A. Salnick
I have a quick question for those of you with overdrive gearboxes in your TR6s. My gearbox in direct third starts to whine a little. When I shift into fourth it doesn’t change much. Then as I increase in speed, it starts to get a pretty loud whine. Then, when I drop the overdrive in, the gearbox goes silent. Any thoughts as to why this might be happening? The gearbox has new front, center, and countershaft bearings and synchros, bushings etc... The overdrive has had nothing done to it. The gearbox seemed all to spec when I put it together. There has been no change in this behavior in some time. I have flushed it a couple of times to no avail. I have tried running gl4 90 wt gear oil, and redline as well. It seems to be something on the output side as it is speed related…..
