TR2/3/3A Panhard or Rear Sway Bar on aTR3?
Twosheds
A panhard rod keeps the rear from moving left-to-right as the car corners.
A sway bar increases roll stiffness.
martx-5
Panhard Rod... Laterally locates the rear axle.
Sway Bar... Is actually a torsion bar between the right and left side that increase the spring rate in turns to help keep the car level.
Edit: twosheds was quicker on the draw...
Twosheds
Ah, but Art has links!
Moseso
Thanks for the link! Tabcon posted some tasty pics of a Watts Link arrangement he made for his car, and I wondered what the heck it does. Now I know...
K
karls59tr
Bronze
Quote from "Vintage Racing" by Terry Jackson:There is some disagreement whether a rear sway bar is needed on early TRs. Many racers say that adding a sway bar only increases the the natural understeer of the car. Some such as Hedke have added a 1/2" bar at the back with good results. Try a small bar but dont be surprised if it does more harm than good." Anyone running a rear sway bar on their TR3?
TR3driver
Great Pumpkin - R.I.P
I had one on TS39781LO for many years (in combination with a front bar, of course). On the street, I felt it improved handling overall, in the sense that I could no longer find that point where the car would suddenly transition from understeer to oversteer and, as Car & Driver put it, "bumble off backwards". However, on the autocross track, I felt it slowed me down overall, because it increased the tendency for the inside rear tire to lift and not be able to put power to the road coming out of a tight corner.
IMO the proper solution was a stiffer front bar (perhaps combined with some suspension mods to raise the front roll center); but I never got around to trying that. A limited slip differential would help a lot, too (got two of them on order
M_Pied_Lourd
Karl,
As you know, there is one on mine. I would add that is was installed on my car when I bought it along with a very beefy front sway bar. This car was a vintage racer for most of it's later life.
According to the racing log books that came with my car it was first raced on May 26th, 1983 at Second Creek Raceway (North of Denver, now closed it looks like) and finished it's racing career on July 11th 1998 at La Junta Raceway CO.
I am assuming that after 15 years of racing that the rear sway bar set up on the car must have worked well.
I have yet to drive the car so I can't comment as of yet. I will be interested to see what others have to say on the subject however.
Cheers,
M. Pied Lourd
bgbassplyr
Just to mess with your mind, think about a Z bar. This is a bar in a Z shape with the ends mounted in the normal sway bar locations on each leaf spring. A normal sway bar, when loaded in a turn, tries to counter the body roll by lifting the opposite end of the axle. A Z bar on the other hand, tries to force the opposite wheel onto the road.
Never tried it on a solid axle car, but on a swing axle (VW-
formula Vee), it works really well. Just look at the races and championships won by Zink Formula Vees in the 60's that were delivered equipted with a Z bar.
OK, talk me down...........
PeterK
And then there's TractionMaster bars to stop spring wrap-up. I have an old set (refurbished and ready) but I still haven't decided on the front attachment point.
TR3driver
Or, another way to put it, a Z-bar lifts the outside wheel. In effect, it reduces roll stiffness, without changing basic spring rate; while a sway bar increases roll stiffness.
Certainly would do nothing to solve the problem I was trying to solve; which is that the TR3 rear suspension lacks enough rebound travel. With the factory setup, in a hard turn, the inside wheel runs out of travel and hits the frame. The sudden impact is what upsets the car's handling so badly ... if you are lucky, the rear end just 'steps' sideways as the outside tire loses traction (due to the full cornering force being suddenly transferred to it), which unloads the inside spring and allows the inside tire to sit back down. It's a rather amusing effect actually, if you are expecting it.
Since the Z-bar reduces roll stiffness in the rear, it also increases understeer (which IMO a TR already has plenty of, especially if you are running a front sway bar or have increased the front spring rate).
Healey Nut BT7 Panhard Rod Austin Healey 28
John Turney The Panhard Rod is Supposed to be Straight, Right? Austin Healey 7
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
John Turney Panhard Rod Austin Healey 14
DanLewis Panhard Bar Kit from Mini Mania Spridgets 0
DanLewis Would a Panhard bar fix this problem? Spridgets 11
steveg Is a Panhard Rod Necessary? Austin Healey 34
Simmo TR2/3/3A Panhard Rod Triumph 9
N Panhard Rod Mounting???? Spridgets 9
K Panhard Rod on a TR3 Racing 3
Nelson Panhard Bar vs Watt's linkage Spridgets 17
J Do I have a panhard rod problem? Austin Healey 12
Trevor Jessie Panhard Bar Spridgets 29
R Panhard Bar Kit Spridgets 3
H Panhard rod Austin Healey 1
T panhard bar for tr4-where to locate & mount Racing 20
T TR4/4A looking for pictures-tr4 with panhard bar Triumph 7
GB1 Panhard Mounts Spridgets 7
GB1 1/4 elliptical Panhard & Sway Bar Spridgets 1
aeronca65t Panhard Rod for Sprite Spridgets 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
