TR6 TR6 Valve cover
bcbennett
Hello all. Got a few questions:
1. My valve cover is bent. I see in the catalogs that you can buy a new aluminum spiffy one, but since my car is a '74, sometimes it says "Must be modified for models 74 forward." What does this mean?
2. How do those super gaskets work--are they utterly preferable to regular gaskets? Do they work with bold old and new valve covers?
The situation is that mine is becoming bent due to over-tightening of the top screws. I would like to either get a new one or a NOS. Any advice is appreciated.
Brad
TR6BILL
Not sure why the modification is needed, perhaps something with pollution venting.
The silicon gasket does not fit the cast aluminum cover.
Stay with original, it is baffled where the aluminum is not. Can get oil into the carbs.
Finding an original is not that hard.
bcbennett
bcbennett
Bill, great! Does it fit a '74 just like my original? I'd be happy to take you up on that and pay for postage, etc.
DNK
Hopefully someone will answer that like Paul or Ken
T
Tinster
DNK said:
Anybody need a 71 head too?
<span style="color: #CC0000">Hi Don !
Would "special shipping and handling" to zip code 00961
exceed $1200. ??
I know "special shipping and handling" for a head gasket
is $84 and a head weighs a bit more than a gasket. LOL
dale</span>
poolboy
I see that Moss has but 1 valve cover (a reproduction) listed for all the years. The Aluminum V/C requires either removal or some sort of modification of the EGR valve.
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
T TR6 Back to that stock TR6 valve cover. Who, where... Triumph 0
T TR6 High temp paint required for TR6 valve cover? Triumph 13
G TR6 I want a stock valve cover for my TR6 Triumph 7
roofman TR6 TR6 silicone valve cover gasket Triumph 9
roofman TR6 TR6 silicone valve cover gasket Triumph 2
I TR6 TR6 valve cover leaking Triumph 5
B TR6 TR6 aftermarket valve cover Triumph 7
B TR6 TR6 Valve Cover Gasket Triumph 5
Stinky TR6 TR6 valve cover ??? Triumph 3
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
sundown TR6 1973 TR6 bypass valve Triumph 1
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
S TR6 Help! Need help from TR experts with this frustrating TR6 pushrod/rocker/valve issue Triumph 23
smaceng TR6 TR6 brake pressure balance valve Triumph 2
P TR6 tr6 valve guides Triumph 14
D TR6 76 TR6 Stromberg Air Valve Triumph 2
Gliderman8 TR6 Setting TR6 valve clearances Triumph 19
Coyote1 TR6 TR6 EGR Valve Delete ? Triumph 9
Brosky TR6 TR6 Heater Valve - EXPOSED Triumph 9
I TR6 69 TR6 engine suggestions - cause for burnt valve? Triumph 5
D TR6 TR6 Valve Springs Triumph 26
wangdango TR6 '76 TR6 pcv valve, etc Triumph 3
I TR6 TR6 valve adjustment help Triumph 3
hondo402000 TR6 New Heater valve installed from Parts america TR6 Triumph 4
TR6oldtimer TR6 TR6 valve reality check Triumph 4
I TR6 69 TR6 vacuum control valve Triumph 8
I TR6 PCV valve attachment 69 TR6 Triumph 5
GT6_Mark GT6 GT6 TR6 etc Oil Filter By-Pass Valve Pressure Triumph 2
I TR6 TR6 valve help/upgrade? Triumph 26
E TR6 TR6 Valve Train Specs Triumph 0
F TR6 Oil Pressure Relief Valve- TR6 Triumph 2
G TR6 TR6 inlet valve dimensions Triumph 4
A TR6 tr6 valve lifters--which ones??? Triumph 21
G TR6 Anti run-on valve question for 73 TR6 Triumph 3
AltaKnight TR6 TR6 leaky heater valve Triumph 2
V TR6 two piece valve spring retainers on tr6 and 250. Triumph 1
R TR6 TR6 EGR valve Triumph 12
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
