
    Thanked in
    I brazed a drain valve into my radiator. Works great.
    I can't remember where I bought my hoses, but it was either VB or Moss. I bought them about 2 years ago and they already look like they are 20 years old. Just FYI.
    You can live in a car but you can't drive a house.
  7. #7
    Join Date
    Apr 2008
    Location
    Raleigh, NC
    Posts
    743
    Thanks Thanks Given
    Thanked in
    Folks,
    Many thanks for the info.
    I was hoping to save the antifreeze (and just add a bottle of that water pump lubricant stuff you can buy at FLAPS)
    Guess I'll just get a fresh jug of antifreeze (is it just me being a geezer or is that stuff gone expensive, or what).
    As far as the hoses, I remember an old-timer trick of wrapping the new hose with electrical tape - supposedly extends the life of the hose - like Morris says, they don't last too long otherwise. Course the problem with the tape is that you can't see 'em when they start cracking and leaking, ha!
    Cheers!
  8. #8
    vagt6
    Quote Originally Posted by bthompson
    I'm pretty sure that most of us here are astute enough NOT to take the above advice. The stuff in your radiator/oil pan is potentially toxic and when you pour it into the "grass" it goes YOUR community's ground water (e.g., your kids and neighbors drink it eventually). Same for waste oil, used pesticides, etc.a Dispose of it responsibly.
    Sorry, but that suggestion is just plain bad for the environment (actually, YOUR environment).
    Back to my hole now . . .
  9. #9
    Join Date
    Apr 2008
    Location
    Raleigh, NC
    Posts
    743
    Thanks Thanks Given
    Thanked in
    That's right and it's another reason to try and save your antifreeze - if I manage to do so, can I just add a bottle of that white stuff called "water pump lubricant", or something the other? I mean, does it contain enough of the anticorrosion agents? Anybody know?
    Cheers
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
