Pinging [newly rebuilt engine]
Lucky_B
Have tried all the usual things: i.e. adjust timing, degree timing, higher octane gas, Gas octane buster, adjust valves and I cannot stop pinging. I am assuming when the engine was rebuilt .030 over, I had the block skimmed and the head re-done (skimmed), I have increased the compression to a point that it now pings.
How do I lower the compression? Are there thicker head gaskets? should I use 2 head gaskets?
Help Please,
Weezer
Platinum
Sandwiching two gaskets is just ASKING for trouble, IMO. Did you use the concave pistons or flat tops?
There's some "meat" in the combustion chambers you can safely remove, that may help. 93 octane without "boosters" is all you ~should~ need, timing retard should settle it out. Since you've tried all that without success, is the dizzy advance coming in too soon due to weak springs mebbe? How much did you deck the block/head?
OH! And welcome to the forum!
Lucky_B
Lucky_B
Distributor is a newly rebuilt from Advance Distributors The pistons are concave pistons. Unknown how much was taken off the head and block.
This is a 77 MGB
OH, thannks for the welcome been here awhile just never posted
Platinum
Well, Jeff's rebuild shouldn't be at issue then... what carb setup? Roy has a point.
Lucky_B
Lucky_B
Has Stromberg carb, all pollution control devices California registered car requiringe smog certification
Weezer
Platinum
eeep. I think we've found the issue. I don't have access to the needle charts but I recall seeing a good on-line reference posted a while back. Do ya know what needle is in it now? Have you tried a bit of an enrichment yet?
jessebogan
Do you still have the EGR valve on it, and if so, does it work? If it is inop, you might want to get it to work as that helps to quell detonation. How about a compression test? Check what the timing is at full advance (3000 to 3500 rpm) Does your car have the 4th gear switch for the spark advance? Finally, how warm is it running? Can you check with a non contact thermometer to verify that it is not too hot? Sometimes a new rebuilt can be tight and the excess friction can add to the problem. Keep us posted on your progress.
Lucky_B
Lucky_B
Yes, I do have the EGR in place. I also have the 4th gear vacuum switch. I have not looked at that possibility as of the EGR faulty.
I do not have the Compression readings. I will get that this weekend
It is not overheating as I have an aux fan to augment the original and i can keep the temp around 180 to 190 degrees. Checked with an infrared thermometer.
Thanks for help I think I may be close with the EGR not working. That will be my next check.
Weezer
Lucky_B
Lucky_B
Well, checked the egr valve - works as it should, Cleaned it anyway. I did a compression check and it reads: 1-155, 2-155, 3-125, 4-155. No 3 will go to 155 if I put oil in the cylinder.
checked advance at 3000 rpm and got 22 degrees of advance no vacuum connected.
Weezer
tdskip
Have you tried a gunson colortune to see how the mixture is when she is running? Might help either focus in or move on to something besides mixture.
Where in SoCal are you?
Deleted member 8987
With the quality of fuels available today as compared to what they were when that vehicle (and settings) were new, first thing I'd be doing is backing off the timing.
Pinging causes ring flutter, which causes oil burning.
Oil burning can cause pinging.
Lean mixture can cause pinging (but your color looks okay).
EGR opening too soon causes lean mixture (the only way to know is run it in "ping" mode for a bit, hit neutral and ignition at the same time, roll off the road, pull the plugs THEN).
Seen a lot of red cats with EGR dumping too soon.
Once pinging starts, you need to fully stop it prior to proceeding.
I don't have my books in front of me, but 22 degrees with no vacuum advance sounds a tad steep.
Back initial off 5 degrees and try it again.
Dave
Deleted member 8987
The closest reference I can find is for a 1977 18V which is 26-30 at 4500 centrifugal.
The advance is a Lucas 5-13-10, starts at 5", ends at 13", with a total of 10 degrees advance.
The basic rule is advance the timing until it "pings", then back it off (usually with the knurled knob) until it doesn't.
Driving it in "ping" mode is going to take out the upper rings, if it hasn't already.
Lucky_B
Lucky_B
Thanks Dave
I will try what you have suggested. My next step is to remove the EGR and go from there I will also back down the timing
Weezer
tdskip
Weezer - correct range through the whole RPM range or "just" at idle?
(wondering if the advance is a bit much for your car, Jeff can adjust, or you can back timing off as mentioned to compensate).
Lucky_B
Lucky_B
I am going to remove the EGR and see if that makes a difference. This only manifests itself when warm and accelerating. My distributor is a 45D (no Wheel) and it was recurved for my car by Jeff at Advanced Distributors, so I am confident that the distributor is good.
Weezer
A pinging / pre ignition Spridgets 2
KVH TR4/4A TR4A Pinging Under Load Triumph 6
Morris Thermostat vs. Pinging Spridgets 14
R Octane levels - engine pinging Austin Healey 4
RobT Pre-Ignition [Pinging] Question Triumph 21
J pinging or knocking Austin Healey 13
LastDeadLast Pinging Alana, EFI related Triumph 1
H Ignition timing and pinging Austin Healey 1
KVH Timing/Pinging Triumph 16
Got_All_4 TR6 Newly purchased poor quality timing gear Triumph 5
Csarneson Storing a newly rebuilt engine Austin Healey 25
BN6 Breaking In Running In a newly built Healey Engine Austin Healey 15
2wrench Timing set on newly installed BP270 cam Triumph 7
Got_All_4 TR6 Newly Acquired 1969 TR6 & Interior Trim Question Triumph 20
T Caring for Newly Painted MG B Restoration & Tools 9
vping Newly sealed Gas tank - Pics MG 24
Mark_Gibson TR6 Newly Finished TR-6 Frame Off project Triumph 23
Basil Newly restored Daimler SS Wheel Other British Cars 5
S Newly Aquired MG Midget MG 5
poolboy For Sale REBUILT Carbs for TR6 Triumph Classifieds 0
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
D The best place to get shocks rebuilt. Spridgets 8
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
K For Sale Two Rebuilt TR3 AUC 878 SU Carbs Triumph Classifieds 3
D Starting After Carbs Rebuilt Austin Healey 30
S TR2/3/3A problem just rebuilt SU carbs Triumph 28
Got_All_4 TR6 Engine pulley dampener 69 vs 70 also new or rebuilt Triumph 1
BJ8Healeys For Sale Rebuilt BJ8 overdrive unit for sale Austin Healey Classifieds 0
steveg HD8s easily rebuilt at home Austin Healey 4
D Need to get a vaccuum advance rebuilt Jaguar 2
K TR2/3/3A Rebuilt steering has creative fix for NA worm bearing! Triumph 4
vickxxx T-Series Distributor rebuilt MG 2
B General TR Putting the rebuilt gear box back in the TR6 Triumph 1
S My recent decision regarding oil in a '66 3000 with a rebuilt engine Austin Healey 101
jfarris TR2/3/3A Rebuilt SU Carbs - Car Won't Start Triumph 7
Marvin Gruber Three rebuilt BJ8 engine- FINALLY! Austin Healey 17
J TR2/3/3A Finally started 17 year old rebuilt motor! Triumph 3
M rebuilt gauges Spridgets 10
gbtr6 General Tech What oil to use in the gearbox, not rebuilt. Triumph 9
gbtr6 TR6 Prime oil pump in rebuilt engine... Triumph 10
britlover TR4/4A Where can I get an A-type TR4A Trans rebuilt in SE Michigan? Triumph 9
C BJ8 Rebuilt Engine and Carbs - Vapor Lock and Misfires when hot Austin Healey 7
cmacmillan TR6 now what have I done? choke on rebuilt carbs.... Triumph 6
J Starting rebuilt engine ! Austin Healey 8
F TR2/3/3A I just installed a rebuilt C39 Generator on my TR3 Triumph 11
bugedd Front end rebuilt help Spridgets 6
