TR2/3/3A tr3 2" gauge bezel
ekamm
tr3 2" gauge bezel
Any one know where I can get a 2" dash gauge bezel? It's for the ammeter but I assume that all 4 gauges are the same.
martx-5
Re: tr3 2" gauge bezel
Yes, I think they are the same, at least from what I've experienced, however, I do think I remember reading of two different types. I probably have a few in the basement. Let me check later and I'll post back if you haven't come up with anything by then.
TR3driver
Great Pumpkin - R.I.P
Are you talking about the glass itself, or the chrome ring around it?
I believe the glass interchanges between the 4 gauges, but the chrome ring for the ammeter is definitely different. For the ammeter, it's actually part of the gauge housing rather than being just a removable ring. To disassemble, you bend the tabs at the back and pull the movement out of the back of the case.
ekamm
ekamm
So after looking a little closer the ammeter is Lucas and all of the other instruments are Jaeger. The bezel is different on the ammeter and I had planned to replace it to the correct, but now wonder if it was changed and the bezel on the Lucas gauge was a little different. If so I guess I'll just keep it that way. I'm about to tackle new interior including the dash and I just thought I might as well get the correct bezel.
TR3driver
It is just a little bit different visually, but not much!
prb51
Randall,
Is that California sarcasm? Looks out of place to me but I've a thing about mismatched gauges.
TR3driver
Uh, no, just the only photo I had handy that had both an original ammeter and 2 out of 3 other original gauges.
As far as the obviously (I hope!) non-original temperature gauge, well, I have a thing for gauges that work.
If you have a better example, then by all means, let's see it!
Number_6
You might try these guys. When I bought my car it had the incorrect Tach in it and I was able to get the correct Tach thru them. You could email them, they may have the correct ammeter.
https://www.britbits.com/
ekamm
ekamm
So is the Lucas ammeter the original? And were all of the bezels thee?
TR3driver
Yes, the ammeter was made by Lucas. The photo I posted above shows original, unrestored, ammeter, oil pressure and fuel gauges.
Here is a shot of someone else's car (sorry, I forgot to record whose, please let me know if you recognize the photo), showing very nicely restored gauges in a later (post-60K) panel:
(click on the image to zoom in)
martx-5
That panel looks like one of those offered on ebay. There's a guy there that rebuilds them and offers them for about $600-$700 IIRC.
LD-Ordie TR2/3/3A TR3 gauge service Triumph 11
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
B TR2/3/3A TR3 Temperature gauge Triumph 19
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
K For Sale TR3 Amp Gauge Triumph Classifieds 0
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
jfarris TR2/3/3A TR3 Gauge Restoration Triumph 6
jfarris TR2/3/3A TR3 gauge panel and nuts on gauges Triumph 5
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
G TR2/3/3A TR3 Temp gauge Triumph 2
T TR2/3/3A What gauge steel use for TR3 frame? Triumph 3
Tr3aguy TR4/4A Amp Gauge TR3 vs TR4 Triumph 4
K TR2/3/3A TR3 Temperature Gauge...cost to repair? Triumph 11
luke44 TR2/3/3A TR3 Oil Gauge Line Triumph 3
N TR2/3/3A TR3 Gauge Rebuilding Triumph 6
6 TR2/3/3A electric coolant temp gauge in TR3... Triumph 6
A TR4/4A TR4 FUEL GAUGE CONVERSION FOR A TR3 Triumph 4
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
B TR2/3/3A TR3 gauge needles Triumph 10
tinman58 TR2/3/3A TR3 temp gauge Triumph 13
S TR2/3/3A tr3 gas gauge calibration resisters Triumph 12
T TR2/3/3A TR3/4 elec. temp gauge Triumph 6
S TR2/3/3A tr3 gas gauge Triumph 5
K TR2/3/3A Picture of TR3 Dash Gauge Layout Triumph 2
W TR2/3/3A Temperature Gauge Rebuild TR3 Triumph 19
martx-5 TR2/3/3A TR3 Fuel Gauge Triumph 17
K TR2/3/3A TR3 Temp Gauge Upgrade? Triumph 5
K TR2/3/3A Reliability of TR3 Temp Gauge? Triumph 16
K TR2/3/3A TR3 Erratic fuel gauge finally quits....testing? Triumph 4
luke44 TR2/3/3A TR3 Water Temp Gauge Core Triumph 14
K TR2/3/3A The TR3 Bouncing Ammeter Gauge? Triumph 6
RedTR3 TR2/3/3A TR3 Oil Pressure Gauge Hose Triumph 3
MGTF1250Dave TR2/3/3A TR3 Temperature Gauge Face Markings Triumph 3
mountainman TR4/4A TR3 - Tr4 Temp Gauge Triumph 5
S TR2/3/3A gas gauge TR3 Triumph 7
A TR2/3/3A NOS TR3 Temperature Gauge Triumph 8
TRclassic3 TR2/3/3A TR3 temp gauge Triumph 15
prb51 TR2/3/3A TR3 Op temp issue and mechanical gauge Triumph 7
newmexTR3 TR2/3/3A TR3 Oil Pressure gauge issue Triumph 8
martx-5 TR2/3/3A TR3 Oil Pressure Gauge Triumph 3
martx-5 TR2/3/3A TR3 Fuel Gauge Calibration Triumph 13
H TR2/3/3A TR3 Temperature gauge Triumph 23
Brooklands TR2/3/3A TR3 Temperature Gauge Triumph 38
C TR2/3/3A TR3 Amp Gauge to Volt Meter Triumph 8
S TR2/3/3A Tr3 fuel gauge sending unit Triumph 6
A TR2/3/3A TR3 gauge position question Triumph 7
P TR2/3/3A TR3 Fuel Gauge Triumph 4
